Reflectix insulation - Page 3 - Fiberglass RV
Old 02-22-2006, 04:14 PM   #29
pjanits's Avatar
Trailer: 17 ft 1986 Burro
This is not from personal experience, but maybe someday it will be. I hope.
BIGFOOT rated for 30 below camping. Now you're talking.
http://www.bigfootrv.com/traveltrailers/index.html
Old 02-22-2006, 04:20 PM   #30
pjanits's Avatar
I pushed the relectex up as far as I could in between my Burro walls,closet and upper and lower cabinets. Camped last fall for a week. It got fairly cold and with the ceramic heater felt ok. The rear windows radiated cold though so I cut some refectex to wrap around the sides and back. Excellent! very cozy, but I couldn't see out.
My guess is that would do for us down to about 20-25 degrees, any lower than that I couldn't pay the wife to camp.
We have camped in Yellowstone in July with night temps down to 32 without insulation and it was fine with just the ceramic heater. I guess that wind has a lot to do with it too.
Old 02-22-2006, 04:47 PM   #31
Hmmm!!! Wonder what that means. People camp all the time in cold weather. Proper clothing and a good sleeping bag are the important things. A good snow cave will maintain about 40F. Therefore I would guess that at -30 the inside of the Bigfoot will be close to 40
Now I'll go hide.
Old 02-22-2006, 06:39 PM   #32
pjanits's Avatar
Foam insulation between the walls ( looks like about 1 1/2 inches or so), tanks are in heated insulated area, thermopane windows and 30000 BtU heater.
Might be more like 70 degrees.
Granted they are much heavier than a regular egg ( and pricier) .
Casita people seem to be happy , I remember Charles was comfortable and he's a big winter camping buff.
I don't recall any Scamp owners talking about it.
It doesn't really matter though, the wife would never go in that weather.
Old 02-22-2006, 08:20 PM   #33
Brian B-P's Avatar
Foam insulation between the walls ( looks like about 1 1/2 inches or so)...
According to both Bigfoot and various owner reports, the insulation is 1.5" expanded polystyrene foam bead board. The Bigfoot specs claim R8, presumably for the complete wall or ceiling structure, since 1.5" bead board will be something less than R7.5.
I have slept in a tent trailer with overnight temperatures just hitting freezing, with no heat source (we had one, just didn't bother starting it...), so I agree that usable and warm are not the same thing.
Our Boler B1700 has the typical insulating lining for that model, which is a lighter (and probably much less effective) foam than the classic Ensolite. A 1500 W heater did not need full power to keep it warm enough at just below freezing, but the temperature was quite uneven and I would certainly prefer much more insulation (plus better windows like those current Bigfeet).
Old 02-25-2006, 08:46 PM   #34
don bowman's Avatar
Trailer: 87 Casita Liberty Deluxe (restored)
I just ran across your posting on insulation.
I have a '87 Casita and Christmas of '04 my brother-in-law moved to Muleshoe, TX. I took a week vacation to go and wire his new 60x80' aluminum fabrication and paint shop. The weather turned COLD! , 6 to 10 degrees daytime. He did not have a house yet, so I stayed in my Casita. The cold would flow through the walls and drift across the bed like the windows were open. I had a electric heater going and the gas range burner on low ( carbon monoxide detector installed ) to add some heat to the interior. The cold would still flow across the bed, so I had to run a fan mounted near the ceiling to mix the cold and warm air. This stopped the cold drifting across the bed.
My brother-in-law was so appreciative he offered to do a make over on my Casita. So, Christmas of '05 we stripped the upper cabinets and lower cabinets out, except for the refg section and sink/range section. We took all the old foam backed carpet out and installed the foil double bubble insulation on the walls and them covered it with auto upholstery carpet and a outside paint job. It looks like a new rig again and I'm exceted to see how much difference the foil double bubble is going to make. I will test it in the hot summer heat , I hate COLD and hope to never be in those low tempts again.
Just had to share,
don
don bowman is offline   Reply With Quote
Old 02-26-2006, 06:43 AM   #35
Suz
Suz's Avatar
Welcome, Don!
There's only one thing we like better than to hear about modifications and fix-ups and that's SEEING them. Do you have any pictures? Why don't you start your own thread HERE. Simply click "New Topic" on the upper right hand side and tell and show us what you've done to your '87.
Suz is offline   Reply With Quote
Old 02-26-2006, 07:03 AM   #36
don bowman's Avatar
I have not taken pictures. But, I will get some in the near future and post them.
Thanks for your reply,
don
Old 02-26-2006, 03:23 PM   #37
Con
Trailer: 1977 Boler 1300/2003 17' Bigfoot
In about Oct 2004 we stopped to visit friends over night in a place called East Barriere Lake about an hour from Kamlops,B.C. Where they live is fairly high above the river valley and and the temp. dropped to almost -20F (-8C) and it frozze the water hose and our sink drain etc. Most of the night I kept a small cube ceramic heater going and we were quit comfortable.
Our Boler is lined with Ensolite and I was impressed with the fact that it kept the inside reasonable. Also there was not a great amount of condensation other than some frost at the bottom of the windows. Desipte what some people may think about Ensolite, I think it does a pretty fair job of insulating.
Con is offline   Reply With Quote
Old 02-26-2006, 08:02 PM   #38
don bowman's Avatar
Con,
I have been reading about the insulation of the Boler and I'm very impressed with the construction and the insulation of this maker. I wish the Casita was constructed as well. As I said in my post I froze in mine at 6C degrees, I had ice on the inside window seals. Hopefully the new foil double bubble will help, but I know it is not as good as a foam board insulation.
I live in the Texas Hill Country for a reason.
don
Old 02-26-2006, 09:24 PM   #39
Con
Don,
I have yet to see a Casita up here in British Coliumbia so I can not make a constructive comment on the good or bad points of them. Before we bought our Boler we borrowed a friends TRIPLE E ( looks almost identical to the Trillium) It was lined with Ensolite the same as the Bolers. If I was going to replace the lining I would certainly redo it with Ensolte as it is allready textured, colored and acts a sound proofing and insulation. I don't know the actual R value of it but it sure would not be fun in the cold without it. All that been said, anything that is light weight and acts a air barrier and sound proofing is better then next to nothing.
There has been some suppliers of the Ensolite added to the "Helpful Links" pages if you want to pursue that type of liner. I seem to remember a thread before the site was hacked about a few people who replaced thier Ensolite liners.
Donna might be some help there, Where are you Donna?
I was lucky, Our Ensolite is almost mint condition and the people we bought the Boler from had found some replacement "T" mouldings for the joints.
Keep us posted on how yours works out and what problems you run into.
Old 02-26-2006, 11:47 PM   #40
don bowman's Avatar
I look around on the net concerning the construction of the Boler and I don't think it is the one I'm think about. I saw a cut throught section of one of the trailers, it had fiberglass top / 1/2" plywood / thick white foam insulation / plywood / fiberglass construction. This one sure looked solid. The person could walk on top of this trailer.
How quick I forget. It was some where in this link.
Old 02-27-2006, 09:24 AM   #41
Brian B-P's Avatar
... I saw a cut throught section of one of the trailers, it had fiberglass top / 1/2" plywood / thick white foam insulation / plywood / fiberglass construction....
That's a current-style Bigfoot, not Boler. The insulation is the 1.5" expanded polystyrene foam board which is referred to in the Bigfoot specs.
The post with the cross-section photo may have been lost in the hacking; although I thought it was newer than that, I couldn't find it in a quick search.
Old 02-27-2006, 12:03 PM   #42
Bill Abbay's Avatar
Trailer: 2002 21.5 ft Bigfoot / 2003 Chevy Duramax 4x4
It's on my site, Bigfoot Mods (below), under Odds & Ends.
Bill Abbay is offline   Reply With Quote
Insulation Rick T Problem Solving | Owners Helping Owners 8 03-22-2009 06:56 AM
Reflectix needed Bonnie Classified Archives 6 04-17-2008 07:17 PM
Add Reflectix Under Mattress Pete Dumbleton Modifications, Alterations and Updates 0 04-16-2008 10:36 PM
Applying vinyl on reflectix- need help Mo22 Problem Solving | Owners Helping Owners 3 05-28-2007 11:58 AM
Insulation Willie Brown Ft. Langley B.C. Rallies 0 12-31-1969 07:00 PM
