Propane Tank Level Gauge -- Anyone know of a good one? - Page 3 - Fiberglass RV
Old 04-18-2014, 09:03 PM   #29
Gotta find your humour where you can.
Interesting that people bought these three items.
Old 04-18-2014, 09:20 PM   #30
Originally Posted by Night Sailor View Post
I second that. I had two of these, and plan to eBay them. Anyone want to buy them?
I was unable to use my full tank to run my furnace. It would act like it was empty when there was still 8 lbs or more of propane in the tank.
Thats intreating as well. My furnace doesnt seem to have any issues with it on. What furnace are you running? wondering if the regulator on your tanks is perhaps set a bit lower than the on mine.
Old 04-19-2014, 04:32 AM   #31
Raz
Raz's Avatar
Vermont
The pressure in the tank varies with temperature making any type of pressure gauge useless (ideal gas law?). I've used the "hot water down the side and feel the temperature" trick as a rough guide. When I think it's getting low, I look for a Tractor supply with a propane station. They meter the propane and their prices are reasonable. Raz
Propane Tank Refills at Tractor Supply Co.
Old 04-19-2014, 08:07 AM   #32
Mike Magee's Avatar
Trailer: Li'l Hauley
We have tried pretty much every device and method available and found only two which are pretty reliable....
1] Buy a tank with an internal float gauge. These are fairly accurate and the ones I have seen usually have a little reserve when they reach empty.
the drawback with this choice is that you can't do exchange.
2] Remove the tank before a trip and weigh it on a bathroom scale.
18 pounds is empty,38 pounds is full. Estimate the need for the trip and switch tanks if necessary before leaving.
Using the weighing method requires the purchase of a second tank to get full use of the propane. We have a grill at home on which we use only "near empty" tanks. This second tank can be filled before a trip if there is not adequate supply in the trailer tank.
I vote this as the best answer. The bathroom scale works great. If it's too much trouble to take out the tank for weighing, get a tank with internal float gauge. I bought such a tank last October at Sam's Club (less than $40 IIRC) and I expect I'll enjoy using it this summer.
How to prepare Tofu
Step 2: grill some meat
Old 04-19-2014, 08:53 AM   #33
Keep in mind that the "Exchange Tank" system is about the most expensive way to buy LP gas. I have seen it as much as 3X propane dealer price.
I'll stick with the Stick-on strip and hot water, about $3, works every time.
Old 04-19-2014, 09:47 AM   #34
MCDenny's Avatar
Trailer: Lil Snoozy
I keep a few one pound green propane bottles to run the weber grill and have an adapter that let's them be connected to the furnace propane line.
When the 20# runs out I can run the furnace approx one night on a one pound bottle. And I know it's time to refill the 20#.
MCDenny is offline   Reply With Quote
Old 04-19-2014, 10:08 AM   #35
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Do you have any info on the adaptor for the 1 lb tank to the furnace line?
Dave & Paula
Old 04-19-2014, 10:25 AM   #36
Dave & Paula
I have one as well, - it allows me to switch from using a large 20lb tank to the small green disposable tanks for the portable stove or BQ if need be. Sorry no picture of it but i picked it up at a local hardware store. Should be pretty easy to find one at any shop that sells BQ's.
Old 04-19-2014, 12:15 PM   #37
papa-t's Avatar
Glade Valley, North Carolina
Originally Posted by Gina D. View Post
Having two tanks helps, yes. Not everyone has two though.
I use Jons method, and the palm of my hand. You can feel the temperature change by palming the side of the tank and running it down until you feel the temp change to MUCH colder.
It doesn't need to be overly accurate, but it does give you an idea on where your liquid level is.
I have the pour the hot water thingy stuck on mine too, but I generally have only used it when the outside temp is so low that it's hard to feel the difference on the tank. The smell method is a giveaway that I have maybe 2 days of normal use left.
My bad. I was assuming we were talking about two tanks.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 04-19-2014, 04:19 PM   #38
MCDenny's Avatar
Trailer: Lil Snoozy
Dave & Paula
http://www.amazon.com/gp/aw/d/B00480BWA0
Old 04-19-2014, 04:53 PM   #39
David B.'s Avatar
Trailer: Lil Snoozy
Thank you..... just ordered it.
Dave & Paula
Old 04-19-2014, 05:14 PM   #40
Gina D.'s Avatar
West Coast USA
papa..you aint bad! The OP does have two tanks.
You may be Bad in a Good way though!
Old 04-20-2014, 08:07 AM   #41
I'm not being a Chicken Little, but want to caution folks that use a steak saver to refill the small green bottles from a 20# tank. The little bottles are not designed to be refilled. Remember, just because you can, doesn't mean you should.
I have friends that almost lost their monster 5th wheel due to a refilled cannister that was in the basement of their 5er. If you do this, be very careful where you "store" the refilled cannister. I'd suggest outside!
Old 04-20-2014, 08:39 AM   #42
IllAnnoy
Some time ago someone reported that they kept refilled one pound cylinders in their square tube bumper! Whether prudent or not, it sure made for some hilarious mental images!
propane
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
does anyone know how much an empty propane tank costs? lpk49 Modifications, Alterations and Updates 13 04-26-2013 09:57 AM
For Sale: stabilizers(2),fiberglass propane tank/gauge kit-$225 cpaharley2008 Parts: Buy | Sell | Trade 6 09-30-2012 04:11 AM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 32 12-23-2005 10:57 AM
