Replacing Boler windows help - Fiberglass RV
Old 04-08-2016, 10:00 PM   #1
TrevB's Avatar
Trailer: 1972 Boler 13'
Hey everyone. Im about to install my new Sunview windows. but the inside flange seems to be wrong. When I dry fit the window, there is a gap between flange and the window. If I screw the flange in, there will be a good 1/8" - 1/4" gap. Anyone have any experience with this? Thanks
TrevB is offline   Reply With Quote
Old 04-10-2016, 01:53 PM   #2
Pictures would help. Not quite sure what you mean.
TimR is offline   Reply With Quote
Old 04-10-2016, 02:05 PM   #3
TrevB's Avatar
Actually just figured it out and finished installing. Thanks
Sent from my SM-G900W8 using Fiberglass RV mobile app
Old 04-12-2016, 09:14 PM   #4
Bill Schreurs's Avatar
Trailer: 1970's Boler, 1970 Bluebird Wanderlodge and 1999 Georgetown
Windows
Trevor:
Which windows are they. I have to replace my windows as well.
If you can post pics as well of your install that would be great.
Bill
Bill and Vadie
1974 Boler 13' "Sad Shack"
1970SP Bluebird Wanderlodge
1999 Forest River Georgetown 325
Bill Schreurs is offline   Reply With Quote
Old 06-11-2016, 11:27 AM   #5
Hello! We paid to have someone install the same Windows (he advertised on kijiji charging a hefty amount I must say) on our 1974 Boler and the seal isn't right! Water pools in the tracks and drips down the inside of the wall 🙄 We will have to completely remove them and put them back on ourselves since he won't reply to our messages. If you have any ideas why it may be doing that it would help so much! Did you have to install any additional seals or products to waterproof the Windows? The 2 Windows that leak are our dinette Windows. Thanks!
missjas is offline   Reply With Quote
Old 06-11-2016, 03:39 PM   #6
Keaner's Avatar
Trailer: 1973 13' Boler
Is there any butyl tape between the window flange and the body?
Keaner is offline   Reply With Quote
Old 06-15-2016, 02:44 PM   #7
Jay H's Avatar
Trailer: Boler 1300
Hi Jasmine,
I found when I was installing the two side dinette windows in my Boler I had to pay real close attention to make sure I could differentiate between Left and Right. Butyl Tape goes on the outside flange and the drain holes in the window frame have to face down (that is they are on the bottom edge not the top). Check to see if the drain holes are on the bottom of the outside of the window frame. If they are not then maybe the window frame is filling up with water and leaking in. The other thing to check is to see if any butyl tape (The sticky/gummy grey or black stuff) is squeezing out between the outside frame and the exterior of the trailer. I tried to be conservative in my use of butyl tape but I was still surprised with how much squished out even a week or two after installation.
Hope you solve your problem and find your answer, sorry about your luck.
Jay
Jay H is offline   Reply With Quote
boler, windows
Replacing plexiglass windows in Boler Macca Problem Solving | Owners Helping Owners 15 04-21-2016 10:52 AM
Windows, windows, windows Matt4483 Problem Solving | Owners Helping Owners 24 02-10-2016 01:50 PM
Replacing windows in my 1973 Boler heidster Modifications, Alterations and Updates 14 09-21-2014 09:25 AM
Replacing Boler window with Trillium Windows Rusty99 General Chat 5 02-02-2013 01:28 PM
Replacing the rectangle aluminum windows with modern rounded corner windows Evergreen Modifications, Alterations and Updates 16 10-29-2010 12:09 PM
