Rebuild of a Trillium Sportsman - Page 10 - Fiberglass RV
Old 02-19-2014, 05:54 PM   #127
David bleed thru was one reason as Toms material is different that the original elephant skin. The main reason is that I have owned 4 Bolers and all had ensolite that did not hold on the surface because of heat, and regular contact cement cannot take heat for long periods of time without letting go. The HP15 I used I had used before on arborite and different paneling jobs and was very satisfied with the products performance, but I now have found it cannot take the heat. I will let everyone know what I find out. Vinyl roof glue for automobile tops is a type of contact cement but it costs about 200.00 a gallon. Hopefully there is no bleed thru with the cheaper stuff and it holds up to heat.
ryan parsons is offline   Reply With Quote
Old 02-19-2014, 07:46 PM   #128
Wisconsin
May I suggest contacting 3M for the spec details of their contact adhesives. Here is one likely product. 3M Rubber & Vinyl 80 Spray Adhesive
This neoprene-based contact adhesive is fast drying and fast bonding.
Featuring exceptional resistance to plasticizing oils, it forms durable, high-strength bonds to vinyl, leather, laminate, wood and most rubber and plastics.
Resists temperatures over 200F (93C).
Common Uses: Bonding flexible vinyl
3M Super 77 Multipurpose Spray Adhesive: spray aerosol adhesives, adhesive aerosols, aerosol spray adhesives product information, 3M U.S.:*3M™ Rubber & Vinyl 80 Spray Adhesive Product Information
DarrylScamp78 is offline   Reply With Quote
Old 02-19-2014, 08:06 PM   #129
Wisconsin
Ryan, for your rehab needs. I forgot to mention this very attractive marine grade LP cooktop - Force 10 (two or three burner models) is stainless steel and features thermocouple protection and electronic spark ignition.
FORCE 10 - Cooking Without Compromise - Products
I hope this is useful, as I owe you more than one on the vinyl and rubber flooring information.
Old 02-19-2014, 08:14 PM   #130
Originally Posted by DarrylScamp78 View Post
May I suggest contacting 3M for the spec details of their contact adhesives. Here is one likely product. 3M™ Rubber & Vinyl 80 Spray Adhesive
3M Super 77 Multipurpose Spray Adhesive: spray aerosol adhesives, adhesive aerosols, aerosol spray adhesives product information, 3M U.S.:*3M„ Rubber & Vinyl 80 Spray Adhesive Product Information
I have had good success with reattaching the rat fur and foil insulation on my Scamp using the 3M spray adhesive. It was actually what Scamp suggested i use when I asked. The key is to make sure you use it as directed and under the correct outside temp. If its to hot out or to cold when you use it, it may not work out so well. Spray it and wait a short time before sticking it together. My trailer has been in a number of hot weather situations over the past few years since using it and none of what I have stuck up using the 3M spray has come down.
Old 02-19-2014, 10:05 PM   #131
Thank you Carol, will source out a can and give it a try this spring. Hp 15 also had the same claims. The foam has no problem holding on to the glue, the glue lets go of the fiberglass and is solely stuck to the foam. The rat fur we used on all the houseboats at Waterways in Sicamous would stick to anything with contact cement except fiberglass the glue would sit there until a little pressure would pull it off. The silconized version of the 3m might be the answer I am looking for. Thanks again
Old 02-20-2014, 10:19 AM   #132
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Wow- $375.00! I'm likin' the thermocouple shutoff that shuts down gas to a burner if the flame goes out, but still...
Is "marine-grade" some kind of designation that requires other special doo-dads that drive the price up?
Old 02-20-2014, 08:28 PM   #133
375 is a good buy! I would have to add 81.00 shipping 12 percent tax and 12 percent difference in money and brokerage fee of 35.00 so total cost to me landed at my door is 581.00 CDN funds not so good for me. Marine grade would have a thermocouple and a higher grade of stainless steel and most likely be lighter, as weight is a big deal in boat quite like these small trailers. Thank you Darryl for the heads up on the cooktop.
Old 02-24-2014, 09:49 AM   #134
Have got all the hardware for the cabinet doors now. mocked one up in kitchen yesterday and took some pictures. first pic is of door with hinges and latch setup. The second is of latch with the three sizes of catches. I had to make up small block to get them to work for my doors as I did not want to inset cabinet doors with dadoes or flush fit. The latch is like old time commercial freezer latch, it is spring loaded, it feels like quality should do the job perfectly.
Old 05-02-2014, 08:24 AM   #135
cabinet doors installed
Now that the weather is getting better I am getting a few of the last items installed. The cabinet doors and latches got installed on the weekend. (pics attached) Sorry about the sideways shot stuff just happens.
Next items to get done - exterior signage, and axle.
Old 05-02-2014, 10:01 PM   #136
Ryan, I follow most builds and major rehabs. But I have to say yours is extra special because of the uniqueness of the model. Thank you for letting us follow along!
Old 06-04-2014, 08:35 PM   #137
Still following..
Old 06-05-2014, 12:23 AM   #138
David Tilston's Avatar
I'm glad Ryan got this Sportsman, because I would have made it into a utility trailer. I would have closed up all the holes, except that wonderful back door, well all the doors of course, each with a window in them, and the front window, with it's rock guard. Then, I would have put in a two person dinette in the front end. For lunch, and paper work. A desk of sorts. Some place to stack a very small fridge and microwave. Maybe where the closet would be on a 4500, above the wheel well. That's it on the inside.
On the tongue a 2000W Honda generator, modified to run on propane, and a 43 lb forklift tank, with two 6V golf cart batteries.
And most important, a re-engineering of the frame. A utility trailer has more then a 2000 lb axle.
Yup, I dream in Technicolor (tm).
Old 07-23-2014, 05:50 AM   #139
Baltimore, MD
Hello, I am interested if you could explain a little more about your interior window wood frames. Did you replace the wood on the interior of the fiberglass body as well? Does the window actually attach to the new interior wood frame you built? When you rebuilt your windows I am guessing you must have also replaced all the weather strips....could you provide where you found the replacement weather stripping? Thanks so much for giving me an additional tutorial...I just bought a 77 trillium 4500 that need TLC and $$$
billiam1969 is offline   Reply With Quote
Old 07-23-2014, 08:58 AM   #140
interior window frames
The window frames are made from Vertical Grain Douglas fir (clear) the size is 1 1/8" x 2 1/4" I stained them, then applied 3 coats Varathane and then made the frames for. Glued each corner and used flush head screws to make sure it stays together. To install My wife held the frame on the inside and I screwed it in place from the outside sandwiching the ensolite fiberglass and seal tape. I put in all of the screws snugly then began to tighten alternating from left to right and up to down until all the screws where tight and some of the seal compound squeezed out.
The weather stripping you can purchase at Vintage Trailer SupplyClick image for larger version
trillium
Triple E sportsman 15 ft miles172 Problem Solving | Owners Helping Owners 0 08-19-2012 09:25 AM
Trillium Rebuild Upcoming David Schroeder Forum Admin, News & Announcements 1 12-09-2006 08:55 PM
Trillium Axle Rebuild...possible? Joseph Olajos Towing, Hitching, Axles and Running Gear 13 10-15-2006 06:26 AM
1948 Mobile Sportsman Tom Trostel General Chat 1 11-14-2005 10:21 AM
» Trailer Showcase
Huevo Duro
DaveW
2017
Mfrost
