Power Caster Adapter - Fiberglass RV
Old 02-04-2003, 02:04 PM   #1
I have to back the trailer down the side of my house between the house and the fence, and there is only about 4" on each side so it took several times to get it just right because I had to go about 80'. The problem is there was no room hardly to make adjustments. If you moved one way a little, the truck fender was against the house or the fence. Thought a power Caster would solve the problem, and it did, but now had a different problem, had to have jackstands to raise the the trailer on, then move the truck and put the tongue jack into the power Caster. All of this was a hassle to deal with. There is now a solution, Power Caster now has an adapter that will fit on the tongue. All you have to do is raise the tongue with the tongue jack, slip the Power Caster under the adapter and away you go. No more hassle or shaky trailer up on a jack stand. So if you have a power Caster that you don't use because of the hassle, order the adapter. Now it's a breeze.
Old 02-04-2003, 10:27 PM   #2
power
Do you happen to have some type of picture of this. it's sound really interesting, but I'm probably way off on what it actually looks like.
Old 02-05-2003, 12:15 AM   #3
Jan, Jan, Jan
http://www.powercaster.com/ :)
I think it's a great idea and I am sure many people would find it quite useful.
need adapter 13 scamp BarryS Towing, Hitching, Axles and Running Gear 4 08-17-2009 03:40 PM
Four-prong flat to seven round wiring adapter Adam S. Classified Archives 0 07-03-2009 05:05 PM
Help find a 30 amp (Hubbell twist lock) to 15 amp adapter rudock1 Problem Solving | Owners Helping Owners 10 12-14-2008 11:36 AM
Wiring Adapter? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 3 06-20-2003 06:21 PM
