Propane Tank Plug - Fiberglass RV
Old 06-11-2015, 07:54 AM   #1
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Propane Tank Plug
For those without enough to worry about I can contribute the following:
I sometimes transport a LPG cylinder in addition to the two 20 pounders at the front of my trailer. Obviously I make sure to firmly close the valve before stashing it inside my tow vehicle (not a ďpick-em-upĒ). As a sort of belts-and-suspenders kind of guy, I made up an additional safeguard consisting of a replacement Acme threaded handle with a ľ NPT cap screwed on it so I could double-seal (if you will) the tank outlet. I didnít want to travel in a cloud of leaked propane in the car just waiting for a spark to enliven a spectatorís day or to make my own contribution to the Darwin Awards. (Darwin Awards. Chlorinating The Gene Pool.)
The other day I spotted the following purpose built plugs that fill the left-hand threaded internal outlet and at less than $2 each Iíve upgraded (I think) my transportation safety.
http://www.americanhardwaremfg.com/content/product_page_template.php?dept=rv&cat=propane&subc at=all_products
Theyíre red now, not yellow and the tag is different but those are superficial differences.
Now that Iíve found these I expect to see dozens of other designs. It figures. Anyhow, they seem vaguely useful so I'm pointing them out. I'm making no claims as to whether they're necessary. Just that they tickeled my gadget DNA.
Quando omni flunkus, moritati
Old 06-11-2015, 09:26 AM   #2
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Looks like a useful gadget Steve. It might be a good idea for those of us who commonly carry an extra tank, like the 5 pounder I use for cooking appliances.
I hate the idea of paying $9 shipping for a $2 item, but if I ever run across one retail I'll probably buy it.
Walt
Old 06-11-2015, 10:59 AM   #3
SteveV's Avatar
Trailer: Amerigo FG-16
Check with your local propane supplier. The local place that I take my 100lb tanks to for refill gives them to you if you don't have one.
SteveV is online now   Reply With Quote
Old 06-11-2015, 01:20 PM   #4
Trailer: 1978 Trillium 4500
Ohere are the Canadian guidelines for propane transportation
OOPEN VEHICLE
In an open vehicle, transport your cylinder in an
upright position and secured so the label displayed on
the cylinder is visible from outside the vehicle.
ENCLOSED VEHICLE
In an enclosed vehicle, cylinders must be transported
upright and secured. In a passenger vehicle, it must
be secured upright on the rear floor with the window
open or in the trunk inside a tote box and with the
trunk partially open to ensure proper ventilation. Y
our
cylinder retailer will have a latch for this purpose.
Either make a special trip to have your propane
cylinders refilled or make it the last stop on your
shopping route. It's never good to leave cylinders
sitting for long periods of time in your vehicle.
Personal exemption permits you to transport propane
cylinders for your personal use between the place of
fill and your home.
NO MORE THAN FIVE
The maximum number of cylinders that can be
transported is five.
In open vehicles, as long as the total combined mass
of the propane & cylinders does not exceed 500 kg.
In enclosed vehicles, the maximum number of
cylinders that can be transported is five, as long as
each individual cylinder weighs a total of less 30 kgs.
(66 lbs). A
full, typical barbeque cylinder weighs
approximately 17 kg (34.5 lbs).
If the limits are exceeded in either open or enclosed
vehicles, your vehicle must be placarded as per the
placard requirements, carry the appropriate
supporting documentation and the people operating
the vehicle must be appropriately trained.
Island Bolers and Friends on Facebook
Island Claire is offline   Reply With Quote
Old 06-11-2015, 02:53 PM   #5
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
If you can't get a free one locally, Amazon has them:
Ush Pol Plug W/Strap
$1.34 + $2.98 shipping
Robot Check
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 06-11-2015, 03:02 PM   #6
WaltP's Avatar
SW Virginia
Nice find Steve, thanks.
Walt
Old 06-15-2015, 12:39 PM   #7
Trailer: Burro
Massachusetts
Hi Steve,
Please keep in mind that it is not the valve at the regulator attachment point that you are worried about. Those seal quite safely. It is the pressure relief valve that you should be concerned with. This will automatically expel some propane gas if the pressure in the tank rises due to a temperature increase, which is easy to achieve in a hot car or trunk. It is because of this that there are so many regulations about transporting tanks in an unventillated space.
Rick.
rick.a is offline   Reply With Quote
Old 06-15-2015, 12:51 PM   #8
SteveV's Avatar
....also I think they are intended more to keep dirt/bugs out of the threads & valve while in transport or storage. We have mud daubers around here that like to build a nest about anywhere!
Old 06-15-2015, 01:01 PM   #9
Steve L.'s Avatar
Originally Posted by rick.a View Post
Hi Steve,
Please keep in mind that it is not the valve at the regulator attachment point that you are worried about. Those seal quite safely. It is the pressure relief valve that you should be concerned with. This will automatically expel some propane gas if the pressure in the tank rises due to a temperature increase, which is easy to achieve in a hot car or trunk...
Rick.
Excellent point and one I hadn't considered. Arghhh.
Old 06-15-2015, 02:21 PM   #10
Borrego Dave's Avatar
Trailer: Casita SD17 2006
If you do loose the threaded plug, a 1"pvc slip end cap fits over the end nicely to keep bugs out also.
Old 06-15-2015, 03:03 PM   #11
Carl Pa's Avatar
Although it would be nice to take along a extra tank, however, why load the weight,space and danger , when you can exchange a tank almost anywhere. Just a thought. Carl
Carl Pa is offline   Reply With Quote
Old 06-15-2015, 03:15 PM   #12
I have two 20 lb. tanks with automatic changeover. You don't want to head out at 2am to look for a propane supplier so that you have fuel for the furnace, especially when it's an hour drive on a gravel road just to get to the nearest town.
I also have a 10 lb. tank that runs my BBQ.
Old 06-15-2015, 03:15 PM   #13
WaltP's Avatar
SW Virginia
Carl
A lot of us prefer not to use the exchanges. We have our own tanks and refill them at propane dealers. I carry a 5lb tank for my stoves and other outdoor appliances.
Walt
Old 06-15-2015, 06:14 PM   #14
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
That plug is a good find.
What LP prices do you folks see in your areas these days? I jut got two 20# refills for $9 each, at the West Lebanon, NH Farm Supply and Feed store. Very happy about that price.
propane
frozen hot water tank drain plug mmiller4 Problem Solving | Owners Helping Owners 15 05-10-2015 03:12 PM
2004 Trillium Outback Drain Plug for Water Tank? BarbinBC Problem Solving | Owners Helping Owners 5 09-08-2013 06:41 PM
Propane usage (T off the trailer tank or take a spare tank) knighth001 Problem Solving | Owners Helping Owners 13 09-20-2012 06:37 AM
Disconnecting propane fridge; plug size? Barrie Bochoff Problem Solving | Owners Helping Owners 11 03-19-2011 04:33 PM
wiring harness plug in Legacy Posts Problem Solving | Owners Helping Owners 3 12-16-2002 12:04 PM
