Pros and cons of a very small 3-way refer - Fiberglass RV
Old 03-02-2012, 01:33 PM   #1
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Seeking opinion on the realtime utility of a very small 3-way and the advisability of replacing with 120VAC dorm fridge.
I have a Burro 17" with a late 90s era Dometic 2202. I have "gone back and forth" on the advisability of giving the darn thing away several times. It works and it doesn't. Will cool down and then warm up on 120VAC even when the ambient temp. is in the winter range. I suspect that coils are not plugged and that this may simply be a thermostat malfunction. Were this little gem working perfectly (which would definitely require cleaning the propane orifice and chimney), I believe the installation is barebones inadequate and that baffling and forced air (muffin fans) in the "chimney" outbd of the cooling unit would be necessary to maintain efficient cooling. And it is sooooo small inside!
I have an electric dorm fridge which will fit in the space under the gas range currently occupied by the Dometic. There is adequate top and side clearance and I think with this unit a muffin fan outbd the compressor for positive air replacement in a closed space would also be a good idea. On the grid it would, I think, be of much more real value for ice-making and food preservation than the Dometic. I also have a Coleman upright ice chest which served for a lot of yrs. of tent and pickup cap camping. That would possibly be better than the Dometic at its functional best but does require the bother of buying ice, draining. I would not even comtemplate an under-counter install of this as it rides quite nicely in the head on the road. I could easily take both to cover possibility of on/off grid stops but I can't deal with taking both (dorm fridge under the front dinette table) and the Dometic.
I know there's an impact on resale (if you have a 3-way, your buyer du jour will want an electric fridge and if you have an electric, he'll want a 3-way LOL) but I'm beginning to think box stock just doesn't matter that much to me. I bought the trailer ten yrs. down the long and winding road, don't have that much in it, am thankful EVERYTHING ELSE works, and with gas prices what they are, the premium is really on the 13 footers.
All I have to do is cut the "kick" area of the glass cntrtop facade in the area of the fridge opening, secure the fridge, fabricate a reasonably sightly reveal to make up any discrepancy in the old and new opening.
My questions: 1) What am I waiting for? (as I'm out of patience with the idea of "fixing" the inadequate Dometic). 2) If you have done this, how well do you deal with on/off grid situation and how? 3) If you've done this, are you satisified or having second thoughts? 4) If you've done this, any advice on the install? For instance, would I need any sort of shock suppression mat under the compressor fridge? Would insulation between the bottom of the gas range and the top of fridge) be advisable?
There could be some pro or con I've overlooked? Please someone push me one way or the other out of my vacillation over this inadequate fridge!!
jack
Old 03-02-2012, 01:59 PM   #2
Trailer: Lil Snoozy / Jeep Cherokee
Dorm type Frige
I have been asking myself similar questions regarding dorm type refrigerators.
I figured a cooler will suffice when off grid and limit foods to mostly those not requiring refrigeration. I can usually get by with cold beer and half & half for my coffee.
My question has been : If you have a dorm type frige and you cool it prior to leaving home, put items in it that have been prechilled, and put some containers (ie. plastic gallon jugs) filled with frozen water on top, will this frige keep things cold just as a camp cooler would?
In addition to hearing the answer to the question as posted in the thread, perhaps someone will have experience with this method of keeping food safe and be able to expand to include this information in their answer.
Bill in Pittsburgh is offline   Reply With Quote
Old 03-02-2012, 02:07 PM   #3
Raz
Raz's Avatar
Vermont
Do you boon dock? Then the old fridge or an ice box is best. Camp where there is always power. Then the dorm fridge will fit your needs. As far as resale is concerned it is what it is either way, a rare 17' Burro and they ain't making them anymore.
We seldom use hook ups. So when we stay put for a while I like the small 3 way fridge. But, if my fridge dies I will have to think long and hard before I replace it considering what they cost and I bring the ice chest anyway. Raz
Old 03-02-2012, 02:12 PM   #4
North Dakota
If you are keeping the camper don't worry about it. Do what's best for you. I have a 12V cooler that I keep in my TB that i also have a AC plug for that I use for extra cool space too. You can even get freezers like that. I've seen them on Ebay. New they're kind of pricey.
Gene Masse is offline   Reply With Quote
Old 03-02-2012, 03:44 PM   #5
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
How about if you install the 110v dorm fridge but add extra insulation so you can use it as an icebox when no AC power is available?
Not sure what your packaging is like, but in my UHaul there is lots of space around the icebox for added insulation.
Old 03-02-2012, 04:06 PM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
I had a dorm fridge in my Burro, and I used a Coleman ice chest. The fridge wouldn't keep stuff cool for more than 3 hours during travel.
My current LP/120v 2way keeps blowing out while driving. Grrrr.
I think my next fridge will be a high efficiency 12v unit, and about 150 watts of solar cells to go with it.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 03-02-2012, 04:17 PM   #7
honda03842's Avatar
Name: Norm and Ginny
AC Fridge
Our first trailer's 3 way failed and we replaced it with a 4 cubic foot dorm style fridge. It always kept things cold.
We typically would let it get a little colder than normal before hitting the road so we could drive with it un powered and still have things cold, typically around 3-4 hours.
We also had a 1200 watt inverter, $59 at Black and Decker outlet, and would turn that on on hot days. We could run about eight hours on a typical hot day before discharging our type 24 battery.
As well at various times we had the ability to charge the battery as we drove or had solar panels.
It worked great and had a bigger interior volume.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-02-2012, 04:56 PM   #8
rabbit's Avatar
Delaware
The voice of been there, done that saves a lot of pain! Thanks for all the suggestions. I certainly have room for insulation--batt, blue bd., Reflectix. I was mainly thinking of insulating the heat transfer from operation of the gas range. Assuming that the insulation in the Black & Decker dorm fridge is minimal, I'm convinced swaddling it in more can't hurt. Thinking maybe a slab or two of that jigsaw ice rink flooring under the feet couldn't hurt to damp road shock to the compressor? I have a 120 volt muffin fan so I think that's another simple plug-n-play for air exchange in the rear and I certainly won't need it state park camping. I also have an inverter so perhaps I could run the electric fridge on the move; in the deficit column I have a starting batt rather than deep cycle so I guess I can plan on an expenditure there. I do have 80 watts of solar and that can't hurt with the battery/inverter equation altho mine's a tether-to-graze rather than a fixed rooftop so no running on the road. Thank you all so much for the kick in the rear! Funny all the things I've rushed into inadvisedly and others where I vacillate forever. Devil loves a coward.
I had time this afternoon to do some checking on dimensions. Functionally and cosmetically, the rough opening for the Dometic is spot on for the dorm fridge. I may be able to elevate the replacement a bit with a platform to avoid cutting away the kick completely. This might preserve some of the structural integrity of the molded counter/facade and will assure that the B&D door opens over all the floor mats we use in the trailer. Guess the first step is to get the Divine Miss D out of there. I don't foresee any complication there except capping the gas line. Shouldn't be more than three trips to the TruValue.
jack
Old 03-02-2012, 05:06 PM   #9
Thomas G.'s Avatar
Originally Posted by rabbit View Post
.......... I may be able to elevate the replacement a bit with a platform to avoid cutting away the kick completely. This might preserve some of the structural integrity of the molded counter/facade and will assure that the B&D door opens over all the floor mats we use in the trailer. ..............
jack
I will be replacing my icebox with a 3 way fridge and I plan to build up a platform for it to sit on from rigid foam. This eliminates carving up the front panel and also adds insulation on the bottom. I plan to use the same foam on the top and sides, as I have the space and the foam weighs nothing.
Old 03-02-2012, 05:32 PM   #10
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Here is a link to Don Dayton's project to run his Casita frig on AC from his tow vehicle while on the road. He found this worked better than 12V DC or propane. I don't know what the current draw of a dorm frig is, but this might also work for your application.
Fridge, ac power from tow vehicle - a set on Flickr
Old 03-02-2012, 08:13 PM   #11
My old 3-way, which is original in a nearly 24 year old trailer keeps humming along. What works for me, is to use the refer to store food.. I only open it 2-3 times a day. Beverages go into a cooler... which has the lid lifted MANY times a day. Refer stays at temperature and the cooler works as it should. YMMV
Old 03-02-2012, 09:16 PM   #12
honda03842's Avatar
Jack, I also put some foam insulation in the spaces around the fridge, no sense keeping air in there. I used riht angle brackets at the rear to keep it from moving about and braced it on it's sides.
I also mounted a muffin fan in the rear and added a couple of heat sinks to the top of the compressor. Not sure it did anything.
The ability to charge the trailer battery from the tow vehicle is worthwhile. We have that ability though not used with solar panels now. The 1989 Scamp being sold on this site has a huge cable (big wire) to do that for his electric fridge. Actually he has a rather large one in his Scamp. It seems that most of the compressors are the same unit in all these fridges.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-02-2012, 09:18 PM   #13
rabbit's Avatar
Delaware
What temperature would that be Donna. 3 below ambient?
jack
Old 03-02-2012, 09:24 PM   #14
Actually Jack, closer to 40 degrees below ambient. I also have a refer fan inside and closely monitor the frig temp with an indoor/outdoor thermometer (outdoor sensor inside the frig). The secret is to only open the refer door when necessary (like three times a day) when fixing food for eating... not to drink bottled water or other "bottled" or canned beverage
Old 03-03-2012, 01:54 PM   #15
rabbit's Avatar
Delaware
Dometic is out; gas line plugged. Looks pretty easy; only need to cut glass down to the kick flange about 3 1/2" above floor. Have to build a platform and also another platform for the water pump further aft as that and the original stand for the Dometic are 3/4" melamine board drywall screwed together and bonded to the floor of trailer with body filler and they deteriorated from moisture. Incidentally, this old trick of bonding wood to cured fiberglass with filled polyester resin (body filler) works really well; way I attached the ledgers for a new shelf in my hanging locker. Bout like buttering up bricks and you just scroosh it in place and hold til cured. Escondido Burro is out of business but cheap as they were they weren't wrong about that.
jack
Old 03-03-2012, 11:23 PM   #16
Mike Magee's Avatar
Yep, fill in as much insulation as will fit; that will help you.
Old 03-04-2012, 10:41 AM   #17
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Dorm Fridges! Caution!
Be aware that MANY dorm fridges use the outside walls for the condenser coils to vent the heat! My cheapy basement Danby Bar unit is such a beast. The sides get warm when it's running. Insulating them would be a BIG problem. If it has exterior cooling coils or uses forced air cooling, then you probably could insulate the walls on the outside.
And for Nancy from Quebec I can say that a Koolatron is NOT a fridge - it only cools and in hot weather will not hold proper fridge temperatures - good for drinks but not for meats and such.
I like and use the 2 way evaporative units (3 way units, on 12V, use a lot of power and rarely cool as well as propane or 110VAC).
Good luck.
Mike .....>
Michael Pupeza is offline   Reply With Quote
Old 03-04-2012, 11:27 AM   #18
Beverage cooler
We use the refrigerator for food and like Donna only open the fridge 2 or 3 times a day . We store water ,pop, and beer in a cooler we keep in the shade. We freeze plastic jugs filled with water for the cooler . We keep one in the freezer and one in the cooler and rotate the jugs in the morning and in the evening between the freezer and the cooler. I'm cheap and object to buying bags of cube ice which melts in a couple hours and Cost $4.00 ea
Old 03-04-2012, 04:23 PM   #19
Trailer: Winnebago
Iowa
Just a sugestion, how about adding a Honda generator to your trailer
Laura June is offline   Reply With Quote
Old 03-18-2012, 04:30 PM   #20
rabbit's Avatar
Delaware
Still workin on it. New platform for water pump and hot water tank is in; 120VAC muffin fan on a strut is in behind the upper vent. I had a duplex receptacle in there with the old "3-Way" or NO WAY as I call it and the TV signal booster transformer plugged in. I needed a third receptacle for the muffin fan and thought about putting in a quad box but today I decided one of those 3$ "six for two" receptacle adapters form the hdware would serve as well. Cleaned up some wiring in there and got the fridge platform square to the cabinet wall. Taped up a poly dropcloth between the head and the aft berth and the galley to avoid contaminating everything with the "itchies" from cutting a larger opening in the counter front. Fridge probably in some day this week. Try it out at Killens Pond near Dover Del around Easter. Thinking about that 1200 watt inverter; the starter battery I'm using right now won't support it but sooner or later I'll get a deep cycle 24 or 27. Incidentally, I've read at least fifty times here and there that batteries kept on converter in winter lose water from cells really fast. Funny, mine's been on converter all winter, showing 13.65 volts and doesn't appear to have gassed at all. Maybe the looksee every month helps?
jack
Pros and Cons Alan Ursacki General Chat 11 10-01-2011 05:18 PM
Atwood Everest Star 7912 Furance = pros and cons Kurt in BC Modifications, Alterations and Updates 10 02-18-2008 12:05 AM
Pros and Cons of fiberglass and Casitas Paris Winchell Care and Feeding of Molded Fiberglass Trailers 3 08-02-2007 12:33 PM
Pros and Cons of different types of windows Peggy Problem Solving | Owners Helping Owners 2 06-15-2007 05:25 AM
Condensation in refer? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 07-28-2003 04:02 AM
