PROVEN Useful tools for renos. - Fiberglass RV
Old 10-29-2012, 12:37 PM   #1
Trailer: Boler 1700 '79
I was working on my Boler 1700 stripping the last of the Ensolite out today and thought I would recommend a few tools for the job. That got me thinking to suggest a new thread specifically for a listing of tools that have PROVENuseful during renos. Not tools you are going to use but ones you have had success with. Perhaps saving people time and energy. I know I have a bunch more things to do and always appreciate when someone can streamline my task.
Important factors I consider when buying a tool: Will I use it again afterward? How much does it cost? How easy is it to use? What is the set up time? How durable is it? What are the maintenance costs? Am I just being lazy...? Etc...
Anyway its just a sort of "it takes a village to reno and egg" kind of thing...
ENSOLITE REMOVAL
Anyway while removing my Ensolite I read various threads about how to take it off. I saw scrapers to even someone using a pressure washer...?
I started(read below if you want to see what tools I used before hand) with a Dremel Multi-Max (electric tool) with a Rigid scraper blade. This worked well. Still took a lot of effort but was much easier then hand scraping. I tried the flexible scraper blade but it was no good(too flexible). After an hour though the Dremel started shutting off. I believe the contact for the switch rattled loose. Long story short: I could not return it and it was too expensive to repair.
I bought a Fein Multimaster which has the scraper blade in the kit and it was awesome. I would really recommend this tool but I think there are others out there that are just as good.(I actually love Dremel tools so it may be just this one tool)
I had also tied a large floor scraper with little effect and a large hand scraper as well as some wall paper scrapers etc... also with little effect.
Hope this helps anyone starting this job.(I will repost this again as a stand alone reply)
Crackedegg is offline   Reply With Quote
Old 10-29-2012, 03:31 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'll start!
Here's a real popular tool: http://www.fiberglassrv.com/forums/
Francesca
Old 10-29-2012, 04:21 PM   #3
Trailer: 1978 Trillium 4500
#1 on my list is this:
Amazon.com: Dremel 6300-01 120-Volt Multi-Max Oscillating Kit: Home Improvement
You can accurately cut fiberglass of any thickness. Not fast, but accurate.
As you noted, this is also good for scraping off Ensolite.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 10-29-2012, 05:34 PM   #4
Kitchen electric knife for cutting foam rubber. Cuts like butter, don't sneeze!!
Old 10-29-2012, 07:33 PM   #5
Voltage Meter and a rivet gun!
Old 10-29-2012, 09:05 PM   #6
uhaulin's Avatar
Trailer: Uhaul ct-13
A plastic scraper and plastic razor blades to remove all silicone from previous owners.
uhaulin is offline   Reply With Quote
bkboler renos bkboler Modifications, Alterations and Updates 25 07-27-2017 02:54 PM
Tools explained DannyH Jokes, Stories & Tall Tales 5 10-30-2010 07:22 PM
Renos-we need to do renos! Rick Harmer Problem Solving | Owners Helping Owners 4 08-27-2009 02:11 AM
Proven Value of MF - Coach House? Steve Dunkel Money Matters 21 03-31-2009 10:34 AM
Renos on my boler LauraW Modifications, Alterations and Updates 27 06-12-2007 12:55 PM
