Replacement Hehr Jalousie Window - Fiberglass RV
Old 09-03-2016, 06:29 PM   #1
Nova Scotia
Hello again!
At the back of my Trillium Jubilee one of the original windows is gone. It has been replaced with a piece of plexiglass. I would like to have this ugly plexiglass replaced with a replacement window. Does anyone have any idea where I could get another window to match the others? An internet search has not turned up much. Other owners *must* have run into this before and found a solution....I hope!
Thanks in advance!
Jennygdeans is offline   Reply With Quote
Old 09-03-2016, 06:53 PM   #2
Roy in TO's Avatar
Is that the large "emergency" window?
Your best bet will be to go to a glass shop. They will have to order in the right size and have it "tempered".
By tempered, the right thickness of glass is cut to the size you need then treated to make it suitable for an RV window.
https://en.wikipedia.org/wiki/Toughened_glass
And yes, it will cost more than a regular pane of glass.
Old 09-03-2016, 07:57 PM   #3
Nova Scotia
Roy - I have another equally large window in the front of the trailer, so no emergency worries! I'm looking for another matching jalousie window to fill the space. A pane of tempered glass will do the job, but only as a last resort!
Old 09-03-2016, 08:40 PM   #4
Roy in TO's Avatar
Sort of like winning a lottery:
You will be waiting for a long time to find a "donor" window of the same size. The next option is finding one with a frame that can be cut down to size.
You might luck out and find someone that can make you a new one but be forewarned its going to be be $$$.
Realistically:
Replacing the plexiglass with tempered glass is your best solution.
Old 09-03-2016, 08:50 PM   #5
Roy in TO's Avatar
You might get luck though.
From a post a few years back: http://www.fiberglassrv.com/forums/f...ows-64228.html
The ebay sellers store: storage shed window, Shed Hardware t handle t hinges barrel bolts t-handles items in SHED WINDOWS store on eBay!
Their website: Shed Windows, Chicken Coop Windows | Shed Windows and More
Old 09-04-2016, 09:55 AM   #6
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
I have a friend who bought on this site but through a caravan parts seller.
I do not know if you can buy directly?
Him it has a U-Haul, but I understand that one can buy whatever format is desired ...
- RV Windows
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 09-04-2016, 07:01 PM   #7
Nova Scotia
Thanks for your input and leads. I'm chasing up both your suggestions, and I have a million alerts set up on eBay. I figure I'll do due diligence and see if I can replace them, if not, tempered glass it is (for now...)!
Old 09-08-2016, 03:01 PM   #8
David Tilston's Avatar
Jenny, What are the dimensions of your window?
Old 09-08-2016, 04:27 PM   #9
Jim Bennett's Avatar
What all is missing? I assume the frame is there, but the pieces that go around the glass are missing. Are there any of the hinges in place?
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-08-2016, 04:29 PM   #10
You are right that it is likely a the single large emergency exit.
The original glass is not tempered.
2017 Escape 5.0 TA
Old 09-08-2016, 04:46 PM   #11
Nova Scotia
David - The missing window measures 23.5''W x 21.5''H. The double window is 47.5''W.
Old 05-28-2017, 03:51 PM   #12
Trailer: Trillium Jubilee '79
Newfoundland
Jenny. Paul from St. John's NL. We have a 79 Jubilee. The window in question is an emergency exit. In the
Documents section of this site review the brochures. In one of them it does identify the window as an emergency exit. Glass does not appear to be tempered. Curious to know how you are progressing with your renovations.
Terranovafox is offline   Reply With Quote
Old 05-28-2017, 07:11 PM   #13
Nova Scotia
Hey Paul! I did have a look through the document section at some point, but I must have missed the Jubilee specific info. Thanks for the tip!
Renos have been on hold for the winter, and then for the rain. Man, I would love to have an indoor place to work. Windows and shell repair are up first. I'll update my main thread once I start at it again!
Hehr Jalousie window header seal FRANK MOLIS Problem Solving | Owners Helping Owners 18 09-04-2016 10:37 AM
Repairing a Leaking Hehr Jalousie Window Johnny M Modifications, Alterations and Updates 2 11-11-2015 01:58 PM
Scamp Jalousie Window Replacement sugermc Problem Solving | Owners Helping Owners 15 04-07-2010 06:33 AM
