Putting a Basement in a Scamp - Fiberglass RV
Old 09-24-2008, 06:24 AM   #1
Trailer: 1985 Scamp 13 ft / 1999 Toyota Tacoma
Well,
After putting on a new trailing arm Dexter Axle this past June, with the Sub frame added and all of that, the little Scamperoonie had leveled out with the Tacoma and the Tundra, so now no drop hitch required. An overall increase in height of about 4 1/2 inches.
I had 13 inches of ground clearance to the axle center, and 24 inches of clearance under the rear of the trailer.
So....I put in a BASEMENT, really a basement in a Scamp.
Made box with 5/8 Plywood sides, and a 3/4 OSB bottom, glued itwith epoxy and screwed it together, then wrapped the whole thing with 4 ounce fiberglass cloth and put an extra layer of 20 ounce fabric on the bottom, and then three coats of fiberglass epoxy resin from Raka Epoxy.
I then cut out the carpet, cut a hole in the floor just behind the step up behind the axle, and glued with epoxy and screwed everything in place, then caulked it all tight just for good measure.
The outside finished dimensions were frame to frame 45 1/4 x 24 front to back and 12 inches high. This gave me almost a cavernous extra 7 1/2 plus extra cubic feet of storage in an easy to access location.
I chose 12 inches to allow milk jugs, milk crates and my charcoal grille to fit vertically in the basement.
This still allows me 12 inches of ground clearance, which I am going to put a metal skid plate on the bottom of the basement. Although it will likely never get hit, the Tug's clearance is only 8 1/2 to 9 inches at the lowest points. The old axle was about 6 inches clearance side to side, and although it got dinged a bit over the years, we never hung up in rough road conditions.
This basement storage is just the thing for this outfit, now we can put a lot of stuff like our chairs and cocktail table, the grille and charcoal out of the way when traveling, also a couple of milk crates with four gallon jugs of water where they will not freeze until it gets real, real cold. The weight is right behind the axle, so very little impact on our Center of Gravity.
Garo
Gary Carvajal is offline   Reply With Quote
Old 09-24-2008, 06:25 AM   #2
More Pics--sorry they are so big..
GAro
Old 09-24-2008, 06:27 AM   #3
One more
Old 09-24-2008, 06:31 AM   #4
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I like this idea. A Scamp can always use more storage space.
Old 09-24-2008, 06:31 AM   #5
Completed view from inside with the basement installed, still twelve inches of ground clearance---Garo
Old 09-24-2008, 06:36 AM   #6
Rear View--Garo
Old 09-24-2008, 06:37 AM   #7
Rear Side--last one...Garo
Old 09-24-2008, 06:38 AM   #8
gearyg's Avatar
Trailer: 13 ft U-Haul and 16 ft Amerigo
Wow ! I'm impressed ; great craftmanship.
gearyg is offline   Reply With Quote
Old 09-24-2008, 06:40 AM   #9
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Gary Carvajal
Why do you have a trailer hitch on the back of your Scamp?
Old 09-24-2008, 06:46 AM   #10
Gary Carvajal
To tow my small boat or drift boat with...
Garo
Old 09-24-2008, 06:50 AM   #11
Recent pic, with the new axle, the increase in ground clearance is noticeable...
This was Labor Day weekend up on the Blackfoot River here in western MT.
Garo
Old 09-24-2008, 07:09 AM   #12
Wow!! Neat idea! But <gasp> SNOW already!! Holy cow!!
Stacy Crotser is offline   Reply With Quote
Putting a new license plate on a Scamp Monica M General Chat 6 05-27-2009 10:28 AM
Putting money into a trailer... Todd Sleeman General Chat 4 05-30-2008 06:12 PM
Putting Together a Tool Kit John Blair Care and Feeding of Molded Fiberglass Trailers 32 05-07-2007 06:25 AM
Putting the truck on a diet Legacy Posts Problem Solving | Owners Helping Owners 6 05-08-2003 07:59 PM
