Refurbishing a 1975 13' Scamp - Page 3 - Fiberglass RV
Old 07-28-2013, 08:20 PM   #29
New Hampshire
Originally Posted by AM Moats View Post
Thanks for the advice. My father is headed out in his RV for a few weeks so I have some time to research before we start the door. Mike, I don't see a link on your reply but the picture looks very interesting. Am I missing the link (I'm using the iPad app right now) or did it not come through?
Sorry about that, here you go:
Freeing up old jalousie windows, cranking mechanisim
msinger919 is offline   Reply With Quote
Old 07-29-2013, 01:45 AM   #30
GMike A's Avatar
Im still looking. Donna probably has the link. the best way to find anything on this site is to use the internal Search Site/ Google input and tons of data will come up. Then go to the very bottom when you read it and it will suggest similar threads. I found several great ideas and how to just in a few minutes.
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-29-2013, 05:04 AM   #31
Trailer: shopping
Exclamation 1976 Scamp rebuild
Hi, I'm in the process of rebuilding a 1976 Scamp I just bought earlier this month. Since I will be going thru the same things you just did, I will be wanting to ask you some questions as they come up, if that's Ok?
One question I already have is can you send me an example of the VIN number on your trailer. Mine is located on the passenger side of the hitch. I look at some example I found at the Scamp web site but they did not match any of their examples. I want to find out for sure what trailer it is.
Another one is: what did you use to make small patches on the outside of the trailer and how much did you sand the outside of the trailer before coating it with .......?
EarlM is offline   Reply With Quote
Old 07-29-2013, 04:34 PM   #32
AM Moats's Avatar
Trailer: 13' Scamp
Earl,
I certainly know what you are about to go through. I can't wait to get mine on the road! I'll be glad to help in any way that I can, but I'm sure you'll find much better advice from others more experienced on this forum. I've been searching it regularly to gets hints.
I'll go look for the VIN and send a photo later tonight. We used Bondo to patch the holes. ( I just recently saw a post from someone recommending a filler used for marine applications. If you are really concerned about water you may want to find that post. I don't recall what the material was.) We drilled the holes a bit from the outside with a countersink bit to widen the hold surface first. We put a piece of duct tape on the inside to keep the bondo from pushing the whole way through. I also just saw someone else's recommendation that you fiberglass the inside and then fill the outside. We could still do that, but I haven't decided if I will yet. We are having a family friend do the painting. He does auto restorations and I'm not sure what paint he's using. (I just get to pick the colors!) We've done rough sanding with sandpaper, but he's also going to do any fine finish sanding for us.
I hope this helps. I'll keep an eye out for the thread on your project! I'm anxious to watch your progress too.
AM Moats is offline   Reply With Quote
Old 07-29-2013, 07:53 PM   #33
Were you asking about a door repair? There's a couple of EXCELLENT writeups in the Document Center. Read both, you may find info in either that helps you: Fiberglass RV - Document Center - Exterior
Old 07-29-2013, 07:55 PM   #34
Earl, does this help? http://scamp.n0kfb.org/VIN_Decoding/VIN-Decoding.htm
Old 07-31-2013, 09:14 AM   #35
tartosuc's Avatar
Trailer: 2007 uhaul ct13
Quebec
Originally Posted by GMike A View Post
There are several articles of fixing the door. This is only one of many. The internal Google search will show the others.
Either I or someone else will post links after they read your info.
Good Luck
so who did that fix?
i searched but could not get a thread about it?
i would like more details on that one..
tartosuc is offline   Reply With Quote
Old 07-31-2013, 11:45 AM   #36
GMike A's Avatar
Here are three more to read through. Also on the second one. Tom is still a member and says the door is holding fine. you can go through that. Gary (fusedlight) talked to the original person who did the mod. Perhaps he can chip in too.
74 BOLER: I fixed the door gap.
Lots of Scamp modifications
door on `98 scamp won't seal
Mike
K5NAN
"Miss Adventures"
Old 08-03-2013, 03:02 PM   #37
Trailer: 1978 Scamp
We recently purchased a 1978 13ft Scamp and are in the processing of renovation and remodeling. One of our big problems is the tape that was used on the seams inside the Scamp. What do we use? Thanks!
Connie SS is offline   Reply With Quote
Old 08-03-2013, 09:51 PM   #38
StacyJayT's Avatar
Trailer: "79 Scamp "Tiny Tow"
Seams
Connie,
I just got a 79 Scamp and working on it. Most in here posted to not use the tape, but a flexible seal, like silicone. Then some went to the added trouble to use a sponge while still wet, so that it would more resemble the ensolite when dry.
Have fun with you remodeling!
Stacy
StacyJayT is offline   Reply With Quote
Old 08-04-2013, 02:35 AM   #39
Trailer: 77 Scamp 13
You can buy the seam tape from Scamp BUT you will need to supplement adhesive with something like 3M spray adhesive 77 (hardware or big box stores have it). Mine has been up for a year without problems.... Except for the smaller test pieces where I did not use the spray on adhesive just to see how well tape stuck on it's own. It didn't.
It's pretty easy, just hold the can close to the seam, spray a fast line of adhesive, wipe off any areas that are wider than the tape will cover right away, wait 5 minutes for the spay to tack up, then apply tape. I used much less than one can to do the whole trailer.
There have been links posted here in the past to other places to get the tape with reports that it is of better quality than what Scamp now has.
Original tape stayed in place for 35 years so I have to figure the quality of what Scamp stocks now is lower than what they used when producing the trailers originally.
Have also seen pictures of the caulk approach, done right it looks pretty good. I went with tape because I felt that caulking would be more work and not be easy to remove if I wanted or needed to redo in the future.
You will need something like tape if you want to trim in your windows, you really don't want to caulk them from the inside to hide the seam between window and wall. Would make window removal for repairs a nightmare.
Old 08-04-2013, 02:14 PM   #40
AM Moats's Avatar
Trailer: 13' Scamp
Taking a breather, literally, from putting up the Reflectix. I'm using contact cement and it seems to be working well, but boy does it go to your head after a while. Please tell me that the ceiling piece is the hardest and it's all down hill from here! We did find some creative ways to help manage the 10 foot piece. I've uploaded some pictures, including a picture of my cheerful helper.
Old 09-01-2013, 07:40 PM   #41
StacyJayT's Avatar
Seal tape.
Hello!
Can you tell me what tape you used? Was it paintable. I was going to paint my ensolite, and found the caulk just rubbed off, so now dealing with that. Also, I was thinking that maybe I should caulk enough to fill the crack, then add the tape?
What do you think? I have some that will be harder to get off/out, but most is gone now.
Thank you,
Stacy
Old 09-01-2013, 07:42 PM   #42
StacyJayT's Avatar
Connie, what did you end up doing for the seams?
1975 Scamp 13' No FL Title serendavid Problem Solving | Owners Helping Owners 22 02-02-2013 06:55 AM
Refurbishing my 77 Scamp RogerDat Modifications, Alterations and Updates 52 08-29-2012 12:22 AM
1975 Scamp on Ebay Cat futrell General Chat 2 08-11-2012 05:54 PM
Scamp 1975 13 Foot Kevin K Referrals: Molded Fiberglass Trailers 4 04-08-2010 02:40 PM
SOLD - 1975 13' Scamp Kevin K Classified Archives 1 09-18-2009 11:45 PM
