Restore boler 78 - Page 2 - Fiberglass RV
Old 09-10-2006, 09:21 PM   #15
Catherine H.'s Avatar
Trailer: 82 14 ft Surfside Triple E TM14
hello
This afternoon i paint the first coat ofthe lower of my boler
I am happy of the result of my labor
Yvon Chayer
Wow, Yvon! What a glossy shine you have! What did you use for primer? What kind of paint and how did you apply the paint?
Catherine H. is offline   Reply With Quote
Old 09-10-2006, 10:39 PM   #16
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
Hello Catherine
I use for primer Dupont epoxy primer and for paint i use Interlux Brightside paint
I spray this with air pistol
The Brightside paint was heavy and the pressure use is around 80 psi for best spray
I am very happy of the result
Yvon Chayer
Yvon Chayer is offline   Reply With Quote
Old 09-11-2006, 04:45 PM   #17
Brian B-P's Avatar
Loren, what is a DA sander?
I had the same thought, but then realized that it probably means "[b]Dual Action": not just a spinning disk, or a rectangular pad which moves back in forth in a straight line, but a more complex combination of "actions".
Loren can correct me when he gets a chance to see this.
Old 09-11-2006, 10:42 PM   #18
Makes sense to me. So would an electric Random Orbital Sander be effective enough? I have to get this stuff off! See pics.(thank you, Benny!) I'd sure like it to look as nice as Yvon's Boler!
Old 09-11-2006, 11:08 PM   #19
Catherine, your best bet would be to find someone to borrow a random orbital from and try it......they are fairly cheap to buy in an air driven version, as long as you have a compressor capable of running it fairly steady......I believe the dual action is switched from a back and forward action to a orbital rectangular pad and a random orbital which is switched from a disc sander to an action that kinda wobbles and spins somewhat at the same time by moving a metal disc to engage or disengage the action ....hope you don`t run into problems with that right rear roof area....looks like some previous damage wasn`t repaired too well.....but luckily it`s fiberglass... ... and almost anything can be fixed........how`s every thing else coming along? Benny
Old 09-12-2006, 05:16 AM   #20
Quebec
Hello Catherine
How is the fibergass and gelcoat condition under the old paint ???
The sander that i use is a chicago pneumatic CP 865
Why do you not consider rent a compressor and a sander ????
You rent the kit for a week end and you make the job !!!!
I put the link oh my sander for the specification of the air supply
http://212.75.80.201/CPIndustrialSite/Default.asp
Yvon Chayer
Old 09-12-2006, 03:00 PM   #21
Hello Catherine
Why do you not consider rent a compressor ans sander ????
Yvon Chayer
Yvon
I don't know the condition of the gelcoat underneath. The "gelcoat" is just the smooth paint that covers the raw fiberglass right? I own a new air compressor and may just purchase a sander for it. I assume you started with a 220 grit and worked your way closer to 100 grit? Any advice for me and others doing this?
Old 09-12-2006, 03:54 PM   #22
Trailer: 84 16 ft Scamp
Sorry, I was away for a few days.
Yes, it stands for dual action. Maybe it's local parlance. I still see them sold and Home Depot and Lowes. They either lock the shaft for direct rotation, or mechanically offset and release it for large semi-orbital, semi-rotating action. They were used by auto body workers and boat builders, probably still are. Use a lot of air, make a lot of noise and spew a lot of dust.
Old 09-12-2006, 04:19 PM   #23
james kent's Avatar
Trailer: Boler 1984
I also am going from this
Old 09-12-2006, 04:20 PM   #24
james kent's Avatar
Trailer: Boler 1984
to this
Old 09-12-2006, 04:29 PM   #25
james kent's Avatar
Trailer: Boler 1984
Jim
Old 09-17-2006, 11:42 AM   #26
Yvon, how is your Boler? We havent heard from you in a while.
Old 10-09-2006, 07:14 PM   #27
Quebec
Hello Catherine
I have finish ma paint job on my boler
I am happy from the result
I reinstall all the componemt with stainless steel bolt and jamnut . install a Maxair on the top vent
and i add a picture from the first ride of 800 km in Beauce in border of Maine , a beautyfull 3 days weekend for the tankgiving in Canada
Yvon Chayer
Old 10-09-2006, 07:30 PM   #28
Brian B-P's Avatar
Your Boler looks great, Yvon!
boler
1980 Scamp Restore Lawrence W Modifications, Alterations and Updates 1 05-12-2010 09:57 AM
Where to find gasket to restore old jalousie windows DannyH Problem Solving | Owners Helping Owners 3 10-03-2009 01:13 PM
Our 1973 Eco - with recent retro restore Mark and Peg P. Modifications, Alterations and Updates 4 07-14-2008 06:17 PM
restore or modify? Rands E. Problem Solving | Owners Helping Owners 5 03-30-2008 11:16 AM
Restore Feature Mike-B General Chat 24 12-14-2005 10:18 PM
