Preparing a 1991 Scamp 16 - Page 28 - Fiberglass RV
Old 09-05-2013, 02:05 PM   #541
honda03842's Avatar
Name: Norm and Ginny
AC Required
you have to be hooked up to 120v for these chargers to work, correct? If not hooked up you will still need the 12v adapter USB charger, correct?
That is true Jim, The outlets require AC to produce the USB's charging current.
We do have two ways to power our AC outlets from the battery. We have a rarely used 1200 Watt Inverter and a cigarette lighter/12 volt socket, 150 watt inverter. The 150 watt Inverter is frequently used every night we boondock. We also carry a secondary one in the car.
We often use the 150 watt Inverter to power our TV and Sat Receiver when boondocking. Assuming we shutoff the Convertor (never on when boondocking), electric hot water and Air Conditioner (never on when boondocking). we can easily power every outlet from the 150 watt Inverter and as a result power our USB ports, TV and Sat dish receiver.
The sum total of the Sat Reciever, TV and USB ports is well less than 150 watts.
Usually when we go to bed we unplug the 150 watt Inverter after we're done with TV. Of course one can not leave this Inverter plugged in powering all outlets and plug in a coffee pot for example or a hair dryer. it definitely takes some consciousness.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-07-2013, 11:44 AM   #542
honda03842's Avatar
Front Window Rubber Gasket
The front window gasket on our Scamp 16 is 22 years old and has been effected by age and sunlight. The inside rubber surface has yellowed dramatically. I purchased this small bottle to recoat th casket black. So far it's worked well. It has a built in applicator and worked well. It cost $14.
Amazon.com: Forever Black 4 oz. Dye Refill w/applicator top: Automotive
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-12-2013, 01:51 PM   #543
honda03842's Avatar
Spot light.
The spotlight arrived and is mounted to the screen door frame on the couch side.
It is only about 2-3 inches in diameter with an led bulb of the same diameter. MR16 bulb rated for 190 Lumens.
It is fully adjustable.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-12-2013, 03:01 PM   #544
Trailer: Scamp 16 Layout 4
Is that spotlight wired into the 12v or battery. Where did it come from, I'd be interested in at least 2.
By the way, I'm writing this from Sunset Point CG in Maine, thanks for the referral earlier this year
Ken
kenl is offline   Reply With Quote
Old 09-12-2013, 06:55 PM   #545
honda03842's Avatar
Spot Light
We bought the lamp on Amazon. Here's the link.
GoWISE USA GW21500 RV Reading Light MR16 Base LED Bulb 12v Satin Chrome : Amazon.com : Automotive
It is powered from 12 volts. I wired it to the 12 volts available at the lamp on the end of the closet. I run the wires along the back of the over the door shelf.
I like Sunset Point, my kind of place. We'll be stopping there again next year on our way to Newfoundland.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-13-2013, 12:47 PM   #546
honda03842's Avatar
Possible Tow Vehicle Tip
Our windshield wipers streaked a little in Newfoundland and were noisy. I bought a new set but before installing them I Rainexed the windows. Now no noise and smooth cleaning.
I think the Rainex reduces the window/rubber friction allowing the wipers to move more smoothly.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-13-2013, 01:55 PM   #547
honda03842's Avatar
Spot Light Performance.
Dark rainy day. Here's how the spot lights brightens the couch cozy corner.
Light on
Light off
On this rainy day working on installing a wireless rear view camera on the trailer. Plan to locate the wireless modules at the front of the trailer and the rear of the Honda to improve reception.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-15-2013, 09:13 PM   #548
honda03842's Avatar
Tyredog sensors
If you follow this thread you know we have temperature and pressure sensors on our trailer and rear tires of our Honda CRV. Since we have heard a lot of trailer tire concerns we decided monitoring the tires would be useful.
We have discovered that the trailer tires run cooler than the Honda's rear tires. As well we have yet to have any trailer tire problems. Maybe it's the watched pot never boils story....
This year one of our tire sensors failed. We ordered a replacement from the company and it arrived promptly. The clever monitor had a learn mode and found the new sensor and properly assigned it to the display. Still happy with the product.
I admit to not knowing if these are necessary or if they will allow us to detect a failing situation but I'm a person who likes information.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-28-2013, 11:29 AM   #549
honda03842's Avatar
Cabinet Locks
Installed a Philp-It cabinet lock. In our Scamp it requires drilling a hole in the front of the fiberglass.
Locked
Unlocked
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-29-2013, 02:35 AM   #550
Andrew Morris's Avatar
Trailer: Scamp 16'
I have heard great things about these Phlip-It latches and have just received ours in the mail. Phil, the owner of the company that makes these, was very friendly and helpful. I plan to install them over the next few weeks...
Norm - any other tips for installing them, or is it very straight forward?
Andrew
Andrew & Allison
Andrew Morris is offline   Reply With Quote
Old 09-29-2013, 06:20 AM   #551
honda03842's Avatar
Phlip-It Installation
Andrew,
I have 26 drawers and cabinets. I am not doing all of them. Some never open or have light items that can never force the drawer or cabinet door open. I have focused on those that have opened and have heavy items behind them.
The first time of doing anything is always a learning experience. First all my Cabinet doors are home made and thinner than the standard Scamp doors. You need to be sure not to drill the back of the door's screw hole thru the front of the cabinet door. I put a piece of tape on the drill bit like a flag to give me an idea of the depth of the hole. I'm sure there are drill stops available but I don't have one.
It was not possible for me to mount the latches at the bottom of the overhead cabinet doors so I mounted them on the side. You have to pay attention and make sure the screw hole is inside the cabinet opening or the screwhead will prevent the cabinet door from closing. Once the latch is mounted, you use it as a guide for the latching screw.
On a couple of occasions I moved the back of the door latch to get it right. You get no second chance with the front of the cabinet latching screw.
The front of the cabinet screw is the difficult part, at least in the fiberglass version. Dave who found this solution has an all wood, Scamp Deluxe. The suggestion is to use a 3/32nds drill for both screws. For the non-wood, fiberglass, I used a larger drill 7/64ths and even a 1/8th. The screw has to go into its shoulder and this is difficult to do in fiberglass and more difficult to do with out chipping. In the areas where the fiberglass cabinets is thin, i.e. like the middle of the overhed cabinets, it's not too bad getting the screws in. If it feels like it's binding stop, you can shear theses screws off. In these conditions I back the screw out and ream it or use a different screw.
Brian's suggestion of using stainless screws or the square head screws is a good one. I used one Canadain square head screw. ( I call them Canadian screws because it's the primary screw available in Canada and I buy some on every trip.) The difficulty is where you're installing a screw near a corner, the glass tends to be thicker. My toughest one was the utensil draw with the screw located at top center above the draw top.
The screw has to go far enough in so the drawer does not move when latched, usually about an 1/8th of an inch from the cabinet face. Make sure you have a good screwdriver for the brass screws that solidly sits in the head.
I haven't tried it but I considered lubricating the fiberglass screws with a little silicone spray. Fiberglass makes a verygood lock nut and these screws will not loosen. I have four more to do and will try lubing them.
Hope this helps
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-30-2013, 12:49 PM   #552
honda03842's Avatar
Cabinet Latch Update
The Philp It Cabinet Locks require putting a brass screw in the fiberglass fronts of the cabinet. After doing a dozen I found that a 9/64th inch drill bit allows the brass screws to go in easier and without chipping while still holding.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-30-2013, 06:28 PM   #553
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I wish they made them in nickel or something.
Old 10-03-2013, 11:15 AM   #554
honda03842's Avatar
Trailer Tongue Weigh In
The trailer's loaded for the road. Tongue weighs 185 lbs. Ginny will probably add another 10 just before we leave, her clothes go at the front.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-03-2013, 11:21 AM   #555
honda03842's Avatar
Food Storage Containers
We use 3 sizes of containers that nest. I made a tilted holder for all of them. My continuous attempt at organization.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-12-2013, 01:13 PM   #556
honda03842's Avatar
Camera.
We started our trip and the Scamp's rear camera works great, making for a dramatically more comfortable drive.
It occasionally partially breaks up but nothing significant.
A great $50 addition.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-13-2013, 11:06 AM   #557
Trailer: 89 Scamp 16 ft
Originally Posted by honda03842 View Post
Camera.
I'd love to see a picture or two of your camera setup when you have a minute. I'm a nervous passenger and I can imagine how much more comfortable the driver would be if I could just relax. ;0)
LUCINDA 1989 Bigfoot 5th Wheel | Steve, Rosemary, Maude Pod & Tripawd Hope
'Glass trips: Moab 03/10 * The Swell 5/26/11 * Antelope Island 12/21/11 * Strawberry Res 6/12 * Whitney Res 6/14 * Uintahs 7/15 * East Fork of Black's 6/16 * St Mary-Ennis-Lava 6/18
Steve and Rosemary is offline   Reply With Quote
Old 10-13-2013, 01:52 PM   #558
honda03842's Avatar
Steve and Rosemary,
I'll post pictures in the morning of our camera set up. Basically it consists of three parts. In the corner of the rear window is the camera, on the side away from the screen. I understand the camera is water proof but..... we decided to have it inside.
It has a wireless transmitter as a seperate module. It can be mounted right near the camera however we mounted our's near the Scamp's front window to shorten the wireless communication distance. I really should have tested it at mounting it near the rear window and did not. The transmitter is connected to the camera by a cable (bought seperately).
The thrid part is the display it sets on the top of our dash under the mirror. Below it is the wireless receiver.
The wireless receiver and the wireless transmitter are each the size of a box of tic tacks.
The hardest part of the installation is connecting the various elements to 12 volt power. FOrtunately nothing uses much power. In the trailer I connected the power wires to nearby lights. In the car I took power from the brake controller wires.
Pictures in the morning.
We noticed while driving into bright sun the display looked a little washed out. Fortunately it has a brightness control which resolved the issue.
Ginny is a vigilant passenger as well. I only make a lane change after notifying her an usually only with her permission. Age encourages teamwork. Safe travels.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-14-2013, 11:16 AM   #559
honda03842's Avatar
Steve and Rosemary.
Here are the pictures of our camera setup I promised last night.
Display sits dash center. The receiver is tywrapped to the column below.
Rear camera also can mount on licence plate. This is our rear window.
Transmitter in our front window
Display with vehicle behind us at stop light. Each line represents 7-8 feet placing this vehicle 21-25 feet or so behind us. It would normally be invisible with out extended mirrors.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 10-14-2013, 12:21 PM   #560
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
Norm: Couple of questions on your rear camera:
1. What brand is it(where did you find it)?
2. Is it always on, or just when backing? Most of the rear cameras I have seen are not for constant use.
(I did not go all through this thread-just back a few pages. So if I missed the info, I apologize)
Thanks
Dennis
Dennis Clinton is offline   Reply With Quote
1991 Scamp 16 ft Kevin K Referrals: Molded Fiberglass Trailers 0 04-14-2010 06:02 AM
1991 16' Scamp Kevin K Classified Archives 0 07-24-2009 05:54 AM
1991 13' Scamp Kevin K Classified Archives 0 06-11-2009 10:24 AM
article: Ford preparing 60mpg F150 Frank G. General Chat 3 03-19-2007 09:56 PM
Preparing to Paint Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-11-2003 04:37 PM
