Rebuilding Predom trailer in Croatia - Page 3 - Fiberglass RV
Old 10-09-2016, 02:06 PM   #29
Trailer: Predom (Cadet)
Croatia
Next step was repairing chassis, i waited for a welding man couple of weeks. Finally, we removed rear end of a chassis, it was bent due to a broken stabilizer. We made completely new rear end and also added some kind of "rear bumper", but i still don't know the purpose for it.
Miro is offline   Reply With Quote
Old 10-09-2016, 02:07 PM   #30
Croatia
More pics - extension
Old 04-03-2017, 02:53 PM   #31
Croatia
Springtime is here
It's time to continue...
This is how painting in the garage looks like:
Old 04-03-2017, 02:55 PM   #32
Croatia
And this is after it's done:
Old 04-03-2017, 02:58 PM   #33
Croatia
Two layers of Hammerite - direct to rust
Old 04-07-2017, 07:22 AM   #34
Trailer: 1999 Casita 17' SD
Ohio
Miro.
Looking good!
Joe
Old 04-08-2017, 07:23 AM   #35
Croatia
Originally Posted by Joe Romas View Post
Miro.
Looking good!
Joe
Thanks, Joe, doing my best
Old 04-08-2017, 07:53 AM   #36
Croatia
Wheel bearings
A few days ago, I started changing wheel bearings. Finished left side, everything was simple as it should be. When I dismounted right hub, found a pretty mess with the inner bearing. Someone drilled a larger diameter and pressed cylindrical roller bearing instead of a tapered. Now I have a problem to put it to the previous state.
Picture shows the inner race of a faulty bearing
[IMG][/IMG]
Old 04-22-2017, 01:49 PM   #37
Croatia
Few more pics:
Old 04-30-2017, 11:46 AM   #38
Croatia
on the wheels again
She's on the wheels again
Next step: the floor. The idea is to fill "waves" with water resistant PU foam, then lay two layers of OSB plates. The problem is where to buy water resistant PU foam
Old 04-30-2017, 03:08 PM   #39
Mike Magee's Avatar
Trailer: Li'l Hauley
I don't know where to buy it, but I am pretty sure that the denser the polyurethane foam, the more it sheds water. So you're looking for a spray that will form a dense (higher weight) foam. I believe Jan Pregowski in Poland either has dense PU foam or knows someone (they use it in the construction of monolithic dome structures); I know Poland is quite a distance from you, but if you can't come up with any other sources you might try Jan. His website Kopuły Monolityczne, Konstrukcje Monolityczne, Budowle Monolityczne, Budowa Kopuł | Monolityczne Konstrukcje MCP contains contact information.
How to prepare Tofu
Step 2: grill some meat
Old 05-01-2017, 08:42 AM   #40
Jennifer Minogue's Avatar
Trailer: Predom Prespol from Poland
We have "foam" stores so easy to get closed cell ensolite foam. Try a boating store as they use lots of foam too. We also used boat hull liner glued to the foam. Boat hull liner will actually let water flow right through. Doesn't get moldy. You can use Velcro on it.
Make sure you get glue that won't dissolve the foam. Foam supplier May have the glue too.
Jennifer Minogue is offline   Reply With Quote
Old 05-01-2017, 01:34 PM   #41
Croatia
The polyurethane foam I'm talking about is used to fill the lacuna between two layers of fiberglass in a boat building. It is a closed cell foam, so it does not absorb water. I need a small amount, 50-60 l of expanded foam. I hope to find it as a spray, that is my next errand.
Old 05-01-2017, 02:07 PM   #42
Croatia
Mike, I'm actually planning to go to Poland for some spare parts for my trailer. But I'm searching for a small package of foam as a spray, and industry like Jan's is using large machines. I doubt I could use it my case.
New member from Croatia Miro Hi, I am.... 15 08-03-2016 04:02 PM
Manual for Predom Prespol Jennifer Minogue Care and Feeding of Molded Fiberglass Trailers 25 09-07-2012 06:20 PM
Predom N126D or Captain Trailer Lorraine K General Chat 11 03-23-2006 05:07 PM
Rebuilding my scamp Ronny W Problem Solving | Owners Helping Owners 8 12-25-2005 08:11 PM
The rebuilding of the surfside Legacy Posts Modifications, Alterations and Updates 2 03-07-2003 09:30 AM
