Remodeling the Kitchen - Fiberglass RV
Old 12-09-2005, 11:31 PM   #1
Jackie's Avatar
Trailer: 1977 Scamp 13 ft
Send a message via Yahoo to Jackie
This is the original kitchen. Note the water 'tank' under the sink - a 1 gallon plastic jug, full of . The sink had a hand-pump...don't know if it worked, never tried it. Since I was going to do things differently, I just removed it. The cabinets were grungy, yellowed, and had icky-stickies stuck all over them. The pressed wood doors were warped and sagging. I took it all out to clean it up, remove the liner, and put in the new liner. I also added a new window in the trailer, over the stove area, and added a city water connection by the wheel well (there wasn't one before).
Jackie is offline   Reply With Quote
Old 12-09-2005, 11:38 PM   #2
Jackie's Avatar
The inside of the cabinets was covered with a contact paper, I assume to seal off the rough fiberglass (green area). It was sticky, greasy, and falling off, so I just peeled it all off. The green was rather dark, so I spray painted the inside of the cabinets with white acrylic paint, to lighten it up, and painted the outside of the cabinets with a spray enamel.
Old 12-09-2005, 11:43 PM   #3
Jackie's Avatar
After putting in the new liner, I painted the wheel well and re-installed the cabinet. I put in a new water faucet, one handled, non-mixing as I have no hot water heater attached, and hooked it up to the city water connection.
At this point, I had not put up the last panel of insulation/liner above the sink as I had 12v wiring to complete before gluing over it.
The 'pole' is the acorn nut holder I fashioned from instructions given by Joy A. There is no way I could have done this project, alone, without that aid! Thanks, Joy!!!!
Old 12-09-2005, 11:51 PM   #4
Jackie's Avatar
I re-installed the upper cabinets, adding new 12v LED lights at both ends. I painted the heat shield that goes over the stove with high-heat spray paint. I also added a toaster oven rather than a microwave. The oven rides under the cabinet when not in use, to give full access to the sink. I like to bake, and find it very civilized to have tea and fresh cinnamon biscuits in the afternoon .
Old 12-10-2005, 12:07 AM   #5
Jackie's Avatar
I put in a new stove (on a BH thread, I had re-painted the old, orange stove a nice raspberry color....unfortunately, I did not check out the stove itself, and it was not functioning properly--flames!!! One of those expensive lessons...).
I added an additional electrical outlet to the bed end of the cabinet, and wire shelves underneath to hold 'stuff'. I zip-tied the shelf over the wheel well, using holes left over from the dinette seats (I am not replacing them). I used a broom clip on the other end, set sideways to hold the shelf. I will try that out for a while, using my Coleman electric cooler rather than a frig. I do still have the 2-way frig, but it was not working properly. I have not decided about putting in a three-way and cutting more holes....
Old 12-10-2005, 07:13 AM   #6
Myron Leski's Avatar
Trailer: 19' Escape
NM
<span style="font-size:12pt;line-height:100%">Go for it! Looking good, Jackie.</span>
Myron Leski is offline   Reply With Quote
Old 12-10-2005, 08:49 AM   #7
Trailer: 2007 17 ft Casita Spirit Deluxe
Amazing makeover. Fresh and clean. It looks like a happy kitchen.
Gary Lynch is offline   Reply With Quote
Old 12-10-2005, 06:46 PM   #8
Chris B's Avatar
Trailer: 2003 Casita Liberty Deluxe
Nice job, Jackie. What a big change!
Chris
Chris B is offline   Reply With Quote
Old 12-10-2005, 09:27 PM   #9
Karalyn's Avatar
Trailer: Eggless for now but looking. currently own Amerilite 21 ft
That took lots of hard work and time. Looks great!
Karalyn
Old 12-11-2005, 09:30 AM   #10
Wow! popping change Jackie. It definitely looks like all your hard work is paying off
Old 12-11-2005, 09:43 AM   #11
Nancy in Oregon's Avatar
Trailer: 1992 19 ft Scamp 19 ft 5th Wheel
Fantastic job, Jackie! I love the step-by-step photos and dialog. It makes it so anyone could follow your steps and renovate their own kitchen. What a change it made!!
Nancy
Nancy in Oregon is offline   Reply With Quote
Old 12-16-2005, 04:24 PM   #12
Lizbeth's Avatar
Jackie, I think our trailers were separated at birth.
Your work looks wonderful! Isn't it great to have things nice and clean? Nice window.
Old 01-01-2006, 01:34 PM   #13
Jollean's Avatar
Send a message via ICQ to Jollean Send a message via MSN to Jollean
Hi Jackie,
Looks impressive. Have a quick question. Did you repaint the counter framing and cupboard framing? If so what did you use?
Thanks,
Jollean
Jollean is offline   Reply With Quote
Old 01-01-2006, 03:46 PM   #14
Dan Quinn's Avatar
looks great !!! i need to put up new cab doors what thickness wood are you useing to make the doors out of...
Dan Quinn is offline   Reply With Quote
Remodeling a Trillium... Randy Bishop Modifications, Alterations and Updates 6 07-24-2010 03:16 PM
kitchen stove top Valerie G Problem Solving | Owners Helping Owners 3 06-11-2008 02:44 PM
Kitchen Window Steve R General Chat 15 09-05-2007 09:39 PM
13' Burro Remodeling Started! Legacy Posts Modifications, Alterations and Updates 8 07-16-2003 09:07 AM
kitchen stove top Valerie G Modifications, Alterations and Updates 0 12-31-1969 07:00 PM
