Questions from new Boler owner - Page 3 - Fiberglass RV
Old 11-30-2014, 05:48 PM   #29
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
If a battery expands or bulges in cold weather, it is because it has frozen. This will damage the battery and render it junk.
A battery can be frozen if it is discharged and subjected to freezing temperatures. The acid in a battery is partially converted to water when the battery is discharged. Reconverted to acid when it is charged. It is very important to store lead acid batteries in a charged state, do not allow a battery to sit in a discharged state for any period of time (in cold weather it will freeze). This will allow the plates inside the battery to oxidize or scale up and decrease the capacity of the battery, resulting is reduced power output and life of the battery.
Batteries can last anywhere from 2 years to 10+ years. I just replaced (today) the battery in my 2002 Chrysler for the first time so this one lasted 12 years. The battery in my wifes Jetta only lasted 3.5 years, so you never know
And, no, it should not vent in this condition, but, I have seen frozen batteries crack the case and acid could leak out the cracks when the battery thaws.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 11-30-2014, 06:34 PM   #30
Borden's Avatar
Name: Borden and Carole
Battery is best outside or in a vented box great advice above, due to fumes;
They make a bottomless rivets for marine use they will not let the water or drafts in; we have had rivets to fix and more to do they come in common head and counter sink head for flush fit the closed end works better than regular rivets
We have kept the original gelcoat as it is low maintenance they make colour match gelcoat kits large kit is small needed a couple of them from local marine store
Some holes had to fill with two part epoxy and then predrilled and rivet
1978 Ontario made Boler
Old 11-30-2014, 07:39 PM   #31
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Originally Posted by andrew78 View Post
JKMBoler,
i have seen batteries expand in cold weather
would it vent in cold conditions?
AGM batteries do not freeze, according to several AGM battery manufacturers.
We have a Lifeline GPL 4DL AGM Mobile 12Volt 210AH.
Dave & Paula
Old 11-30-2014, 07:43 PM   #32
Philsie's Avatar
Name: Phil & Margot
Trailer: 1982 Boler 17' 2002 Honda Odyssey. Replaced with a 2010 Odyssey
Ottawa, Ontario
Just as an aside...I have read where some have used two 6v batteries wired in series. What are the benefits of doing this? More amps? Last longer? Is the extra cost worth it?
Thanks
Phil
To err is human, to moo is bovine
Philsie is offline   Reply With Quote
boler
New to the site and New Burro owner with questions GregLS Problem Solving | Owners Helping Owners 8 06-23-2014 09:42 PM
Basic questions ;electrical from a new owner Kent I Electrical | Charging, Systems, Solar and Generators 11 12-07-2010 07:57 AM
New Owner with questions Rachel D Problem Solving | Owners Helping Owners 1 05-16-2009 02:21 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 04:36 PM
New to the site and New Burro owner with questions GregLS General Chat 0 12-31-1969 07:00 PM
