reinstalling fixtures - need input please - Fiberglass RV
Old 09-18-2012, 03:29 PM   #1
Trailer: 1973 Love Bug '13
Preparing furniture/fixtures to reinstall into 13' Love Bug. We are midway through our off frame rebuild. Considering options for reinstalling fixtures. Although rivets were used in original construction we are looking at our options. Blocking has been discussed in a number of threads.
Has anyone ever glassed the fixtures directly to the inside of the shell prior to installation of wall covering? If so, what are your thoughts?
If you see downsides to this option, I request your input. Any and all advice is greatly appreciated.
Thanks,
Cathy
Cat futrell is offline   Reply With Quote
Old 09-18-2012, 05:42 PM   #2
Raz
Raz's Avatar
Vermont
That's how my Trillium is made. The up side is a more rigid structure and no popped rivets. The down side is once done, removal will be a major project. If I ever have to replace my floor I am in for a much bigger job than drilling a few rivets to remove the benches. Raz
Old 09-18-2012, 05:48 PM   #3
Raz,
Thanks for that info. We are replacing the floor now. Hopefully floor replacement won't be necessary in my lifetime.
Cathy
Old 09-18-2012, 05:53 PM   #4
Raz,
How is the wall covering situated in your trillium? Is the same material used inside the cabinets or as the rest of the cabin?
Cathy
Old 09-18-2012, 06:31 PM   #5
Raz
Raz's Avatar
Vermont
Our Trillium uses a vinyl ( kinda like nauga hide) with a foam backing to insulate. It ends at the furniture. Inside the cabinets they use a material similar to fleece. In the bench storage areas there is no covering. On later models they used the same material as the closets to eliminate the splinters that bare fiberglass walls produce. Based on what I have read here, if I had to cover walls I would seriously consider marine fabric (rat fur). A while back I stumbled across this site you might find interesting. Lots of fabric choices. Raz
Sailrite.com | Home
Old 09-18-2012, 06:39 PM   #6
Thanks again, I will check that out.
Need Your Input! FRED SMAILES Money Matters 36 03-23-2012 05:02 AM
Reinstalling a Duotherm 65512 on a Trillium 4500 lamimartin Modifications, Alterations and Updates 3 09-05-2011 03:42 PM
LED Fixtures for Reading ? Tim Wood Modifications, Alterations and Updates 28 07-01-2011 11:20 PM
LED Fixtures gerry gregory Problem Solving | Owners Helping Owners 6 10-14-2006 05:59 PM
I NEED YOUR INPUT ; Legacy Posts General Chat 23 08-03-2003 12:10 PM
