10-30-2011, 08:13 PM
Trailer: Burro 13'
Replumbing
On my 1978 13' Burro I am not very impressed with the hose draining the sink and dribbling down the outside.
I don't want to install a grey water tank, space issues being what they are. Anyone done something clean and clever they would care to share?
I am leaning toward a standard 1 1/2" drain to the outside. Thoughts?
10-30-2011, 08:32 PM
How about a ball valve under the floor with a garden hose quick connect on it, then you can carry a length of garden hose for onsite sewer connection and a jug for catching the water directly.
10-30-2011, 08:52 PM
Trailer: 1976 Surfside
In my small camper I put about a foot or so piece of 3 inch abs piping capped both ends , on the top with a 1 inch fitting for the hose from the sink and on the bottom I brought it down to 1 1/2 fitting with a gate valve. It did not hold much but gave enough room to brush my tooth, lol
Hope this helps
10-30-2011, 09:05 PM
I bought an elbow at some RV store speciffically made for this problem.
When you're camping remove the exterior drain cover, screw this little elbow on and attach a short piece of garden hose to go in your drain bucket or tank.
John
10-31-2011, 01:37 PM
Sorry, I don't quite understand you question. I have a standard female hose fitting on the side of the trailer to which I attach a short length of garden hose that feeds into a jerry jug. Once I found water dripping down the side of the camper( leak) and discovered the hose washer was missing. A new hose washer stopped the drip. As long as everybthing is tight, all the sink water goes into the jug. Are you looking to do something different?
10-31-2011, 02:56 PM
Trailer: Burro 13'
My journey so far.
Taking a cue from Ken h, I am cobbling together a 4" PVC grey water tank that will stand vertically inside the cabinet. I drilled and glued assorted adapters and gate valve on to end caps. It took an hour of wandering in the Ace plumbing section. The staff has learned to leave me alone. Altho they did remind me a vent line would allow the sink to drain better. I am not done yet. I will post photos when I am. I am thinking I will use the old garden hose coupling to supply fresh water at the sink with a spray attachment.
10-31-2011, 06:01 PM
Charley, sounds very interesting! And you know, we'll want to see some detailed pictures!
11-01-2011, 05:10 PM
Trailer: 84 16 ft Scamp
I use a portable 'free-bee' 2-1/2 gal tank located directly under the sink which drains via a part of a funnel through a 1/2 inch piece of rubber hose into the tank. The tank was originally contained mustard spread and was a restaurant throw-away.
I seldom generate that much grey water in a day, but empty it daily, so as not to be surprised. I find this much more handy than dealing with emptying built-in holding tanks!
11-02-2011, 08:16 PM
Trailer: Burro 13'
I have finished the grey water tank. Took 3x the time and 2x the $ I imagined. But once you start down that Rabbit Hole, you have to stay true to your vision...right?
I like having the valve interior so I may dump at my pleasure without crawling around underneath. I can attach a hose to direct the flow as needed.
Now I have to learn how to post the pictures...
11-02-2011, 08:20 PM
Trailer: Burro 13'
grey water pictures
Here are photos of my homemade greywater tank.
11-02-2011, 08:37 PM
Nice.. and permanent too!
11-02-2011, 11:48 PM
Hey Charley , your new holding tank looks great. That is about what I had come up with on my camper , but I see your's is the larger white model.
Great job!
11-03-2011, 03:58 PM
Trailer: Burro 13'
Since I was this deep into it I added a spray wand to the counter top. I hooked to up to what had been the drain line garden hose connection. Now I am done with that. Wiring is done too. Until I start one the solar power anyway...
