02-13-2017, 01:44 PM
Vermont
Rat fur first?
Hi All, I bought a Scamp which was completely stripped inside. Because of this, I don't know how the interior walls looked from the factory. This summer will be insulation/rat fur instillation. My question is, do I install all the fur first before riveting the cabinets back to their original placements or cabinets first then covering the blank areas. Thank you for all input, Nancy
02-13-2017, 01:47 PM
Insulation and rat fur first, then cabinets. You want continuous insulation across the shell; otherwise, cold spots allow condensation to form.
02-13-2017, 02:00 PM
Trailer: Fiber Stream
South Dakota
rat fur?
rat fur???? Ive been looking online for the ensolite but I have only found single squares. Ive read a few post on the rat fur, is that what it is really called. My fiber stream is an empty shell and I would like to cover all the walls and ceiling with something.
02-13-2017, 02:16 PM
Vermont
That makes sense because when I held the cabinets up to the wall, they didn't seem to fit snugly. I wasn't sure if they had deformed from being off the walls for a long while or there needed to be fur under them. Thanks Jon!
02-13-2017, 02:26 PM
Vermont
I will be using Reflectix for insulation and indoor/outdoor rug, don't remember the name, I purchased at Home Depot last year. I understand it is similar to the original fur like covering that is used in some trailers from the factory. Good luck Ronda
02-13-2017, 02:39 PM
Ronda, the real name for the "rat fur" is Marine Headliner, and it can be purchased in several colors.
Dave & Paula
02-13-2017, 03:26 PM
Trailer: Scamp 16, previously Scamp 13
None
Dave & Paula
Yeah, call Scamp and they will sell you the proper amount, or point you to their supplier who could provide many different colors.
02-13-2017, 03:37 PM
02-13-2017, 03:46 PM
Scamp's "rat fur" has a fairly long nap. It's thin and somewhat stretchy, so it's fairly easy to shape to the contours of the shell. It has a fuzzy touch, and it catches hair (I'm married with two daughters, so I know about hair!). Not a big problem- vacuums right off.
If you Google "marine headliner," you will find a number of other products out there in different shades of neutral (as far as I have seen). I've never run across anything quite like Scamp's. The other products have a much lower nap- more like a Berber carpet. From a couple of posts I've read, they're a little thicker and less stretchy to work with, but have a smoother touch.
Either would make a nice wall covering.
Carpet intended for floors usually does not make as good a choice because it has a stiffer backing, making it hard to fit the contours of the shell.
02-13-2017, 10:35 PM
Late thought... If the interior has been out for a while, it's very possible the shell has sagged a little and bulged out in the middle. You may find you need to put a brace between the floor and ceiling and apply gentle pressure to restore the original shape to get the cabinets to fit right. The door can be a clue. Does it fit tightly all around?
02-14-2017, 06:19 AM
Vermont
Door closes tightly and stays closed during transport. There might be a slight bow out at the bottom but the cabinets do fit in their original spots, just a little loose. The closet on the door side is still in place, though not riveted, so that may have kept the roof from sagging. Time will tell when everything else goes in! Always surprises!
02-14-2017, 07:36 AM
Actually that door closet being in place was a very good thing. Think of it as a structural column that doubles as storage. You will probably want to take it out to do the shell lining, and you would do well to brace the ceiling while it's out.
02-15-2017, 11:37 AM
Vermont
I'm encouraged by your positive input Jon! Redoing this trailer from scratch is daunting but with help from this site, I feel I will be successful........... more questions will follow along this journey I'm sure!
