Power cord and Inlet Question - Fiberglass RV
Old 04-08-2012, 11:54 PM   #1
bomni's Avatar
Name: Matt and Lindsey
Trailer: 1972 Boler 1300
Hey Everyone,
We are both not electrically savy, but I (Matt) am a quick learner and have a general idea of how electricity works and have done some wiring. We bought an RV cord (Camco 30A male to 30A female) from Canadian Tire like this.
We also need to replace the Bargman 30A inlet in our Boler and have been looking at the Furion Inlets on Vintage Trailer but they look a little different. Does anyone know if the prong set up is compatible with the power cord we purchased? Its a bit confusing as the new type is locking. I have been unsuccessful in trying to find one that is the same as the Bargman. Any help would be great!
Thanks in advance
bomni is offline   Reply With Quote
Old 04-09-2012, 03:38 AM   #2
Trailer: U-Haul ct-13
Quebec
Just bought a marinco 30amp rv inlet. The one you are looking at is a marine grade inlet and the power cord you have is a rv connector type. The male part on the inlet is not the same on a marine grade as on a rv. Just look on the pin partern and you will see what I mean. The other thing is that in campground you need the rv male conmector, I dont think the marine will fit.
https://www.americanrvcompany.com/mo...p?itemid=11619
theman is offline   Reply With Quote
Old 04-09-2012, 08:19 AM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Most of the 30 amp inlets I've seen use twist lock connectors. As Frederic stated it looks like you purchased a 30 amp extension cord with a standard TT-30 female connector - I've never seen a TT-30 inlet. To use this cord with a standard twist lock inlet you would would need an adapter, or better yet, replace the cord's female connector with a twist lock that matches a standard inlet (a NEMA L5-30R).
Old 04-09-2012, 08:58 AM   #4
I Installed the marinco receptacle with a wether tight cap and got the matching power cord.
If U do that you will B happy come camping time because the Marinco receptacle seals tight and keeps the ants out, the ants that crawl up the power cord and enter the camper through the big hole where you shove the cord in when not in use.
Old 04-09-2012, 01:45 PM   #5
A newbie question here, At the campgrouds, is there some special plug I need to use ? My egg came with a heavy duty extension cord that just plugs inot my outside outlet. Do I need more than that? I am planning on leaving on my great adventure this weekend and I want my electric creature comforts,especially my ceramic heater- its snowing up here in the mountains!
adkboler is offline   Reply With Quote
Old 04-09-2012, 02:34 PM   #6
Oswego, NY
What kind of connector is on each end of the heavy duty cord?
Old 04-09-2012, 04:07 PM   #7
The answer is Maybe.
You can find the Adapters at Walmart. They have a selection of adapters and RV items and are not as expensive as a camper store or campground.
Old 04-09-2012, 04:38 PM   #8
Walmart has several listed, which one should I get? I am staying in KOA's mostly..and have a 5000BTU air conditioner and small fridge.
Road Power 30/15-Amp RV Power Adapter Cord
Road Power 30/50-Amp RV Power Adapter Cord
Thanks for all of the good advice, I love FGRV!
Old 04-09-2012, 08:59 PM   #9
bomni's Avatar
Well we have decided not to spend $220 for both a new cord and an inlet. We are going use the cord we bought at Canadian Tire and cut the end off on use the newer style twist lock type and also purchase the furion inlet. Has anyone done this before? I am no electrician but it seems to be pretty straight forward.
Old 04-09-2012, 09:23 PM   #10
tractors1's Avatar
Trailer: Escape 21 - Felicity
Ground - use a meter
As long as you get the ground wire connected to the correct terminal, all will be well. Use a meter to make sure it's correct!
Old 04-09-2012, 09:59 PM   #11
bomni's Avatar
Will do! Got a voltmeter so not a problem.
Thanks!
Power inlet dimensions needed Raz Problem Solving | Owners Helping Owners 17 04-18-2015 04:34 AM
15 Amp power cord question.... Doug Mager Problem Solving | Owners Helping Owners 5 06-19-2011 01:50 PM
30 amp Power Cord francene Problem Solving | Owners Helping Owners 13 01-31-2010 07:50 AM
Fusing question for main power cord Parker Buckley Problem Solving | Owners Helping Owners 25 03-21-2009 07:55 PM
Power cord hatch/door Legacy Posts Electrical | Charging, Systems, Solar and Generators 11 10-17-2002 05:46 AM
