05-13-2015, 02:21 PM
Trailer: Trillium 1300
Removing Weatherstripping Adhesive
Can anyone give me some advice on the best product to use to remove the adhesive left on my door after removing the weatherstripping? I have read that acetone might be a good solution...any thoughts? Thanks!
05-13-2015, 02:43 PM
A business that sells automotive paint and body shop supplies should have something that works if acetone does not work. MEK (mehyl ethyl keytone ) is very similar to acetone but does not evaporate as quickly so you would have a longer working time than you would with acetone.
05-13-2015, 03:25 PM
Name: Norm and Ginny
I use WD-40 and a paper towel. MEK is strong.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
05-14-2015, 09:45 AM
Trailer: 2017 Escape 17B
SW Virginia
Whatever you use, try it out where it won't cause a problem first. I'd start with rubbing alcohol
Walt
05-14-2015, 09:51 AM
I have used acetone for this lots. The one advantage it has, is that it leaves no residue itself.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
05-14-2015, 10:51 AM
Trailer: 1979 Trillium Jubilee
I used kerosene to remove all the residue from around the window openings. Cheap, relatively harmless (compared to MEK, at least) and easy to find.
05-14-2015, 10:54 AM
Dave & Paula
05-14-2015, 11:12 AM
Trailer: Surf-Side
Manitoba
The product that is safe and effective is GOO GONE , it is a citrus based product . It smells nice and is not an explosive hazzard . It can be purchased at most lumber or hardware stores , as contracters use it to clean up after glueing and siliconing jobs .
05-14-2015, 01:04 PM
A lot also depends on what you intend to do after cleaning. If you are going to paint, then anything that will leave a residue will not be good, and you will have to wipe down with acetone or a similar cleaner in order for paint to stick good.
2017 Escape 5.0 TA
05-14-2015, 05:16 PM
I just finished removing my weather stripping this afternoon. I used regular paint thinner - varsol. Worked well, took about a half hour.
05-17-2015, 12:21 PM
Trailer: 1985 BigFoot G
Mississippi
I agree and it's wonnnnnderful stuff! Walmart even has it as well.
05-17-2015, 03:04 PM
Trailer: Surf-Side
Manitoba
Bob's wife says: it is great for sticky zippers, too. Just put a wee bit on the end and slide the slide up and down a few times. You will be surprised!
