Replacement screws - Fiberglass RV
Old 07-25-2017, 08:11 PM   #1
Trailer: ECO 1973
Replacement screws
I'm replacing a side window and would like to use ss screws. What kind and size do I use. Thank you
BeckyK is offline   Reply With Quote
Old 07-25-2017, 08:42 PM   #2
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
Hi Becky,
Take one of your old screws out and take it with you to the hardware store to compare and get the right size. Lowe's handles some stainless steel fasteners. Having said that, if the screw hole is "eaten out" or deteriorated I sometimes go with the next size up in diameter. Be careful about using a longer screw that could go all the way through to the interior of the trailer. I also like to dip a screw threads in the window caulking (you will be using fresh caulking to seal the window) to make sure the screw hole is sealed.
Old 07-26-2017, 12:38 AM   #3
Alf S.'s Avatar
Hi: BeckyK... Be careful using S/S screws. You'll have dis similar metals and could end up with a corrosion issue. If you do use them, also use thin nylon washers to isolate the screw heads from the window frame.
Old 07-26-2017, 05:57 AM   #4
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Assuming your camper windows were assembled similar to vintage Boler 13s (rivets or sheet metal screws into raw fiberglass), you could use relatively short (maybe 1" pan head sheet metal screws). Alternatively you could use machine screws paired with nylock nuts and washers. This alternative would address the problem of dealing with various sized holes in the the fiberglass.
John in Michigan is online now   Reply With Quote
Old 07-26-2017, 04:08 PM   #5
Trailer: ECO 1973
Thank you Becky
Fantastic fan screen up-grade,no screws shane n Modifications, Alterations and Updates 2 03-25-2009 05:45 PM
Rusted Screws amado_aguilar Problem Solving | Owners Helping Owners 3 07-20-2008 08:12 AM
screws or rivets Tim M Problem Solving | Owners Helping Owners 1 06-23-2008 12:28 PM
Thumb Screws for Refriderator Panel Joe Loiacono Care and Feeding of Molded Fiberglass Trailers 6 06-27-2007 08:40 AM
Replacing screws in Trillium door Kevin Falk Problem Solving | Owners Helping Owners 0 05-28-2007 09:24 PM
