Replacement screws - Fiberglass RV
Old 07-25-2017, 08:11 PM   #1
Trailer: ECO 1973
Oklahoma
Replacement screws
I'm replacing a side window and would like to use ss screws. What kind and size do I use. Thank you
BeckyK is offline   Reply With Quote
Old 07-25-2017, 08:42 PM   #2
Bruce H's Avatar
Trailer: Sold Bigfoot. Shopping for Arctic Fox 22G
Missouri
Hi Becky,
Take one of your old screws out and take it with you to the hardware store to compare and get the right size. Lowe's handles some stainless steel fasteners. Having said that, if the screw hole is "eaten out" or deteriorated I sometimes go with the next size up in diameter. Be careful about using a longer screw that could go all the way through to the interior of the trailer. I also like to dip a screw threads in the window caulking (you will be using fresh caulking to seal the window) to make sure the screw hole is sealed.
Bruce H is offline   Reply With Quote
Old 07-26-2017, 12:38 AM   #3
Alf S.'s Avatar
Hi: BeckyK... Be careful using S/S screws. You'll have dis similar metals and could end up with a corrosion issue. If you do use them, also use thin nylon washers to isolate the screw heads from the window frame.
Old 07-26-2017, 05:57 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Assuming your camper windows were assembled similar to vintage Boler 13s (rivets or sheet metal screws into raw fiberglass), you could use relatively short (maybe 1" pan head sheet metal screws). Alternatively you could use machine screws paired with nylock nuts and washers. This alternative would address the problem of dealing with various sized holes in the the fiberglass.
Old 07-26-2017, 04:08 PM   #5
Trailer: ECO 1973
Oklahoma
Thank you Becky
Old 06-30-2021, 10:52 AM   #6
Trailer: Trillium 4500
Please tell me what nylon washers to buy - repairing windows on "78 Trillium 4500
Carri in Ontario is offline   Reply With Quote
Old 06-30-2021, 12:41 PM   #7
David Tilston's Avatar
Carri, They are available at Home Depot. Match to the size of screws used:
https://www.homedepot.ca/product/pau...ers/1000418599
It is worth noting that I replaced the screws around the windows on one of my Trillium about four years ago with 316 screws. I did not use nylon washers. I have not noticed any corrosion issues, but better safe than sorry.
Old 06-30-2021, 02:19 PM   #8
Trailer: 2013 Escape 19
Here in the US, for almost any part, I check Amazon and eBay. In the case of screws, to do the windows in a Trillium you are talking several hundreds of them. Buying at a local home improvement store tends to be pretty expensive.
On screws, I find eBay is the cheapest, I buy several different lengths of #6 and #8 SS screws, Phillip head. A bag of 100 can be around $6.50.
Now in Canada, no idea which will be cheapest.
Old 06-30-2021, 03:10 PM   #9
AND
Thanks David and Bill.
I am hoping to order from Amazon as home depot SS screws don't seem to be sold in quantity and are very expensive.
There are SOMANY screws - but I think the sizes are standardized enough that I can figure them out. The nylon washers on the other hand...I cannot figure out the sizes...each list thickness, OD and ID.AND measurements listed in metric, inches OR decimal inches. :-P
Old 06-30-2021, 04:18 PM   #10
I post links to Home Depot because they are easy to search. But when I want to buy a large quantity of screws or other fasteners, I go to Calgary Fasteners & Tools:
https://www.calfast.com/search?contr...uery=fasteners
I can never find what I'm looking for on their site, but I take an example of what I am looking for and they produce a box of 100 for as much as Home Depot charges for 10. The only down side is they are mostly open during business hours, (when I'm at work). They are open 8am till noon on Saturdays, but that means I have to get up early. There are three of them in Calgary. There is likely a comparable store near you.
Old 07-01-2021, 08:29 AM   #11
ACE HWD carries a good selection of stainless screws. They sell by the piece or you can buy a box. The boxes usually contain 50 or 100 screws. The boxes are in the rear of the bin. I don't waste my time at Lowe's or HD for stainless hardware.
Eddie
Old 07-01-2021, 02:20 PM   #12
Roy in TO's Avatar
Home Depot sells a black powder coated screw in their deck / railing section that does the trick.
I found my post that gives the part #
https://www.fiberglassrv.com/forums/...tml#post600917
Fantastic fan screen up-grade,no screws shane n Modifications, Alterations and Updates 2 03-25-2009 05:45 PM
Rusted Screws amado_aguilar Problem Solving | Owners Helping Owners 3 07-20-2008 08:12 AM
screws or rivets Tim M Problem Solving | Owners Helping Owners 1 06-23-2008 12:28 PM
Thumb Screws for Refriderator Panel Joe Loiacono Care and Feeding of Molded Fiberglass Trailers 6 06-27-2007 08:40 AM
Replacing screws in Trillium door Kevin Falk Problem Solving | Owners Helping Owners 0 05-28-2007 09:24 PM
