We fixed the 78
awning with new roller,
awning plus new push button. A&E Dometic told us parts no longer available; but remove the old arm caps and put the caps on new unit, the pin is larger on new unit so drilled out to closest drill size which was just under new pin size and put old caps on new awing. The small
awning push button arm release will install on our old awning arms fine difference is not enough to make a difference. Rebuilt all cupboards except back upper units with new paneling and hardware. Atwood small
furnace was a good match for our trailer; a bit of
fiberglass wall repair and gelcoating was needed on outside and a 2" platform under unit. New Arbrite on counter and table top now. Have to still do the floor
weight concerns have slowed things a bit trailer is heavier with all the changes; we have tried to add as little as posible, will have to check later to find out how much
weight we have added at least 200 or 300 lbs. All new waster lines, taps most of the window seals and did the weirs as well.
