12-10-2005, 12:31 AM
Trailer: 1977 Scamp 13 ft
This is the original kitchen. Note the water 'tank' under the sink - a 1 gallon plastic jug, full of . The sink had a hand-pump...don't know if it worked, never tried it. Since I was going to do things differently, I just removed it. The cabinets were grungy, yellowed, and had icky-stickies stuck all over them. The pressed wood doors were warped and sagging. I took it all out to clean it up, remove the liner, and put in the new liner. I also added a new window in the trailer, over the stove area, and added a city water connection by the wheel well (there wasn't one before).
12-10-2005, 12:38 AM
The inside of the cabinets was covered with a contact paper, I assume to seal off the rough fiberglass (green area). It was sticky, greasy, and falling off, so I just peeled it all off. The green was rather dark, so I spray painted the inside of the cabinets with white acrylic paint, to lighten it up, and painted the outside of the cabinets with a spray enamel.
12-10-2005, 12:43 AM
After putting in the new liner, I painted the wheel well and re-installed the cabinet. I put in a new water faucet, one handled, non-mixing as I have no hot water heater attached, and hooked it up to the city water connection.
At this point, I had not put up the last panel of insulation/liner above the sink as I had 12v wiring to complete before gluing over it.
The 'pole' is the acorn nut holder I fashioned from instructions given by Joy A. There is no way I could have done this project, alone, without that aid! Thanks, Joy!!!!
12-10-2005, 12:51 AM
I re-installed the upper cabinets, adding new 12v LED lights at both ends. I painted the heat shield that goes over the stove with high-heat spray paint. I also added a toaster oven rather than a microwave. The oven rides under the cabinet when not in use, to give full access to the sink. I like to bake, and find it very civilized to have tea and fresh cinnamon biscuits in the afternoon .
12-10-2005, 01:07 AM
I put in a new stove (on a BH thread, I had re-painted the old, orange stove a nice raspberry color....unfortunately, I did not check out the stove itself, and it was not functioning properly--flames!!! One of those expensive lessons...).
I added an additional electrical outlet to the bed end of the cabinet, and wire shelves underneath to hold 'stuff'. I zip-tied the shelf over the wheel well, using holes left over from the dinette seats (I am not replacing them). I used a broom clip on the other end, set sideways to hold the shelf. I will try that out for a while, using my Coleman electric cooler rather than a frig. I do still have the 2-way frig, but it was not working properly. I have not decided about putting in a three-way and cutting more holes....
12-10-2005, 08:13 AM
Trailer: Escape
New Mexico
<span style="font-size:12pt;line-height:100%">Go for it! Looking good, Jackie.</span>
12-10-2005, 09:49 AM
Trailer: 2007 17 ft Casita Spirit Deluxe
Amazing makeover. Fresh and clean. It looks like a happy kitchen.
12-10-2005, 07:46 PM
Trailer: 2003 Casita Liberty Deluxe
Nice job, Jackie. What a big change!
Chris
12-10-2005, 10:27 PM
Trailer: Casita 2000 Spirit Deluxe
That took lots of hard work and time. Looks great!
Karalyn
12-11-2005, 10:30 AM
Wow! popping change Jackie. It definitely looks like all your hard work is paying off
12-11-2005, 10:43 AM
Trailer: 1992 19 ft Scamp 19 ft 5th Wheel
Fantastic job, Jackie! I love the step-by-step photos and dialog. It makes it so anyone could follow your steps and renovate their own kitchen. What a change it made!!
Nancy
12-16-2005, 05:24 PM
Trailer: 1979 13 ft Boler and 1987 Bigfoot 5th Wheel
Jackie, I think our trailers were separated at birth.
Your work looks wonderful! Isn't it great to have things nice and clean? Nice window.
01-01-2006, 02:34 PM
Hi Jackie,
Looks impressive. Have a quick question. Did you repaint the counter framing and cupboard framing? If so what did you use?
Thanks,
Jollean
01-01-2006, 04:46 PM
looks great !!! i need to put up new cab doors what thickness wood are you useing to make the doors out of...
01-01-2006, 05:29 PM
Hi, like where the microwave is located ...may hang mine over the sink also....just hope that the upper cupboard can support it....having the cupboard support next to the mic helps I suppose....Benny
01-01-2006, 08:53 PM
Actually, Benny, that is a toaster oven. It has a heat shield to keep it from scorching the cabinet, and can be taken down and placed uner the sink when not in use, so I have full acess to the sink, and espceially when traveling. I opted for a toaster oven rather than a microwave, to fit my lifestyle and preferences. I imagine that if you put some extra wood slats to disperse the weight in the upper cabinet, it may be OK to place a microwave there...anyone done this?
01-02-2006, 09:12 PM
Hi again, should`ve looked closer the first time around ....right, toaster oven...sorry bout that....but I may try to hang the microwave up there with the wrought iron bracket to help support the one end and possibly a bracket inside the cupboard with a couple 1/4" SS bolts thru the roof the help the cupboards support the other end....should work ok and just have to remove the glass plate that`s inside.....we`ll see if it`s practical first......we now carry a small mic on the floor when on the road with the 17' Boler but may do a permanent install on the 13 footer.....Have a Good New Year....Benny
