Preparing a 1991 Scamp 16 - Page 31 - Fiberglass RV
Old 04-29-2013, 01:43 PM   #421
honda03842's Avatar
Name: Norm and Ginny
I just received 3 plastic boxes from RV Widget Works. One was custom made to hold our spices.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-29-2013, 01:52 PM   #422
honda03842's Avatar
1 minute later installation.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-29-2013, 04:49 PM   #423
Trailer: Scamp 16ft
Alabama
dang I can't even keep up with your additions even when I'm logged on. I'm using some of your ideas and mods.. If you haven't patented them.
Darrell in Al is offline   Reply With Quote
Old 04-30-2013, 12:09 PM   #424
honda03842's Avatar
Darrell, Glad you can use some of the mods.
Today mounted a second of the plastic boxes on the front bathroom wall. We will use it to carry misc things like bandaids, aspirin, .... the wooden shelf above is for bigger items like vitamins, ... and is full when we travel.
The bathroom contains 4 little baskets attached to the door frame. The back of the door, in addition to towels, has another plastic basket for soap dishes and soap storage. Under the towels are also two magazine racks.
As to the third container we're thinking of using it for banana storage. We usually have 3 or 4 bananas
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2013, 12:16 PM   #425
honda03842's Avatar
Propane tank holdown.
My propane tank was held down by two metal straps that ran from the tank's rim to the tongue's cross braces. The went thru the cross braces and were held in place with nuts located under the brace.
I replaced them with a ring like structure that sets between the two frame memers and is bolted to it.
This makes it much easier to remove the tank.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2013, 12:29 PM   #426
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm thinking about doing something similar on my trailer, but intend to place the loop much higher on the propane tank. That way there's some redundancy protection against the possibility of the tension nut loosening followed by the tank bouncing off the tongue.
Francesca
Old 04-30-2013, 12:40 PM   #427
honda03842's Avatar
Francesca,
This is a case of recycling. I took the propane tank holder off our former stick built trailer. We used it on our trip across Labrador with plenty of bumps and it stayed in place. If I was concerned I could add a stiff bungee cord.
I agree that if I were making one from scratch I'd raise the ring.
Actually with the nut removed I don't think the tank would come out.
In fact the reason for replacing the old dual strap method was we had a nut loosen and lost a strap, not to mention that the bottom nuts are a pain.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2013, 12:56 PM   #428
I've been mulling this over for awhile, and it keeps getting more complicated in my head, since part of what I want to do is add my version of a propane tank "gauge": essentially just an itty bitty one gallon cylinder and an auto-changeover setup that switches to the small tank when the big one goes dry. A gallon of propane will keep me going for several days- plenty of time to get the first one filled and start all over again! (Volume of baby tank easily monitored by use of a good ol' hanging fish scale)
The problem is how to carry/mount the second tank.
Since my battery is alongside the existing tank and the front "v" is otherwise occupied, my idea is to mount the baby cylinder above the battery. I've been speculating as to how to build a double loop holder that will accommodate that setup.
Francesca
And of course it all has to be absolutely weightless since I'm already mighty close to the limit for my setup!
Old 04-30-2013, 12:58 PM   #429
I would be more concerned about what happens if the trailer goes over on its side ... as we all know its happens, even to a few fine folks here. Would be worried about the tank popping off and bouncing down the road or hillside and a possible big bang as a result. Me thinks hearing the bang of the trailer going off the wheels would be more than enough for me without worrying about a second one.
Old 04-30-2013, 03:06 PM   #430
honda03842's Avatar
Francesca,
I carry an adapter that allows me to connect my standard Proprane regulator to a 1 lb tank. The adapters are available on Amazon.
We have only one tank and have this as a back up. The reality is that we've never run out. My hope is eventually to replace my steel tank with a fiberglass tank that allows one to see the propane level.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2013, 03:53 PM   #431
I already have the adapter setup. I've used it, too, when the main tank has gone dry. The problem I'm trying to circumvent is the necessity to "guesstimate" whether I'm nearly empty and should change to the full tank to avoid running out in the middle of the night or something.
There are only two ways to know for sure how "empty" the tank is:
1) by weighing it
and
2) by running it completely dry.
My theory is that by attaching the small cylinder to the autochangeover regulator, I'll know that the main tank is bone dry when it switches to the aux., which will supply me with sufficient reserve to get by for a couple of days.
It's a crude version of the "reserve" function on motorcycle gas tanks that have no gas gauges. Old VW bugs used a similar method.
Francesca
Old 04-30-2013, 04:41 PM   #432
honda03842's Avatar
Carol,
I went out side and tried to pull the propane tank out of it's holder. It simply doesn't move in any way.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 04-30-2013, 06:21 PM   #433
Trailer: Scamp 13 ft
Eastern Ontario
Francesca
Check out these Hammerhead Tank Gauges at amazon
Amazon.com: Removable Accu-Level Propane Tank Gauge with Magnetic back: Kitchen & Dining
I use them and they are accurate and inexpensive.
Sandy C.
Sandy Christie is offline   Reply With Quote
Old 04-30-2013, 06:23 PM   #434
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Sandy Christie View Post
Francesca
Sandy C.
YMMV
1991 Scamp 16 ft Kevin K Referrals: Molded Fiberglass Trailers 0 04-14-2010 06:02 AM
1991 16' Scamp Kevin K Classified Archives 0 07-24-2009 05:54 AM
1991 13' Scamp Kevin K Classified Archives 0 06-11-2009 10:24 AM
article: Ford preparing 60mpg F150 Frank G. General Chat 3 03-19-2007 09:56 PM
Preparing to Paint Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-11-2003 04:37 PM
