Restore boler 78 - Fiberglass RV
Old 09-03-2006, 05:55 PM   #1
Yvon Chayer's Avatar
Trailer: Bigfoot 17 ft 1992
Quebec
I am restoring a boler 78
First I remove front window because i dont use it and i have some leak around the glass
I take the gravel shield and install it with fiberglass and finish it with epoxy boddy filler
I sand all the shell , i remove 2 coats of old paint and repair somme scratch
Also i remove the furnace and patch the exhaust hole
The next opration is paint with interlux Brightside
Excuse me i speak english just a bit , i am french canadien
Yvon Chayer is offline   Reply With Quote
Old 09-03-2006, 06:52 PM   #2
Norm Roy's Avatar
Trailer: 75 Boler 13 ft
Hello Yvon,
How bad was the interior?
Good luck on the project.
Norm Roy is offline   Reply With Quote
Old 09-03-2006, 06:52 PM   #3
Brian B-P's Avatar
That's the first I've time heard of replacing the front window with a solid section of wall. It should certainly eliminate any weather sealing issues, and the new front end looks nice and smooth.
Yvon, how are you finishing the inside surface, where the window was? I assume that you will have an insulating lining of some sort, like the Ensolite material which is presumably on the rest of the wall surface.
Old 09-03-2006, 07:07 PM   #4
Catherine H.'s Avatar
Trailer: 82 14 ft Surfside Triple E TM14
Yvon
I would also like to know about the inside where the window was and if you will insulate it. How did you sand it? What tools and materials did you use? Was it difficult?
Catherine H. is offline   Reply With Quote
Old 09-04-2006, 05:38 AM   #5
Quebec
Hello
For the interior finishing i use a sheet of 3/16" cork buy a Rona hardware
I use contact ciment for stick it to the inside fiberglass
I make joint with latex silicone and paint it with a hight quality latex paint ( same color of insolite)
I will take some pictures in the next week and post it
Yvon Chayer
Old 09-04-2006, 05:51 AM   #6
Quebec
To Norm Roy
The interior was in good condition, very clean , no mildew and moisture
When i finish the exterior , just put new curtain and recover the foam
Yvon Chayer
Old 09-04-2006, 10:24 AM   #7
Quebec
Hello Catherine H
For sanding i use a random oscilating air sander
When i fit the fiber glass pannel in the front of the boler i use a small grinder to make grove betwenn to part of fiber
I center it with 12 bolt and washer to ensure that the pannel was flush to the wall of the boler
I use premix ( fiberglass fiber mix with resin ) sale at autoparts
When the first coat was hard , i remove bolt and washer and finish the fiberglass
After i make finition with catalyse putty for automotive boddy finishing
It is not very difficult but require mutch time
Yvon Chayer
Old 09-04-2006, 07:09 PM   #8
Trailer: 84 16 ft Scamp
Thanks for your hard work in writing your process out in English. I now know exactly how you did it!
Old 09-04-2006, 08:27 PM   #9
Yes. Thank you, Yvon. Keep posting your pictures so we can see your good work!
Old 09-07-2006, 07:30 PM   #10
gregshannon's Avatar
Yvon;
I am going to start the same project in October and hope to be finished by spring. So i'm very interested in how long did it take to sand the whole egg. Keep us posted on the paint job
Also, how big was the compressor that you used to run the sander. I have a 2.5 h.p. that can supply 3.5 CFM at 90 lbs PSI. Will this work.
gregshannon is offline   Reply With Quote
Old 09-07-2006, 08:07 PM   #11
Quebec
Hello Greg
I take aroud 20 hours to sand completly the boler but i remonve 2 coats of old paint
I take aroud 2 hours to remove accessories ( light , propane regulator . door etc
For the compreesor i use a 8 cfm at 90 pounds andit dont supply the sander continusly , i stop the sander regulary to give the pressure go up
Now the primer surfacer is apply and i will paint the lower of the boler this week end
I will post some picture of the next week
bye and good luck for your project
Yvon Chayer
Old 09-08-2006, 01:09 PM   #12
I've been through this using small compressors for DA sanders.
What I did was to throttle the air down with the valve on the sander. (It actually seemed to sand better at the lower speed.) Then when the speed dropped too low for good sanding, I would stop for a moment to change paper and let the compressor catch up.
I found it was a good idea to not let the pressure come up to the point that the compressor motor stopped, because it was hot enough that it really didn't want to start again.
Also, if possible, don't run the compressor on an extension cord. Having full voltage sure helps.
If it turns out your compressor just isn't up to the task, consider getting a good electric DA sander. Back when I was painting cars for a hobby, they just weren't available. Now just about every tool outfit has one. From some of the other forums, the Ridgid is probably the best buy, with the Festool the best overall. However, as with anything else, there are a lot of opinions floating around. I happen to have both a Porter Cable and a Festool RO125.
You can also hook your vacuum up to most of the electrics. This is important, since the stuff you are sanding off isn't the nicest stuff to breathe.
Old 09-10-2006, 05:11 PM   #13
Quebec
hello
This afternoon i paint the first coat ofthe lower of my boler
I am happy of the result of my labor
Yvon Chayer
Old 09-10-2006, 09:17 PM   #14
Loren, what is a DA sander?
boler
1980 Scamp Restore Lawrence W Modifications, Alterations and Updates 1 05-12-2010 09:57 AM
Where to find gasket to restore old jalousie windows DannyH Problem Solving | Owners Helping Owners 3 10-03-2009 01:13 PM
Our 1973 Eco - with recent retro restore Mark and Peg P. Modifications, Alterations and Updates 4 07-14-2008 06:17 PM
restore or modify? Rands E. Problem Solving | Owners Helping Owners 5 03-30-2008 11:16 AM
Restore Feature Mike-B General Chat 24 12-14-2005 10:18 PM
