Relocating Shower Pump on Scamp 16 - Page 2 - Fiberglass RV
Old 12-22-2015, 03:00 PM   #15
Trailer: 2014 Escape 21
Virginia
With the front bath the floor drain is below GW tank inlet so you have to have a pump. With the earlier side baths with the smaller GW white in color tank the inlet was was about mid point of the tank and they did not use a pump. But you had to put a snower drain stopper in to keep the grey water out the shower pan when traveling or when the tank was getting full. I have a 2004 side bath W/O shower with the G/W black in color 21/26 gal. tank and the drain inlet is below the frame rail so I could install a gravity drain. The newer 21/26 gal. tanks have the drain input in the rear up high on the tank so the drain line drops below the frame rail an rises again which requires a pump. The pump also acts as a check valve keeping the grey water out the shower floor pan.
Eddie
Old 12-22-2015, 08:17 PM   #16
I am not planning on using my shower during this cold winter season as I travel and... I noticed in deeper inspection that the drain is cracked probably from being hit from under the trailer before I bought it. I will have to replace it... anyone replaced one before? it looks like the part posted, so I assume I can obtain one easily... not so sure how easy it is replaced though.
Teal is offline   Reply With Quote
Old 12-22-2015, 08:56 PM   #17
Originally Posted by minnfinder View Post
Question, when did Scamp start using the shower drain pump? I have a 90 16' layout 4 with no pump, am considering putting one in. Is it worth the money?
My 92 16' - layout 4 (Sidebath) has a shower drain pump.
7 years of travel over some rough dirt/gravel as well & have never had issues with clearance.
Old 12-22-2015, 09:02 PM   #18
If your referring to the white trap that was posted they are easy to find at most RV shops (or from Scamp) and pretty easy to remove and replace. I have had mine off a couple of time to clean it out after items (hair or dry grass clippings) get caught up in it.
If its cracked it may be due to lack of winterizing. It holds water and people often forget to pour some anti freeze down into the shower and sink drains.
Old 12-23-2015, 06:31 AM   #19
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
I am constantly amazed at what I learn from this forum. Maybe, it's myself that I am amazed with because I don't know what I don't know, most of which, I've never thought about...hummmm.
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Covering back of shower pump switch in closet mgellar Problem Solving | Owners Helping Owners 5 04-16-2015 12:33 PM
Shower Pump Dan Meyer Problem Solving | Owners Helping Owners 0 06-26-2014 08:40 PM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Post-2006 13' scamp shower drain pump relocation? JohnF Plumbing | Systems and Fixtures 6 11-16-2011 08:47 PM
