Question of second battery's interior placement - Fiberglass RV
Old 10-12-2011, 09:42 PM   #1
Trailer: 1988 Bigfooit 19'
I recently purchased a 1988 bigfoot 19' travel trailer. While remodeling I discovered an additional battery space under the FWD dinette storage. A power cord terminating in both a positive and negative battery connection plugged into a female receptacle ( I expect to be the shore power connector).
I was wondering what a setup like this is used for as I have a battery mounted on the trailer tongue? No to mention the dangers of storing a battery inside the trailer.
I'd appreciate any advice or help offered.
jordo is offline   Reply With Quote
Old 10-13-2011, 01:46 AM   #2
Saskatchewan
Pictures would make visualizing it much easier. The only thing I could think of would be an option to relocate the battery to prevent theft. If you have voltage tester I would see if there is power at the leads and try to trace them back.
Orcus79 is offline   Reply With Quote
Old 10-20-2011, 05:27 PM   #3
Trailer: TrailsWest CAMPSTER 1970
Jordo, In my Campster I found a good place for my battery next to the wheel well.
I will try and attach a photo.....last time photo transfer did NOT work.
Doc the boonDOCer aka campfrugal
campfrugal is offline   Reply With Quote
Old 10-21-2011, 12:32 AM   #4
Trailer: 16 foot Scamp
There are advantages to having the battery inside. For one thing, it is kept warmer and that significantly improves performance in cold weather. A lead acid battery stored inside should be in a sealed box with exterior venting so that corrosive and explosive gasses are kept out of the trailer. Dry cell batteries like the Optima can be kept in a non-vented box.
David
DavidSo is offline   Reply With Quote
Old 10-21-2011, 09:58 AM   #5
The Minimalist's Avatar
Louisiana
That's not the battery location for the trailer brake break away system?
Battery placement Sleeka Problem Solving | Owners Helping Owners 14 07-17-2011 01:25 PM
Bigfoot B19 interior disassembly question Lee P Problem Solving | Owners Helping Owners 3 04-06-2011 09:09 AM
Interior Vinyl Question Jakeh General Chat 7 10-18-2008 04:10 PM
Trillium 1300 Interior Battery Placement Booker B. Problem Solving | Owners Helping Owners 12 06-22-2008 10:31 PM
Fiber Stream Battery Box Placement Benita Care and Feeding of Molded Fiberglass Trailers 11 05-12-2006 03:07 PM
