Radio Antenna - Page 2 - Fiberglass RV
Old 06-26-2003, 10:09 AM   #15
FYI
for the lower 48 group.............
<img src=http://www.fiberglassrv.com/board/uploads/3efb1a9ab9f8c4350.jpg/>
http://www.valcoelectronics.com/marine/4350.htm
"This 3' combination antenna features Shakespeare's exclusive distributive load for super signal pulling power. The coil is permanently sealed in Shakespeare's white fiberglass. A polycarbonate Lift and Lay mount is included. Includes 10' RG-62 coax with Motorola plug Mount: Integrated Lift and Lay mount with hardware is supplied. One section, 39" overall length" from their ad...
Old 07-02-2003, 08:57 PM   #16
Different am/fm antenna
Found this antenna at AutoZone for about $10 while I was shopping locally for one of the rubber antennas like Ches mentioned above. Metra Model #UA200 adheres to the fiberglass--I put it inside a cabinet. It is for use with an automobile style am/fm radio. It has a built in amplifier, so you must connect to a ground and a hot wire to the ''power antenna'' wire on the am/fm radio. So far it works great. Probably won't be as good as a large external antenna, but seems adequate and it's a cinch to install!
The web link is to Lafayette Radio, but it is half their price at AutoZone, if you have a store in your area.
http://www.lafayetteradio.com/universal_antennas.htm
Scroll down to 44-UA200
Old 07-10-2003, 09:33 AM   #17
Antenna
I just installed a car radio/cassettes in my trailer. I am using the alluminium frame of the small overhead cabinet as an antenna. Just bought the male plug part of the antenna, solder a wire with an aligator clip to connect to the frame.
So far, so good. AM or FM.
But I did not try it far from transmitters.
Alain
Old 07-10-2003, 09:50 AM   #18
Stuff it in
I installed a CD deck in the upper portion of my tall cabinet.
Although I've drilled many holes into my fiberglass during the restoration, I didn't want to put one in for the antenna.
I just left it extended and stuffed in the corner standing up in the back of the cabinet. It works very well.
I have a photograph of the stereo placement as the tenth photo down on this link:
http://www.fiberglassrv.com/board/read.php?TID=3011
Old 07-10-2003, 10:03 AM   #19
yes, the folks who suggested a marine application are right. The big problem with "auto" antenni on fiberglass is that you are dealing with a situation in that the surface does not produce a sufficient "ground plane" for the antenna. Unless you want to fool around with metal mesh (and mess) to adapt an auto antenna, go the marine application route.
Ham Radio Al POGUE Hobbies & Passions 103 10-22-2013 01:11 AM
Radio Antenna Sebastian H Modifications, Alterations and Updates 13 02-26-2010 09:31 AM
CB radio in BC ronsmith100 General Chat 10 04-23-2009 10:42 PM
target antenna TonyB Problem Solving | Owners Helping Owners 9 03-11-2008 03:17 PM
Antenna Question Chris C Problem Solving | Owners Helping Owners 31 03-11-2008 11:05 AM
