Questions from new Boler owner - Fiberglass RV
Old 07-31-2014, 10:21 AM   #1
morgynm's Avatar
Nova Scotia
I finally got out to explore my new to me Boler today and take some pics. It looks like it has some minor mildew or mould on the inside so I'm going up have to do a good bleach wash soon. Is that normal for campers that haven't been used in a while?
Also, there's some screws or rivets or something starting to pop out on the outside. Easy fix?
And what is the panel in the third pic for? One of the black knobs has a fuse in it and the two white buttons are labelled "20" and "15"
Name:	ImageUploadedByFiberglass RV1406823489.813446.jpg
ID:	74281Click image for larger version
Name:	ImageUploadedByFiberglass RV1406823523.644392.jpg
ID:	74282Click image for larger version
Name:	ImageUploadedByFiberglass RV1406823586.099326.jpg
morgynm is offline   Reply With Quote
Old 07-31-2014, 10:23 AM   #2
morgynm's Avatar
Nova Scotia
I might have put this in the wrong sub- forum. Sorry if I have.
Old 07-31-2014, 11:03 AM   #3
morgynm's Avatar
Nova Scotia
Update... I discovered that the other knob has a fuse in it too. I also discovered the deep cycle battery under the seat below the panel and when I connected the wires to the terminal... Presto! Lights inside! The ivory rocker switch has three positions: left turns the power from the battery on, centre seems neutral as the lights go off, and I'm not sure what right does as there's no power that way either. Click image for larger version
Name:	ImageUploadedByFiberglass RV1406826170.405594.jpg
ID:	74284 Still trying to solve the mystery of the two little push buttons with numbers on them!
Old 07-31-2014, 06:06 PM   #4
Roy in TO's Avatar
Rocker switch might be to switch from battery to off to 120 coverting to 12V
Push button swithches could be fuse sizes in amps. give them a push and turn and a glass fuse should be inside.
Old 07-31-2014, 06:10 PM   #5
morgynm's Avatar
Nova Scotia
Thanks! I'll try that when I get back from camping... unfortunately, not in my new baby!
Old 07-31-2014, 06:27 PM   #6
Roy in TO's Avatar
Originally Posted by morgynm View Post
I One of the black knobs has a fuse in it and the two white buttons are labelled "20" and "15"
oops misread, white buttons are to reset circuit breakers.
Old 07-31-2014, 06:36 PM   #7
morgynm's Avatar
Nova Scotia
So there are fuses and circuit breakers? Sorry. I really am very new to all this. I'm trying to learn as much as I can from people before I jump in and muck about with the different systems in the camper.
Old 07-31-2014, 06:44 PM   #8
Roy in TO's Avatar
I've got a different converter in a different trailer. In mine the circuit breakers are on the 120V side and fuse on the 12V side. The rocker switch is for 12V from the converter on one side, off in the middle and 12V from the battery on the other. If you are not plugged in, you can test it with your interior lights. On, off, off or the other way around. Plugged in you will get on, off, on.
on edit, reading your post above. It will probably be left = 12V from battery, middle = off, right = 12V from converter.
Old 07-31-2014, 06:55 PM   #9
morgynm's Avatar
Nova Scotia
Alrighty! Is the big round plug tucked behind a little round flap what I plug in to power the lights direct? This thing has so many plugs and outlets. Click image for larger version
Name:	ImageUploadedByFiberglass RV1406854450.509575.jpg
ID:	74290 If that's the case, I'll ask my dad to plug her in!
Old 07-31-2014, 08:14 PM   #10
Roy in TO's Avatar
Ask your dad to plug her in then.
And the one beside it is a water fitting. If female, it should be water in to the sink, not the tank. Follow the line or hose inside to make sure.
Old 07-31-2014, 09:10 PM   #11
Trailer: 17 boler
make sure the battery is sealed and vented if its inside the trailer
andrew78 is offline   Reply With Quote
Old 08-01-2014, 05:21 AM   #12
morgynm's Avatar
Nova Scotia
Oh crud. It's not in a battery box. Someone mounted it to one of those holders like in a car but that's it. I was surprised where it was as I always thought they were mounted on the tongue. Adding moving the battery and it's corresponding wiring to my to-do list.
Old 08-01-2014, 07:55 AM   #13
Trailer: 17 boler
not a big deal to buy a vented battery box. i thought it always made sense to have it inside to keep some weight off of the tongue
Old 08-01-2014, 08:11 AM   #14
morgynm's Avatar
Nova Scotia
Alrighty then... I can cross off the previous and add vented battery box instead. Sound much easier to do!!
boler
New to the site and New Burro owner with questions GregLS Problem Solving | Owners Helping Owners 8 06-23-2014 09:42 PM
Basic questions ;electrical from a new owner Kent I Electrical | Charging, Systems, Solar and Generators 11 12-07-2010 07:57 AM
New Owner with questions Rachel D Problem Solving | Owners Helping Owners 1 05-16-2009 02:21 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 04:36 PM
New to the site and New Burro owner with questions GregLS General Chat 0 12-31-1969 07:00 PM
