03-10-2014, 03:58 PM
#81
Originally Posted by Carol H
Even without ever leaving the lights on, 5 years seems to be about the norm - that is if I want to be sure the battery is good enough to crank over at -30 on a ski hill. I guess if you stick to warmer climates you might get more years out of one.
The good news is my new tug is a bit fool proof in regards to leaving lights on when its not running. It shuts them off itself after 5 min. Which reminds me I have to check to see if it keeps charging the trailer if I leave it plugged in while parked.
My Frontier is a 2012. The cheap (s) version . No headlight timer, no courtesy lights up front, no power window, door locks, mirrors, you get the idea . But the charge line is off with the key off.
03-10-2014, 04:21 PM
#82
Thanks Raz, good info. I am assuming that as I have some of the other stuff mine will work the same.
Drew - yes getting a solar controller to match your panels is a good idea as it is to match your power needs and I do see the benefit of the MPPT when running solar. But my question is will the fact I am running a simple consumer grade Power Converter with a basic smart charger when on the grid & not on solar which is about 50% of the time mitigate the benefits of having the MPPT in regards to improved battery life?
03-10-2014, 04:53 PM
#83
Trailer: 2010 Scamp 16
Originally Posted by MCDenny
My jeep grand cherokee puts 13.0 volts on the trailer battery whether idling or running 2000 rpm. Not enough oomph left after running through the vehicle to the plug and another 5' of 10 gage wire to the battery. Towing with the fridge running doesn't seem to run down the battery but towing with a partially discharged trailer battery won't recharge it either.
Common problem, that long run from the tug charging system back to the trailer plug has to be some heavy wire to avoid voltage drop. Have heard of people using 8 gauge or even welding leads to overcome that problem.
Voltage delivered has to be greater than battery voltage to force any charge in, and if it's just a little greater it won't charge very rapidly.
Say battery is at 70% charge, it would still have approx. 12.3 volt charge and feeding it 13 volt is not going to push much charge in. Especially if you drawing power at the same time.
That is a question that has not been asked (at least I don't think it has) how does a charge controller deal with load while charging? In regards to the state of the battery charge. How does it handle topping off the battery charge when say 3 of the 4 amps coming from solar is being used.
03-10-2014, 05:45 PM
#84
NE Oklahoma
Originally Posted by blodn1
I can see a tent and/or tipi made of solar cell material........lol
Haven't searched yet, but would not be surprised if there already
is such a animal.
Interesting read.
03-10-2014, 05:46 PM
#85
NE Oklahoma
I just had a thought........
A vehicle wrap that is actually a solar wrap.
03-10-2014, 11:41 PM
#86
Carol, battery sulphation, which is what kills a battery, starts to pick up when the battery drops below 80% of charge. As long as you have enough solar panels to support your discharge rate, just about any PWM or MPPT charge controller should get your battery above 80%. Once you make it to float mode your battery sulphation rate drops to almost nothing regardless of what kind of controller you have.
03-10-2014, 11:52 PM
#87
My teardrop-shaped panel stand-offs and wire viaduct are made from a pine shelf board, the viaduct cap from 1/4" plywood. I drew a teardrop shape on some graph paper, transferred it to the shelf several times, and cut the profile out with a sabre saw.
From there I had to use a belt sander to get the bottoms of the standoffs so they sat flat to the trailer roof and panel. I wrapped them in thin fiberglass mat, drilled my holes in the mounts and in the trailer roof (being very, very carefull to make sure everything lined up) and attached them to the roof using Bondo. I also used Bondo to build the little contour ramp up the sides.
From there it was sanding and painting.
Oh, I also added a layer of cloth on the inside where the mounts are as well as some structural roof supports made of 1" PVC pipe cut in half, then fiberglassed for it's entire length right-to-left in the roof ridge.
We're really hoping to have the Surfside ready for Bandon, by the way.
03-11-2014, 05:45 AM
#88
Just to avoid a common misconception, the voltage drop on the charge line is always the difference between the two sources and has nothing to do with the size of the wire. The charge line resistance determines the size of the charging current and how long the trailer battery will take to charge. As long as there is nothing on in the trailer, the trailer battery will eventually charge.
Icharge =(Vtow - Vtrailer)/ Rcharge line
Tow vehicle or solar controller, both should behave the same. With a load in parallel with the trailer battery, the trailer battery is being discharged. The charge line current is still the difference between the two sources divided by the charge line resistance. If the charging current is greater than the load current, the difference will charge the battery but at a reduced rate. If the load current is greater than the charge line current then the trailer battery will continue to discharge and it's voltage will drop. When the load was a heater in a 3 way fridge, the battery was never charged and the fridge was warm. But if the load is a motor in the fridge, it's possible it could stall. Then the overload should protect the fridge. In this case a larger charge line might increase the charge current (larger wire) enough to satisfy the demand. If not, you need to increase the size of the source be it a solar array or an alternator. Raz
Edit- one additional thought. In the case of a smart controller you really are at the mercy of the software. I would assume the programmer anticipated this scenario.
03-11-2014, 06:54 AM
#89
Trailer: Prius camping - want an Oliver
Virginia
I don't get lost, I go on interesting side trips.
03-11-2014, 09:18 AM
#90
Thanks Peter for the details on how you made your thru hull fitting! You are the crafty one! Look forward to seeing the Surfside at Bandon. Are you guys bringing both trailers? - his and hers?
I am pretty careful with keeping my power demand well below the solars ability to supply but admit when off the grid for more than a few days in less that perfect sunny weather keeping the battery above 80% is a tall order. Keeping it above 50% is my target with current set up & I am able to do that. Not sure that even with a bigger panel I would be able to achieve keeping it above 80% some days in the wet heavy forested wet coast, which I know you know all about. But as panels are getting smaller with more watts and due to price drop I am considering upping my panel wattage and giving my old panel to a family member who is just starting out with solar on their RV.
I guess what I am still just a tab puzzled about is as it has been suggested here more than once the PD converter with smart charger which the trailer is running off of about 50% of the time will not give a true full battery charge resulting in some sulphating. If I went with the MPPT solar controller it is able to give a fuller charge avoiding the sulphating issue but due to camping in tree covered areas my solar is not plugged in full time or fixed to the roof - only put out as needed. So if the battery its charging off the converter 50% I am assuming that some sulphating is taking place. Will the fact its running off a MPPT controller the other 50% of the time actually do anything to mitigate that? Will it reverse the sulphating issue?
Not sure yet if I should spend the extra dollars for the MPPT controller vs spending it on a larger wattage panel due to the fact I am not planning on changing out my converter any time soon. I actually talked to Reace about possible changing the converter last week as the trailer is heading his way shortly for an update of another kind .... he talked me out of it!
03-11-2014, 11:02 AM
#91
Unfortunately the sun is the key no matter what controller you have. If you aren't in a sunny spot it's like sitting in the dark to a solar panel. If you are in the sun and your panel can't push your battery to it's bulk voltage your panel is likely undersized. The mppt controller might allow your panel reach it's spec'd amperage but it won't give you any extra unless your panel is a much higher voltage.
For off grid cabins etc the simple formula for minimum watts to buy is 1 solar watt for each battery amp hour. So if you have a 100amp hr bank you need a 100 watt panel. This minimum generally ensures you'll hit the bulk voltage in one day, but is still considered a minimum.
I went from 75w to 215w. Since I did that I've never had a problem unless the sun is fully blocked by trees or some massive rv .
Where we’re going, we don’t need a plug-in.
03-11-2014, 11:30 AM
#92
Thanks Drew, as I mentioned I do understand the issues associated with the sun and panel sizes etc.... wondering more about the sulphating issue caused by the Power Converter and reversing it with the MPPT.
03-11-2014, 11:47 AM
#93
Trailer: 13' Scamp
Sulphating issue
so with a panel fixed on the roof, the battery will never sit for long periods discharged. In fact it will get charged every day which is the ideal conditions for storing a battery. Therefore sulphating should not be an issue because the battery is always charged. MPPT vs. PWM controller will not have an effect either way, though some have functions that periodically apply pulses to reduce sulfation.
If however you use a foldable array that you put away, you then need to make sure you keep your battery charged while in storage and leaving the battery discharged will result in sulfation which will decrease the life of your battery.
03-11-2014, 11:58 AM
#94
Trailer: 13' Scamp
MPPT waste of money for small system
More panel is MUCH cheaper then using an MPPT over a PWM controller. With a MPPT you will probably get 10 to 15% more energy out of your panel then a PWM controller. The higher numbers in marketing material refer to connecting a solar panel directly to the battery. So for a 100W panel you may get 10 W more out of the panel on average (remember most of the time the panel is giving you less then the rated output under ideal condition). That MPPT will cost you $100 more than the PWM controller, but for $100 you could easily get a 30W panel. So for the same price the extra panel will give you more power.
However if you simply must maximize the performance from the one panel you have then an MPPT can be an expensive tool for optimization.
In a larger system like >500W then then additional performance from the controller can save a lot of money in extra panels and the difference in cost between a PWM and MPPT controller becomes negligible.
03-11-2014, 12:18 PM
#95
When it comes to battery sulphaton and MPPT, PWM, and Progressive Dynamics chargers, one really isn't better than the other at preventing it. Lead sulphate only forms while a battery is discharging, not charging. That means as long as your charger, whatever it is, is pumping electrons into your battery, the battery won't sulphate. The only exception to that rule is when your battery boils and the lead plates become exposed and dry out.
As for Progressive Dynamics converters, I think they're fine for camping use, but I don't think they're the optimal for storing a trailer and its battery. For that I use a charger that's really designed to keep stored batteries in top condition, a BatteryMinder trickle charger/desulphinator.
A BatteryMinder melds electrical circuit design with an understanding of the properties of the two types of Lead Sulphate (Lead (II) Sulphate, the "good" kind, and Lead (IV) Sulphate, the "bad" kind that "sulphates" batteries) to break up the bad lead sulphates and get keep a battery in good operating condition as long as you possibly can. Using the BatteryMinder to trickle-charge your system while you're not using it is probably the single, best way to keep a battery working over the long-haul.
One of these days I'm going to write up a layman's description of how a battery becomes sulfated in accurate, understandable layman's language that a chemist could love. I started doing that again today, but, once again, got hung up in explaining the reasons why there are two types of lead sulfate and how, why, and when they form in a battery. The explaination, very literally, tries to reduce quantum physics as it applies to Chemistry -- third year Chemistry, if you're studying for a Chemistry degree -- and make it understandable to non-Chemists. I'll make it happen someday and post it.
03-11-2014, 12:19 PM
#96
I'd have to agree with some other post, MPPT wouldn't do much more to reduce battery sulphation. You might squeeze a bit more out of your panel but likely not enough to make it superior to simply adding watts.
I use MPPT because my new panel sits at 42v. When I used it with a 17v panel I never saw any real gains. At most it allowed the panel to push it's maximum 4amps, which some might argue is worth it, but I don't think it's cost effective on such a small panel, especially if you already have a working controller.
03-11-2014, 01:05 PM
#97
<cut>
<cut>
One of these days I'm going to write up a layman's description of how a battery becomes sulfated in accurate, understandable layman's language that a chemist could love. .<cut>
LOL look forward to reading the first addition!! Sure to be a best seller here if you are able to keep it in simple layman's terms!!!
Got the BatteryMinder for winter storage so I guess at this point it seems on the bases of economics I will just stick with my plan to increase my panel wattage and assuming I don't get one with to high an amp output I will keep using the solar controller I already own... now when I get my forever trailer then will be the time to upgrade everything to the best and I will read your novel for sure! who knows what the best will be in a year or two! I am still amazed at how much cheaper and smaller panels have become just over the past couple of years along with the controllers. I could purchase a pretty nice high wattage system for 2 trailers for what I paid for my first panel and controller 6 years ago
03-11-2014, 03:39 PM
#98
Trailer: Lil Snoozy
Many solar controllers have an"equalize" function the operates manually or automatically maybe once a month. It over charges the battery a bit, the purpose being to remove lead sulphate crystals (I think).
My iota Dls 30 charger does not have an equalize function but my T105s are two yrs old and still have a fully charged resting voltage of 12.72 and the partially discharged resting voltage agrees with the state of charge calculation my Victron battery meter gives. So I think the battery's are still A-OK.
THe battery charger has been plugged in pretty much all the time we have been camping and once a month for 24 hrs when it's been in storage.
03-11-2014, 04:17 PM
#99
My PD 4045 has a similar function. I believe they increase the voltage to boil the electrolyte in an attempt to make it homogeneous, mimicking the mixing effect of a moving vehicle. I believe it is preventative and will not remove already existing crystals. Newer chargers are using high frequency pulsing to reverse sulphate crystals. If anyone knows the magnitude and frequency that is being used, I'd love to know. Raz
03-11-2014, 04:18 PM
#100
Trailer: Lil Snoozy
Questions about solar power
I pulled the trigger today.
100w mono semi flexible panel from Renogy. $199, free freight.
The 3 lbs weight (vs. 16.5# for their conventional glass panel) was just too good to pass up. I'm going to rig up a slide in mount on the roof. The panel will live there and stay up there if we are boondocking in the sun. It will slide out and go into a frame to sit on the ground if we are boondocking in the shade. I'll have this built in a couple of weeks and post some pics then. The light weight and 0.196" thickness makes me believe this 'best of both worlds' solution will be hassle free.
Schneider Electric, formerly Xantrex C-12 12amp PWM controller. $77 plus $13 freight from N Arizona wind and sun.
Boy, was this a complicated issue. You can read all the PWM vs MPPT discussion above. I decided the extra cost of MPPT was not justified by my puny little 100w panel.
In my research I noted different controllers use different voltage set points for bulk, absorption, float and equalize phases. I looked up Trojan's recommendation for my T105s and found none of the controllers (nor does my battery charger) meet their specs. I chose the Xantrex C12 because the voltage set points for bulk and float are user adjustable. I asked a Trojan tech support guy if this mattered and he said "well, ya, sort of, the battery will last longer, not gas as much, it's probably better". Not an unequivocal "yes" but not "it doesn't matter" either. I asked the salesman at Az wind and sun if it mattered, he leaned closer to "yes" than the Trojan guy. I was going to get a Morningstar Sunsaver 10 amp which they say is their most popular controller. I asked him, since T105s are certainly a popular battery choice for deep cycle applications, what about the mismatch? He said most people never dig this deep and the Sunsaver-T105 combo works good enough.
Here's a little table of the different voltage points. I hope the columns stay lined up.
$80. $56. $22. $90
TROJAN. IOTA. TRACER M'STAR. RENOGY. XANTREX
DLS30 1215Rn. SS-10. 10 Amp. C12
Bulk. 14.8. 14.8. 14.6. 14.4. 14.4. Adjust to 14.8
Absorb. 14.8. 14.2. 14.6. 14.4. 14.4. Adjust to 14.8
Float. 13.2. 13.6. 13.8. 13.7. 13.6. Adjust to 13.2
Equalize. 15.5. N/a. 14.8. 14.9. 14.6. 15.8
All are 10 amp PWM except the tracer is MPPT. Xantrex is 12a PWM.
Another plus for the C12 is that it will handle 200w of panels so if I find 100w isn't enough I can add more and keep the same.
controller.
I ordered 50' of 10/2 marine duplex wire from genuine dealz for $52. Free freight. I've used this supplier for all the wire and terminals for my electric boats. Good quality, good service, lowest prices anywhere. I plan to drill a hole in the bottom of the trailer under the bed where the controller will go, route under the trailer and up the back wall to the panel. If I take the panel down I'll have about 7' of wire to move the panel on the ground. I'll use the rest of the cable, about 30’, to make an extension cord if I need to locate the panel further than 7' from the back of the trailer.
The panel comes with MC4 connectors so I got a five pack for $10 on Amazon.
I'll begin installing this stuff in a couple of weeks and will update this thread when it's all done.
