Removing belly band 13' 1970 boler - Fiberglass RV
Old 05-09-2017, 09:17 PM   #1
Has anyone removed the belly band from thier Boler. I am thinking of fiberglass the inside then cut off belly band and fiberglass outside. To give it a smoothed out look. Info and or ideas appreciated please.
Pgmopar is offline   Reply With Quote
Old 05-09-2017, 09:58 PM   #2
FRED SMAILES's Avatar
Trailer: 13 ft Boler
I think it would look cool.
I do think the band probably adds some rigidity to the sides.
If you do it make sure you add multiple layers.
Think I would start with say a 4in wide layer at the joint then follow with maybe 6in, 8in. 12in.
That would spread the load over a large area and the interior wall shouldn't get too bulky looking.
After you grind off the band and gel coat close to the band a layer or 2 could go there too
Good luck if you go for it.
Fred
FRED SMAILES is offline   Reply With Quote
Old 05-10-2017, 08:54 AM   #3
Fred
Hi Fred,
I think that the band definitely adds some rigidity to the whole body, a few layers of FG from inside may not function as well as the band.
Eric
HawkBoler72 is offline   Reply With Quote
Old 05-10-2017, 09:39 AM   #4
FG to replace band
So after looking at some options for the belly band removal. Here is my thoughts so far. Since I have the entire interior stripped out. I am thinking a nice thick FG "peanut Butter " mixture to fill the slight indent inside the Boler at the band point then at least 4 layers of glass matting on top of that. Once dried an set, remove band and lip and use at least 2 layers of matting on the outside. This seems to be as good as I can get for the structural point of FG. Does this seem good or bad or really just a crap load of overkill.....lol
Old 05-10-2017, 01:32 PM   #5
Borrego Dave's Avatar
George, I'm surprised that you haven't received an answer from a few members that have done what you're asking about. Your repair ideas will work fine and be plenty strong. FWIW, I would lay in one strip of thin cloth (inside) before any matting. Post pics of the repair for the rest of us.
Old 05-10-2017, 02:16 PM   #6
belly band removal
I have removed the belly band on my surfside looks beter .as for the belly band it is held on with 1/8 rivets one half inch long ita is just a garnish moulding .if you do fiberglass it use apoxie in it is 5 times stronger than pollister.also use woven matt also 4 times stronger fixed corvets for years works for me .
MAP 56 is offline   Reply With Quote
Old 05-10-2017, 03:07 PM   #7
Sounds good. I will post up the pics of my process. Ty for input.
Old 05-10-2017, 03:07 PM   #8
Perfect. Ty
Old 05-10-2017, 09:40 PM   #9
ID:	105915Click image for larger version
ID:	105916Click image for larger version
ID:	105917Click image for larger version
First fill of peanut butter in the seam. Now to wait 24hrs then sand and see where I am at.
Old 05-11-2017, 12:22 AM   #10
Looking good George. I don't know the layout of your TT but had a couple thoughts for you. Depending where any cabinets or such may cross your repair area, the new FG build up may cause a problem with the wall fit. If so, they could be trimmed to fit but it would be a lot easier to only use one layer of mat behind those areas over your butter fill. No extra work that way . One other thing to consider now that you have raw walls. A number of folks have glassed in wood blocking for a good attachment point for shelves, cabinets and such.
Old 05-11-2017, 07:36 AM   #11
Good idea. Ty
Old 05-11-2017, 10:44 PM   #12
Attachment 105915Attachment 105916Attachment 105917Attachment 105918
Does not seem like a big change from yesterday. But there is a second coat of peanut butter on the seam. 24 more hours and resanded smooth. Then 1/8" plywood strip will be installed for strength. Then that will get fiberglass over that. Two layers. Then we can cut the outside belly band off. So with dry time. Mid to end of next week the band will be off.Click image for larger version
Old 05-13-2017, 07:39 AM   #13
Trailer: Looking!
I have wondered about doing the same as you. I can do glasswork just well; however, I haven't yet obtained an egg to work on. I like the style of the Burros, but that seam needs to be shaved!
adlorin is offline   Reply With Quote
boler, vin
Removing, repairing and reattaching the belly band on a Scamp byersl Problem Solving | Owners Helping Owners 4 04-01-2017 03:15 AM
Trillium-removing belly band & filling in. hrose414 Problem Solving | Owners Helping Owners 4 02-04-2015 09:47 AM
Grind off Belly Band on Boler? Sleeka Care and Feeding of Molded Fiberglass Trailers 4 02-06-2011 03:09 PM
Boler Belly Band timmckee Problem Solving | Owners Helping Owners 10 07-21-2010 03:20 PM
Boler Belly Band Sealer Dave Mc Problem Solving | Owners Helping Owners 7 05-09-2008 05:49 AM
