Refrigerator conversion - Fiberglass RV
Old 07-07-2014, 06:42 PM   #1
Trailer: Hunter
USA
Hello! We have a new Hunter and the fridge only works when we are plugged in. We are camping in a lot of National Park/Forest sites that don't have electric. We use it as an icebox then, but we are full timing and going through a lot of ice! Is there any way to make the fridge run full time? We have a small battery for some lights and the water pump. Can we hook it up to that with an inverter? We bought a little solar charger to keep the battery charged.
Thanks!
juliep1114 is offline   Reply With Quote
Old 07-07-2014, 07:16 PM   #2
The Minimalist's Avatar
Louisiana
Is it AC only. What is the make and model number?
Old 07-07-2014, 07:43 PM   #3
David Tilston's Avatar
If it is a three way, the fact that it works at all means that it can be made to work on propane. It probably just needs the lines cleaned. Apparently spiders love propane lines.
Old 07-07-2014, 11:50 PM   #4
Trailer: Hunter
USA
It's not a 3 way, AC only.
Old 07-07-2014, 11:54 PM   #5
Trailer: Hunter
USA
And it's a frigidaire, not sure where to find the model number. It's not very old, though.
Old 07-08-2014, 12:55 AM   #6
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Julie it looks to me that you are in for a new 2-3 way refer. You're kind of between a rock and a hard place. Solar or an inverter won't do it. With out park 110V your only option is a generator to run it. Personally, I wouldn't even think of a genny for anything more than coffee and the microwave. Not sure if you have LP but it is the way to go for boondocking. Sounds like your refer is a dorm style unit.
Borrego Dave is online now   Reply With Quote
Old 07-08-2014, 07:38 AM   #7
MCDenny's Avatar
Trailer: Lil Snoozy
It sounds like you have a dorm fridge if it just runs on 120AC. There is no practical way to use that except plugged in. Same situation I was in. You can put in a propane fridge and the propane system to support it ( most common solution) or get a 12v fridge, a good size battery (at least 200ah) and a solar panel. Probably looking at $1000 plus either way.
I chose the 12v path and couldn't be more happy with the results.
Dave's right, it will run on a generator but that's not a 24/7 solution plus a little Honda super quiet genny is still IMHO quite noisy, costs $900 and requires lugging its 53# plus a can of gasoline around.
Denny Wolfe
Wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 07-08-2014, 07:54 AM   #8
Louisiana
Post in the Classifieds here, Parts for Sale/Wanted, for a Dometic RM2191, DC/LPG, or RM2193, AC/DC/LPG or equivalent. You may luck out. be specific about your location, as you may want to check the unit personally to ensure that it works to your satisfaction, ei: try before you buy.
Of course I'm assuming you have LPG, but most do.
If you want to know more on what's involved, go to the top of the page, click on 'more', click on 'Document Center', click on 'Refrigerators'. You will find the manual for the RM2191/2193 there.
Someone else familiar with Norcold could guide you to the Norcold equivalents of these units.
Old 07-08-2014, 08:22 AM   #9
Timber Wolf's Avatar
North Florida
I am in the same boat and am researching one of the 12V compressor refrigerators. They are pricey but I consider it an investment in my long-term plans for boondocking utilizing solar panels to charge the battery(ies). There is Engel, Norcold, and I think one other that escapes me right now. $600 and up. I just can't see spending the money to go with a new 3-way (120v, 12v, propane) with solar as cheap and available as it is these days.
Old 07-08-2014, 09:11 AM   #10
I camp 50/50 on and off of power and personally wouldn't want a fridge that didn't run on propane. Even though I have solar I want a fridge that uses as little power as possible for those times I am camping in a heavy tree canopy (which is fairly often) or in rainy weather with little sun. I like to save what power I have for the furnace on cold nights etc. Have a couple of friends I camp with who have the Norcold 12 v compressor fridges - both fairly new and they struggle with the power consumption when we are dry camping for more than a couple of days in less than ideal weather.
Old 07-08-2014, 10:02 AM   #11
North Florida
Different strokes, I live in Florida (don’t need much heat) and don’t want (any) propane in the trailer. Been there, done that, got the T-shirt. It is a personal phobia but one that will certainly not kill me so I live with it. I am not an expert and don’t know for sure but suspect that properly sizing the solar system and batteries would go a long way to solving any energy drain problem. Committing to a 12V refrigerator may mean there will need to be more engineering of other systems to accommodate it. For example, I am considering upgrading (modernizing) the converter in my trailer and wonder if I should go with a 60 amp rather than the more traditional 45 amp version since I am planning on adding a dedicated 12V refrig.
Old 07-08-2014, 12:00 PM   #12
A 12vdc fridge takes on the order of 2-3A:
DE-0041/EV-0041
A 45A converter is already overkill. In fact, about 100W of solar cells, and a group 27 battery will run a typical 12 vdc fridge. No shore power required.
Old 07-08-2014, 12:39 PM   #13
Originally Posted by Timber Wolf View Post
Different strokes, I live in Florida (donít need much heat) and donít want (any) propane in the trailer. Been there, done that, got the T-shirt. It is a personal phobia but one that will certainly not kill me so I live with it. I am not an expert and donít know for sure but suspect that properly sizing the solar system and batteries would go a long way to solving any energy drain problem. Committing to a 12V refrigerator may mean there will need to be more engineering of other systems to accommodate it. For example, I am considering upgrading (modernizing) the converter in my trailer and wonder if I should go with a 60 amp rather than the more traditional 45 amp version since I am planning on adding a dedicated 12V refrig.
NOTE---- Scamp wiring is designed for 20 amp maximum. A larger converter with a big load like you're talking about requires rewiring Scamp with bigger wire.
Old 07-08-2014, 06:22 PM   #14
Assuming you have some sun/daylight
refrigerator
Honda Genny conversion and Box Michael Pupeza Modifications, Alterations and Updates 2 02-23-2011 02:20 PM
Propane conversion of Honda Genny! Michael Pupeza Modifications, Alterations and Updates 3 06-03-2009 09:46 AM
Conversion of Scamp 5th Wheel Hitch Nita F. Modifications, Alterations and Updates 5 04-14-2009 09:21 PM
Cool Conversion Candi Woods General Chat 1 03-17-2009 09:50 PM
My miniVAN pseudo-RV-conversion project Ken Black Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
