Real wood floors in a Scamp 1998 16? - Page 2 - Fiberglass RV
Old 06-03-2014, 07:02 PM   #15
Night Sailor's Avatar
Connecticut
Jim, so the cork is put down in tiles and then you seal it with urethane ? How thick is it ? And how is it on the feet for cushioning ?
Old 06-03-2014, 07:48 PM   #16
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Conrad, here is a link to my install. Note that I put down two layers of 3/16" tile, mostly for the warmth and comfort, but one layer would suffice. And yes, I sealed it with a few coats of a good water based polyurethane.
New Cork Flooring
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-03-2014, 09:58 PM   #17
Trailer: scamp
Jim I really like the way it turned out! Very nice!!
scamphappy is offline   Reply With Quote
Old 06-03-2014, 10:47 PM   #18
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Originally Posted by scamphappy View Post
Thanks again everybody for the advice and tips! It looks like I may have a book of dos and don'ts by the time i get around to doing this. Right now I'm facing a aesthetics dilemma on installing the floor. There is some kind of water hose under the side dinette table under the carpet. A hose and a small copper pipe along with wires. I think they will be exposed if I took out the carpet.
I had to deal with that when I installed my vinyl floor, as I have four water lines plus wiring running across the back. I ran a piece of aluminum channel across the back between the benches.
Name:	ImageUploadedByFiberglass RV1401857074.832319.jpg
Old 06-04-2014, 12:37 AM   #19
Trailer: scamp
Thank you Jared for replying and for posting a pic. That is a very good Idea. I am not sure if I could get away with that because the hose n wires run in a curve around the wheel well. :/ Ps nice kitty !! I wish I could post a pic of what I am working with but I am not sure on how to do post directly here like you did?
Old 06-04-2014, 05:38 AM   #20
Thanks, we really like it. It turned out to be everything we hoped for, and more.
2017 Escape 5.0 TA
Old 06-05-2014, 11:31 AM   #21
Connecticut
You did a meticulous job Jim and it shows. I've been thinking about doing something to replace the carpet under my dinette and the step up to the bed. Two small sections but difficult to keep clean. I have one piece vinyl and it is holding up OK except for a few dents from dropping things. It is easy to sweep out.
I have vinyl covered wood in places and that stuff! It is beyond stupid that they would use something that does not hold up and is difficult or impossible to repair.
Old 06-18-2014, 02:32 PM   #22
Trailer: Burro 13'. 1982
Montana
Question,
I pulled up the uninstalled carpet in my 1982 Burro. The only thing under it (besides the carpet pad) is the green fiberglass floor. It's bolted to the white fiberglass sides.
Should I be concerned? Should I install some type of plywood then lay the carpet back down?
Thanks!
Lfoxmont is offline   Reply With Quote
Old 06-18-2014, 02:34 PM   #23
Trailer: 1977 Scamp 13 ft
I think there is plywood laminated under the fiberglass in a burro. But I am not sure.
Can you post a picture?
David Morgan is offline   Reply With Quote
Old 06-18-2014, 09:02 PM   #24
Green Frog's Avatar
Trailer: '83 Burro
Virginia
Lfoxmont, I believe you will find that your original Burro floor is a sandwich of fiberglass over plywood over fiberglass. Unfortunately, the edges were not always sealed all that well and if water leaks around the windows, the plywood gets soaked and eventually delaminates, causing the fiberglass to heave and eventually allowing the floor to rot out. Make sure those window seals are working properly!
Froggie
Green Frog is offline   Reply With Quote
Old 06-19-2014, 09:57 PM   #25
Montana
This is what I see under the carpet pad.
Name:	ImageUploadedByFiberglass RV1403236669.756674.jpg
Old 06-19-2014, 10:06 PM   #26
Montana
So far, window seals are fine. The only place I had concern with was that the PO had wrapped carpet over edge of floor by the door extending it under camper. Took one trip with rain to bring that problem to my attention. I trimmed away the extended carpet, used aluminum carpet trim and finished the edge so there isn't anymore "wicking" from carpet being on the exterior.
I had thought about installing something else besides carpet but after three camping trips this Spring, I have grown to like the stuff.....so it will stay for now.
Old 06-19-2014, 10:36 PM   #27
Attachment 72724
That is interesting. It actually looks like the plywood has been cutout maybe? I don't know on that rig, but looks suspicious. Do you have more photos maybe zoomed out a little further so we can see exactly what's going on there?
Old 06-19-2014, 11:03 PM   #28
Montana
This is under the table section......Click image for larger version
Name:	ImageUploadedByFiberglass RV1403240577.682249.jpg
U-Haul ct-13 camper: just installed wood floors DanSturman Modifications, Alterations and Updates 9 10-26-2013 10:04 AM
Order new Scamp w/real wood doors only? melissab General Chat 15 03-14-2012 09:51 AM
floors ? Phillip Care and Feeding of Molded Fiberglass Trailers 7 06-08-2009 06:24 PM
Arlyn's question about laminate floors Arlyn R Care and Feeding of Molded Fiberglass Trailers 9 03-28-2008 09:11 PM
Walls and Floors Bonnie Problem Solving | Owners Helping Owners 0 08-22-2007 02:38 AM
