Preparing a 1991 Scamp 16 - Page 39 - Fiberglass RV
Old 09-03-2013, 07:22 PM   #533
honda03842's Avatar
Name: Norm and Ginny
Ken and Sharon,
I went to the site and also found it gone. I'll do a more intensive search in the morning.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-04-2013, 06:42 AM   #534
honda03842's Avatar
Ken and Sharon,
I have no experience with the following company though their panels seem similar and less expensive.
semi-flexible solar panel - eco-worthy solar panel online shop
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-04-2013, 04:32 PM   #535
honda03842's Avatar
AC/USB OUTLETS
I'm installing 3 of these outlets, one in the front corner of each dinette.
Began by outlining the hole with blue tape to guide and protect.
The outlet box has wings that tighten against the back side of the fiberglass when front screws are tightened. One wing standing up in picture.
The outlet is larger than a normal outlet but easily fits in the box. Shown with a normal outlet.
Finished product.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-04-2013, 05:09 PM   #536
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Luxurious Norm! Good call on the install.
D Davis is offline   Reply With Quote
Old 09-04-2013, 05:16 PM   #537
honda03842's Avatar
Left out one picture.
As well I've used it to charge my Nook.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-04-2013, 06:34 PM   #538
Andrew Morris's Avatar
Trailer: Scamp 16'
Flexible Solar Panels
Originally Posted by honda03842 View Post
Ken and Sharon,
I too have followed much of Norm's advise and installation ideas, with great satisfaction!
Earlier this year I installed 2 x 50 watt flexible solar panels (I chose 2 panels wired in parallel, rather than a single 100 watt panel in order to have better performance in partial shade). The original company that Norm purchased from is out of business, I called them earlier this year and the previous owner confirmed they are no longer deal in solar. The panels that I ended up purchasing are flexible monocrystalline ones from Discount Solar (Semi-Flexible 50 Watt Solar Panel 12V High Efficiency Sunpower), purchased through their eBay store:
discountsolar | eBay
They have performed flawlessly, in combination with a Morningstar Tristar-45 charge controller (Morningstar Corporation Ľ TriStar)
It is basically the same style install as the one done by Norm. You can see some pictures in my registry.
Andrew
Andrew & Allison
Andrew Morris is offline   Reply With Quote
Old 09-05-2013, 11:56 AM   #539
honda03842's Avatar
Thanks Andrew.
I installed the last two outlets. The second in the water tank dinette and the third in the end of the stove side counter. The stove side outlet was a 22 year old original and too small so I replaced it with a blue box.
Corner of dinette
End of stove counter with Nook Charging. Actually fully charged the Nook last night. Found it also charges our 7" Samsung pad as well.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-05-2013, 11:59 AM   #540
cpaharley2008's Avatar
you have to be hooked up to 120v for these chargers to work, correct? If not hooked up you will still need the 12v adapter USB charger, correct?
Jim
Never in doubt, often wrong
Old 09-05-2013, 02:05 PM   #541
honda03842's Avatar
AC Required
That is true Jim, The outlets require AC to produce the USB's charging current.
We do have two ways to power our AC outlets from the battery. We have a rarely used 1200 Watt Inverter and a cigarette lighter/12 volt socket, 150 watt inverter. The 150 watt Inverter is frequently used every night we boondock. We also carry a secondary one in the car.
We often use the 150 watt Inverter to power our TV and Sat Receiver when boondocking. Assuming we shutoff the Convertor (never on when boondocking), electric hot water and Air Conditioner (never on when boondocking). we can easily power every outlet from the 150 watt Inverter and as a result power our USB ports, TV and Sat dish receiver.
The sum total of the Sat Reciever, TV and USB ports is well less than 150 watts.
Usually when we go to bed we unplug the 150 watt Inverter after we're done with TV. Of course one can not leave this Inverter plugged in powering all outlets and plug in a coffee pot for example or a hair dryer. it definitely takes some consciousness.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-07-2013, 11:44 AM   #542
honda03842's Avatar
Front Window Rubber Gasket
The front window gasket on our Scamp 16 is 22 years old and has been effected by age and sunlight. The inside rubber surface has yellowed dramatically. I purchased this small bottle to recoat th casket black. So far it's worked well. It has a built in applicator and worked well. It cost $14.
Amazon.com: Forever Black 4 oz. Dye Refill w/applicator top: Automotive
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-12-2013, 01:51 PM   #543
honda03842's Avatar
Spot light.
The spotlight arrived and is mounted to the screen door frame on the couch side.
It is only about 2-3 inches in diameter with an led bulb of the same diameter. MR16 bulb rated for 190 Lumens.
It is fully adjustable.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-12-2013, 03:01 PM   #544
Trailer: Scamp 16 Layout 4
Is that spotlight wired into the 12v or battery. Where did it come from, I'd be interested in at least 2.
By the way, I'm writing this from Sunset Point CG in Maine, thanks for the referral earlier this year
Ken
kenl is offline   Reply With Quote
Old 09-12-2013, 06:55 PM   #545
honda03842's Avatar
Spot Light
We bought the lamp on Amazon. Here's the link.
GoWISE USA GW21500 RV Reading Light MR16 Base LED Bulb 12v Satin Chrome : Amazon.com : Automotive
It is powered from 12 volts. I wired it to the 12 volts available at the lamp on the end of the closet. I run the wires along the back of the over the door shelf.
I like Sunset Point, my kind of place. We'll be stopping there again next year on our way to Newfoundland.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 09-13-2013, 12:47 PM   #546
honda03842's Avatar
Possible Tow Vehicle Tip
Our windshield wipers streaked a little in Newfoundland and were noisy. I bought a new set but before installing them I Rainexed the windows. Now no noise and smooth cleaning.
I think the Rainex reduces the window/rubber friction allowing the wipers to move more smoothly.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
1991 Scamp 16 ft Kevin K Referrals: Molded Fiberglass Trailers 0 04-14-2010 06:02 AM
1991 16' Scamp Kevin K Classified Archives 0 07-24-2009 05:54 AM
1991 13' Scamp Kevin K Classified Archives 0 06-11-2009 10:24 AM
article: Ford preparing 60mpg F150 Frank G. General Chat 3 03-19-2007 09:56 PM
Preparing to Paint Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-11-2003 04:37 PM
