Preparing a 1991 Scamp 16 - Page 43 - Fiberglass RV
Old 12-26-2013, 03:23 PM   #589
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Originally Posted by Scamper Jim View Post
If I understand correctly, from there you connect a male 7-way plug wire running to the camper.
The trailer end (pigtail) of the typical 7-wire is female; the male connection is on the tow vehicle.
I for one have never taken any special precautions to prevent contact with the hot wire in/on the trailer end plug when it's disconnected from the tug.
Old 12-26-2013, 03:24 PM   #590
cpaharley2008's Avatar
You can always store your plug in a safe environment as this Amazon.com: Plug Guard - 7 Way: Automotive
Jim
Never in doubt, often wrong
Old 12-26-2013, 03:33 PM   #591
I pulled a latex glove over mine, and used an elastic band to secure it.
Two weeks later, I thought the glove looked peculiar.
It was full of water.
Old 12-26-2013, 05:11 PM   #592
honda03842's Avatar
Name: Norm and Ginny
Interesting question. I don't remember but will look in the morning
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-26-2013, 06:03 PM   #593
honda03842's Avatar
I believe I did not use the auxiliary center pin but instead wired it to the plus battery terminal of the trailer's 7 pin connector. Hence the two batteries are virtually in parallel, neglecting the tow vehicle's battery switch and the in line fuse.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-26-2013, 06:31 PM   #594
Borrego Dave's Avatar
Trailer: Casita SD17 2006
You have that backwards Francesca, the female end is always on the TV no matter what type / style or number of pins a connector has. That is unless someone decided they thought it would be better backwards than industry standard.
Old 12-26-2013, 06:39 PM   #595
Dave.
You better go out and look at your trailer harness.
Old 12-26-2013, 07:20 PM   #596
Originally Posted by Glenn Baglo View Post
Dave.
Hi Glenn, the picture you sent is indeed the trailer end and is a male fitting.
Old 12-26-2013, 07:57 PM   #597
You never had that talk with your dad?
Old 12-26-2013, 08:04 PM   #598
OMG, my eyes are leaking and here... all along.. I thought most folks on the forums were ADULTS!
Old 12-26-2013, 10:51 PM   #599
But...this car-end one has WAY more sticky-outies. Isn't that a sign of "maleness" in the plug world?''
Old 12-26-2013, 11:07 PM   #600
Ahhh, no, the pins or tabs make no difference to the male / female nomenclature. It is each end of connection and how they work together that give its name. It is the same way plumbing fittings get their names for use of applications.
Old 12-26-2013, 11:18 PM   #601
I thought ( think ) it is the contacts that are male and female, thus the trailer side would be female - a harem in fact.
Old 12-26-2013, 11:46 PM   #602
Further to my argument, the vehicle side has a plug that is inside a shroud, and thus must be male. The shroud isn't necessary to the plug.
From Wiki, the U.S. military definition:
Characteristics
Connectors usually consist of (i) a mating pair (plug and receptacle) each equipped with male (pin) or female (socket) contacts; note that at least one of the connector halves, or its contacts, should be floating to minimize mechanical stresses.[2]
So, it's the contacts that determine if the plug is male or female.
1991 Scamp 16 ft Kevin K Referrals: Molded Fiberglass Trailers 0 04-14-2010 06:02 AM
1991 16' Scamp Kevin K Classified Archives 0 07-24-2009 05:54 AM
1991 13' Scamp Kevin K Classified Archives 0 06-11-2009 10:24 AM
article: Ford preparing 60mpg F150 Frank G. General Chat 3 03-19-2007 09:56 PM
Preparing to Paint Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-11-2003 04:37 PM
