01-26-2013, 09:59 AM
Radiant Floor Heating
Has anyone installed radiant floor heating in their trailer? What product did you use to do this? How did it work out?
Usually radiant floor heat will amount to an electric heat pad that goes under the floor tile (or carpet).
Does anyone have any wisdom on radiant floor heat in our trailer type applications?
Derek
01-26-2013, 10:11 AM
I used a heated pad on the floor underneath the dog bed, worked great.
01-26-2013, 11:46 AM
In floor heating
Electric in floor heating is normally used as supplemental heat in colder climates and not as a primary heat source . The watt density/ft. and the heating cable spacing can vary to suit your heating needs, but you are limited to a maximum floor temperature to prevent burning skin (Bare Feet) , The flooring material must conduct heat (Ceramic =Good --Carpeting = poor) You would also need to insulate the floor and use a reflective surface to force the heat up into the living space, I have in floor electric radiant heat in my home and have installed it in many homes and commercial buildings . Stepping on a warm ceramic floor after coming out of a shower is nice but in floor electric heat does little to warm the room air on a really cold day. In floor electric radiant heat is also slow to respond to large temperature change. (HOT WATER IN FLOOR HEATING USED WITH A CONCRETE SLAB IS ANOTHER SUBJECT)
01-26-2013, 12:11 PM
I have hot water radiant heat in my house, solid stone with slate roof and 24' thick walls. The system utilizes cast iron welded pipes, encased in gravel, under my hardwood floors. There is about a 2-3 hour time lag before the floors get warm, but once warm, they retain the heat for about 12 hours due to the gravel heat sink, until the cycle repeats itself. The air temperature is about 64 but with warm floors, you feel warm. That said, I doubt that you could create a heat sink install that would hold the heat. Thus it would be on constantly, so you might as well use some other type of electric heater.
01-26-2013, 03:20 PM
Name: Norm and Ginny
I've considered this in the past. The real issue is lack of floor area. My view is that you need about 1500 watts and in general these small trailers don't provide enough floor area.
They would not work like Harley's, no heatsink effect but would heat the floor directly. My experience with floor radiant heat was very satisfying. Nothing beats a warm floor. Link follows to a source.
Laminate Heated Floors - ThermoSoft
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
01-26-2013, 04:19 PM
Trailer: '78 Trillium 4500
Thanks for the link, Norm!
Looks like they're having a sale...at $65.00 for a 1-1/2' by 5' section, I'm almost tempted to buy and try as a floor-warmer under my throw rugs. I know that's only about the wattage of a light bulb...but anything might take the chill off the bare feet!
Francesca
01-26-2013, 04:24 PM
There are plenty of 120V floor heat systems available that could be used in a trailer. With some you can do a custom layout of the floor and they will make a mat to that exact size. We do this all the time with bathrooms and entries in homes.
Once of the biggest problems is that there is little for insulation below the heat mat, and much of the heat will be drawn to the outside, so the effectiveness will be quite low. I guess it is not a big deal if you are using the campgrounds dime, but it is if you care about conserving energy.
Nuheat is one brand we use a lot, and rarely do the standard mats fit, though you might find they do with the simple layout of a trailer.
http://www.nuheat.com/floor-heating/...loor-heat.html
2017 Escape 5.0 TA
2009 Escape 19 (previous)
01-26-2013, 04:36 PM
I s'pose all trailers differ, but my Trillium's floor is fiberglass on marine plywood, under which is the (airgap?) belly of the trailer. One would think that might provide a bit of a barrier to heat loss.
And while you experienced types are on the line:
Is there some reason these mats couldn't be used on the walls???
Francesca
01-26-2013, 04:41 PM
Francesca
I don't make a habit of walking on my walls.......just sayin'.
These electric mats for the most part are for comfort, not the heating of a space. We install the majority of them under tile, and mostly in bathrooms. Feels great on the tootsies.
2017 Escape 5.0 TA
01-26-2013, 05:50 PM
Trailer: Escape 17 ft Plan B
I have a friend living in Leadville, CO (where it gets a bit cold!) who heats his house with hot water radiant heating installed in the ceilings. He has been happy with if for 20 years...
01-27-2013, 11:14 AM
Radiant heat with a liquid system would be pretty heavy for our trailers. It would be great in a house though.
Both of the websites listed show radiant heat with electric pads is about 150 watts. I agree. This isn't going to do much more than warm your flooring. You can probably overcome the heat loss through the floor by spray foaming the underside of the trailer.
01-27-2013, 11:46 AM
Or, you could convert all your LED lights back to incandescent.
01-27-2013, 12:15 PM
Let's see if I can drive you up one
I dislike the noise of fans, so for hookup camping I use two little "radiant heaters" that total 1500 watts between them. One's under the table and one's near the door. Their 1500 watts of heat warms the trailer and then some!
A heat mat measuring 1-1/2' by 5' is 75 watts...you'd need 1500 square feet to achieve the same "output" as my little heaters.
It seems to me that radiant heat is radiant heat, and all one needs in the case of these mats is enough room to place enough square footage to achieve the same result, only better dispersed.
My question is: since there's not enough floor, why not use the walls, and even the ceiling?
Since my trailer has only ensolite on the walls I s'pose I'd lose a lot of heat through them, but for someone with one that has reflectix-covered "rat fur", why couldn't that work?
Francesca
01-27-2013, 01:51 PM
Whaddaya mean? I am still trying to crawl my way back down again.
Those fan assisted cube heaters are still WAY quieter than the furnace fan, though silent would be nicer.
2017 Escape 5.0 TA
01-27-2013, 02:02 PM
I wasn't suggestion water based radiant heating, just that most fiberglass trailers have more ceiling space than floor space. While the panels in Leadville were behind the sheetrock, they do make electric radiant heating panels designed to go on ceilings, however most of them are 240V...
01-27-2013, 06:25 PM
Francesca
Here's a company that specializes in RV radiant floor heating. They specifically suggest using it in the walls. I think it was this site that also mentioned it was supplemental and not a full heat source. They can integrated the cabling with a fan at the start point to add more heat though.
STEP RV
Mark
1969 Boler (#183)
01-27-2013, 06:35 PM
Thanks, Mark
It's good to know that wall/ceiling applications are out there. It looks like the Step system's 24 volt, though I s'pose one could "step" down from 110v via some sort of adapter.
This has all certainly provided a lot of food for thought.
Francesca
01-30-2013, 07:05 PM
Originally Posted by glamourpets
.........They claim high efficiency, and this is a big plus...........
All electric heaters are 100% efficient.
02-05-2013, 09:22 AM
Trailer: Bigfoot 25RQ
IIRC there was a post by one of our members (Steve??? from SE MI) about 8 years ago about heated floor mats that he used. Interesting post, but I can't come up with it. Sorry.
I have searched the Internet for this item and they are available online.
