Rear bumper jack - Fiberglass RV
Old 10-23-2017, 12:16 PM   #1
Rear bumper jack
Can anyone with a Scamp please post some pictures of where/how the rear bumper jacks are attached to the frame?
Thanks!
jeroen is offline   Reply With Quote
Old 10-23-2017, 05:13 PM   #2
Here you go. They're bolted to the top of the L-beam bumper inside the frame rails. They swing up toward the center of the trailer and stow behind the bumper.
From the side (door side):
From the top:
Fram the back (street side):
Old 10-23-2017, 06:17 PM   #3
Thanks!
Old 10-23-2017, 06:24 PM   #4
I put a pair on the front on some square tubing I welded in to stabilise better than the front jack alone.
I lower the front with the jack, drop the rear jacks, raise the front a little higher than level and drop the front jacks and Bob's your uncle.
Old 10-24-2017, 07:08 AM   #5
JD...did you put them on pointing outwards like the rear? I've thought about that but if I added some, I would want them point towards the front of the Scamp (IF there's enough room to get the bar in there). The reason? I've noticed I get "movement" front-to-rear when it's stabilized. NO side-to-side. But the front jack AND rear stabilizers have enough "give" to let it do this. If the front two stabilizers could point forward, it would stop it.
Whew...just thought of something, they would have to be VERY secure and not let them drop down while you're on the road!! Or else >
I secure my rear ones with straps for added peace of mind.
Old 10-24-2017, 07:50 AM   #6
back jacks
My understanding the jacks are meant for stabilizing only am I missing something?
thanks
bob
Old 10-24-2017, 07:57 AM   #7
You're right...stabilizing only. But you can use them to "tweak" leveling a bit...I do.
thanks
bob
Old 10-24-2017, 07:58 AM   #8
You're correct, Bob. To confuse, Atwood calls them "stabilizer jacks," and they are capable of lifting, but Scamp does not recommend using them that way because of the danger of twisting the frame. Jacking (i.e., lifting) the frame should be done from the main longitudinal frame rail behind the axle. But as Darrell says, raising them a notch or two to fine tune the level won't do any great harm as long as most of the weight remains on the wheels.
Old 10-24-2017, 08:12 AM   #9
I put mine in where they fold to the rear so that IF they came down then would drag and not dig in.
Oriented this way they will extend towards the front and help fore and aft.
Quite possibly if you wanted the most stability having them in a vee with the legs at an angle towards the front would be optimum.
I happened to have two 1 1/2" tubes that carry the condenser unit for the heat pump and the entire front of my trailer is different and much modified so adding these jacks is a relatively minor mod on this trailer!
Old 10-24-2017, 09:45 AM   #10
Wow JD. That looks good. Nice mod! And you have them pointed the way I was thinking. Something I didnt think about but makes perfect sense as you mentioned, if they fall, they're going to drag to the rear. So pointed towards the front (when they're down) because of the way they're deployed is the way they will be most effective. First time I've seen this but like it.
Problem w/ scamp rear bumper jack alan H Problem Solving | Owners Helping Owners 9 08-23-2015 05:04 PM
Replacing Bumper Stabilizer Jack in '88 Casita Michele B Problem Solving | Owners Helping Owners 2 03-23-2011 02:32 AM
Storage Box for Rear Bumper Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 12 09-03-2009 05:22 PM
Need bracket for 4" rear bumper Michael Pupeza Modifications, Alterations and Updates 4 05-29-2009 07:53 AM
castors for rear bumper Legacy Posts Modifications, Alterations and Updates 5 01-17-2003 03:00 AM
