Originally Posted by ontheroadagainace
...My ins. company is replacing my awning that got bent and broken in a high wind...the brackets broke too. Only 1 company have I found, so far, that will come to the rv court and reinstall one. They are having trouble finding anyone that sells the same size. I told them, I had read on the forum, favorable reports on the Tiammi..or some such....and they called them; only to find they had NO 10' ones...and even Scamp doesn't have 10'....I find that amazing...this old awning appears to be the original from A and E (maybe Dometic?).
They will have to refabricate it...and with THREE brackets instead of 2, like it came from Scamp.
Any advise...I am in Az. at present.
What year and model
Scamp do you have? Am I understanding that you talked to Scamp and they no longer supply the same size
awning on new builds? Their website shows a 10' awning as an option on the 16' models. I'm not understanding why you can't just use whatever they currently supply, including the brackets. The only complication might be that the bracket holes are different, so you will have to seal up the old ones. BTW... Fiamma is the one that lots of folks seem to like.
KC is referring to a bag awning, commonly used on tent trailers. Lots cheaper than the case awning you had but not as convenient to set up. It attaches to the trailer with an awning rail (C-channel) rather than brackets. Typically they cannot be as long as a case awning because the rail cannot mount on the compound curves at the front and back of the upper sidewall.
The truck camper awnings are just smaller case awnings. All case awnings are designed to be mounted on a flat, vertical sidewall. Special brackets are required to mount to a curved surface.
Another alternative to the factory case awning you might look into is a Shady Boy awning. The case is only 4' long, it weighs only 14#, and it opens out to 10'x6'. They supply brackets for mounting on
fiberglass trailers. Its design makes it less susceptible to wind damage.
http://www.shadyboy.com
