Question about fiberglass shell "reshaping" - Fiberglass RV
Old 02-08-2016, 12:56 PM   #1
Trailer: 1981 Burro - 13'
Ohio
My new Burro seems to have been the victim of a large tree branch laying on top of it for some time over the last few years. The roof is not straight any more, has a dip about 1.5" across it at an angle where the fiberglass seems to have been deformed by the sun/time/etc.. If I shore up the inside with a nice straight board or two so that there is some pressure against the ceiling, and then used a heat gun to "gently" warm up the surrounding fiberglass around the dent, would it take a new "set" and straighten out? Or am I doomed to having a "hunchbacked" Burro? Anybody have any ideas, advice? It's not cracked, just has a very noticeable dent at a 45' angle across the roof line. Help??
CapnJim is offline   Reply With Quote
Old 02-08-2016, 04:55 PM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
Your idea of warming it up while applying force sounds good. That's what I would try, but I would wait for some hot summer days to make the heating more uniform and to make it easier on myself. If you leave it braced while not in use, it should return to its original shape over time. The fiberglass should have some memory.
Old 02-08-2016, 06:50 PM   #3
Ohio
Thanks for the input, Paul. And maybe putting a layer of something dark over it, like a dark tarp, a layer of felt roofing, or something similar to use the solar effect. Won't be much of that here in Ohio for a while, though! I'd really like to hasten the "fix", the vent hole in the top is only temporarily covered with foam board and outdoor duct tape and I don't want to install the new vent with it sagging. So, for now, my Burro has a "do-rag" on it (a tarp tied down over the top) Can't hurt to shore it up in the meantime, can it? Not sure how much "memory" fiberglass has.......haven't worked with it much but I have a feeling I'm going to LEARN fast! Thanks! Anybody else faced the same thing?
Old 02-17-2016, 10:04 AM   #4
David Tilston's Avatar
I have a Trillium that the roof was collapsed for about 5 years before I purchased it:
I was sure I was done buying Trilliums for Now
I jacked up the roof for the last couple of years, and the shape has returned in many places, but there is a limit. There are places that I am resigned to cutting out the deformed section, and putting in new fibreglass. But since the insulation has to come off anyway, that doesn't seem like such a difficult job.
Old 02-17-2016, 10:56 AM   #5
Ohio
Mine isn't really BAD, just mostly noticeable; like a dimple on a marshmallow! I haven't done much with it due to cold weather, but thanks for the reply; I have hope now that most of it will come out with the sun and a prop under it. Good luck with your project!
burro
Boler door reshaping Steve_74 Problem Solving | Owners Helping Owners 20 08-21-2015 05:51 PM
IN | Fiberglass Scamp or Trillium Shell camper trailer for sale Cobrajet Classified Archives 8 04-25-2012 08:18 PM
2006 TrailManor - fiberglass shell hard popup matt scott Classified Archives 9 11-18-2008 10:56 PM
Need a Quick and Dirty Way to Waterproof Fiberglass Shell! April Care and Feeding of Molded Fiberglass Trailers 13 04-11-2008 03:42 PM
FIBERGLASS CAMPER SHELL FOR SALE Mike Kelley Classified Archives 0 02-11-2007 02:06 PM
