Rebuilding 13' 1982 Scamp - Fiberglass RV
Old 12-09-2012, 07:50 PM   #1
stevewolverton's Avatar
Trailer: 1982 Scamp 13'
Hi All,
My girlfriend and I are currently rebuilding an '82 Scamp. We started this summer and have been working off/on during the weekends.
Here are a few pics of the progress.
This is the camper the day we brought it home. The first thing we did was start gutting the interior. The floor was shot as it had a leak in the back.
Steve
stevewolverton is offline   Reply With Quote
Old 12-09-2012, 07:52 PM   #2
We removed the body from the frame. Most of the screws were rusted substantially, so I ended up breaking most of them and drilling other. It took about 6 hours to get the body/frame separated.
Old 12-09-2012, 07:54 PM   #3
With the frame on saw horses I began the task of removing rust with a wire wheel. I also cut the old axle off as it was shot. The back bumper area had a lot of rust so I decided to cut all the bad metal and weld new material/support.
Old 12-09-2012, 07:57 PM   #4
This photo shows the old axle removed and the new axle in place. I went with a Flexiride adjustable axle. I had to do a little fabrication work to get the new axle in place, but I think it was well worth the effort.
Old 12-09-2012, 07:59 PM   #5
New steel was welded to section directly behind the axle. New steel was also added above the axle mount. I also ran a crossmember under the floor.
Old 12-09-2012, 08:00 PM   #6
This photo shows the new steel sections cut for the axle mount.
Old 12-09-2012, 08:01 PM   #7
While working on the frame, I also removed the floor from the camper, and stripped all the insulation. Only the floor in the rear was rotten, but I figured I might as well go ahead and replace it all while I had the frame/body separated. I used 3/4" ply for the floor.
Old 12-09-2012, 08:03 PM   #8
I had to replace some sheet metal at the door entrance (not shown in photo but it's the piece of metal at the doorway) and I'm welding the floor crossmember in place. You can see the extra steel that's welded between the axle and the frame to beef that section.
Old 12-09-2012, 08:06 PM   #9
This picture show the dropped floor I added to the center of the camper. I'm 6'1" and my head touched the ceiling with the standard floor. I dropped the floor 5" and can now easily stand in the camper without hitting my head. 3/4" BCX ply was used for the floor.
Old 12-09-2012, 08:08 PM   #10
We live on the Texas Gulf coast and it's quite miserable without AC. We decided to do away with the front/rear windows in the camper. The front window was removed because we're converting the front to a bathroom/shower. The rear was removed because we spend most of our time outside the camper, and like it dark. I used 1/4" plywood, fiberglass, and woodflour and glass bubbles to seal the window. This picture shows the cutout for the AC.
Old 12-09-2012, 08:12 PM   #11
We didn't like the 80's style square windows so we ditched them. I found some 20" x 24" windows on Ebay for $10. I We also hate the fact that Scamp uses rivets to hold everything in place. We removed all the rivets, and glassed the closet, and the kitchen fiberglass piece in place. We then filled all rivet holes with epoxy. One of the first jobs we did on the body was to fill the kitchen vent and window holes on the side.
Old 12-09-2012, 08:14 PM   #12
The seat areas are glassed to the body. The windows have their own frame built using pocket hole jig and are also glassed to the body. This picture shows the installation of the foam insulation.
Old 12-09-2012, 08:18 PM   #13
We hated the lower fiberglass kitchen cabinets, so I built my own using 3/4" MDF. We also decided to ditch the settee in the back and make the bed platform permanent. I used 3/4" plywood for the platform. We decided that the bed would be more comfortable without all the seams of individual cushions. I've had the cushioned settee before and would always manage to end up swallowed in them in the mornings. Solid bed = no seams = better for us. The cabinets are also 3/4" MDF. The cabinets are getting skinned in .040" brushed aluminum. The kitchen backsplash wood is 1/4" and it's just there to support the aluminum. We're getting a custom kitchen counter, just not sure which type yet.
Old 12-09-2012, 08:21 PM   #14
This photo was taken on the bed platform facing forward. The bathroom wall was built from 3/4" ACX. The bathroom door and closet door are also 3/4" MDF, and will be skinned with .040" brushed aluminum. The floor is laminate. The floor trim is 3/4" MDF and edged with a 1/2" roundover bit.
Newbie rebuilding Scamp 13 BOBco. Hi, I am.... 11 11-13-2012 09:16 PM
MN | 16' 1982 Scamp koolperson2 Classified Archives 1 06-09-2012 08:18 PM
Rebuilding a Bigfoot 5th Wheel Tom Y Modifications, Alterations and Updates 19 02-22-2012 10:29 AM
Rebuilding my scamp Ronny W Problem Solving | Owners Helping Owners 8 12-25-2005 08:11 PM
The rebuilding of the surfside Legacy Posts Modifications, Alterations and Updates 2 03-07-2003 09:30 AM
