Refrigerator Ventilation Fan - Page 2 - Fiberglass RV
Old 08-04-2013, 08:45 AM   #15
Roy in TO's Avatar
Originally Posted by RRJR View Post
If you check the weather radar all our bad weather seems to come from down under.especily here in southern Ontario.
I disagree. It seems to come from the wet coast.
Back to the fridges ...
http://www.fiberglassrv.com/refrig-fan.php
Performance of 3-way absorption fridge
too much ventilation in fridge
Old 08-04-2013, 11:30 AM   #16
Trailer: Trillium Outback - 2004
My 2004 trillium also has a DC only fridge (Nova Kool). If it's the same as mine it's already wired for a fan. There is a +- spot you can plug one into and it will cycle with the fridge. There should be a wiring diagram on the back of the fridge.
I added two fans recently and they work fine. Camping in Radium BC last week it was 40 degrees (C) and the fridge kept everything cold/frozen. It was on almost the entire time during the day so I'm not sure the fans helped much. However keeping the fridge side shaded helped drop it's cycles significantly. Shade or sun the fridge temp was good so the fans either helped or the compressor just works well regardless.
Where were going, we dont need a plug-in.
multi-task is offline   Reply With Quote
refrigerator
Refrigerator Exhaust Fan jimmied Modifications, Alterations and Updates 6 05-23-2013 11:42 AM
Ouestion about putting a fan in refrigerator Kevin K Electrical | Charging, Systems, Solar and Generators 22 01-05-2013 11:47 PM
Bigfoot refrigerator fan Tim D. Modifications, Alterations and Updates 6 04-20-2011 10:27 AM
Valterra Refrigerator exhaust fan Lisa H. Care and Feeding of Molded Fiberglass Trailers 15 07-14-2008 05:01 AM
13' Scamp Ventilation Fan Legacy Posts Modifications, Alterations and Updates 5 11-22-2002 04:01 PM
