RGB LED Lights around Belly Band - Fiberglass RV
Old 06-14-2015, 08:13 PM   #1
Trailer: 2000 17' Bigfoot CB
Nebraska
Thought I would share my idea on how I am going to put led strip lights around the belly band to create Party Scamp!!
I estimate it will cost $60 or $70.
Initially, I just purchased some led strip lights with adhesive backing that I was going to simply stick to the underside. But they didn't bend enough around the curves, so it was back to the drawing board. Besides, I don't think they would have lasted a year before falling off.
I also could have done rope lights, but that would be too easy!
So, on some random forum, someone suggest Pex tubing (for plumbing). It's about $30 for 50 feet. Well I just happen to have some left over from a project, so let the fun begin!
I drilled holes on the underside of the 1/2" Pex big enough to fit a screwhead thru, then drilled pilot holes in band, and then installed the screws. I used clamps and moved them as needed. I believe it will be fairly weather proof, until the Pex fades at least.
I'll post more as the project continues.
Screen Shot 2015-06-14 at 9.00.08 PM.jpg   Screen Shot 2015-06-14 at 9.00.17 PM.jpg
chud13 is offline   Reply With Quote
Old 06-15-2015, 06:12 PM   #2
Trailer: boler
canada n.s
nice idea !!!! . I find the trick with them how ever is you need to bounce the light of something letting the light mix its self with the colors from the other bulbs in not you just see little cooler spots
farmer is offline   Reply With Quote
Old 06-15-2015, 06:26 PM   #3
Nebraska
I'm hoping the Pex diffuses the LEDs a bit. They are quite bright on their own. Here is a pic of the Pex all the way around.
Old 06-20-2015, 05:08 PM   #4
Nebraska
Ok, I used fish tape to pull the two led strips from both directions to the point where they meet. I have a power center right below the sink, so that's where I am pulling the wires to. I am bringing the wire thru a screw hole that holds the sink cabinet in place. The hole is right below the belly band, so it is hidden. Being that it's an old trailer, the bolt fell out a long time ago, so I didn't actually remove the bolt to do this operation. I should have this baby fired up tonight!
Old 06-20-2015, 05:50 PM   #5
Originally Posted by chud13 View Post
.... I should have this baby fired up tonight!
PICTURES!!!!
Old 06-20-2015, 06:48 PM   #6
There are single and RGB exterior LEDs already inside tubing w/3M adhesive double face tape attached and ready to go on Ebay. Several of the awing manufacturers also offer this for lighting at the end of the awning roll. (The key work is "Exterior")
I have about 18' of it (White LED's only) around the inside of the dinette/sleeping area of my Hunter. It's been adhered to the IKEA curtain track for almost a year without problems.
Old 06-20-2015, 07:05 PM   #7
Rick Mooyman's Avatar
Trailer: 1971 Boler 13' / 2013 Ford Escape
Manitoba
I would love to see a night time pic with the lights on. I was going to run LED's under the trailer but now thinking the belly band idea may be better.
Rick Mooyman is offline   Reply With Quote
Old 06-21-2015, 11:42 AM   #8
Nebraska
Here are some pics and a vid. They look even brighter when it's completely dark.
The reason I installed them was for the music festivals we camp at, but I think they would actually be useful too. If you've ever boon-docked in BFE where it is pitch black, these throw off 360 degrees of light around the camper, so you can see if there are any critters lurking nearby before you step out.
If anyone is interested in more details, lemme know.
Screen Shot 2015-06-21 at 12.19.40 PM.jpg   Screen Shot 2015-06-21 at 12.20.06 PM.jpg
Old 06-21-2015, 12:01 PM   #9
Trailer: '74 Perris Pacer
Fantastic! I love it!
Suzy I. is offline   Reply With Quote
Old 06-22-2015, 02:40 PM   #10
USDM's Avatar
Trailer: UHAUL Ct13
Name:	ImageUploadedByFiberglass RV1435006733.246224.jpg
ID:	85720 I did mine underneath. RgB with remote.
Through the valley of death.
I love my Uhaul.
USDM is offline   Reply With Quote
Old 06-22-2015, 02:41 PM   #11
USDM's Avatar
Trailer: UHAUL Ct13
Added Cree led fog lights for reverse lights, too.
I love my Uhaul.
Old 06-22-2015, 02:44 PM   #12
Nebraska
If you travel at night, do you drive with them on?
Old 06-22-2015, 02:59 PM   #13
USDM's Avatar
Trailer: UHAUL Ct13
Technically I could but I would be asking to get pulled over.
Old 06-22-2015, 03:11 PM   #14
USDM's Avatar
Trailer: UHAUL Ct13
what awning setup do you have?
led lights, light, lights
Rope lights on the belly band? clmess3 Electrical | Charging, Systems, Solar and Generators 11 08-31-2012 08:29 PM
lights under belly band sfoss Modifications, Alterations and Updates 3 05-03-2012 03:05 PM
Solar Green LED lights around the Scamp Joy A Modifications, Alterations and Updates 3 01-17-2011 01:42 PM
Solar belly band led rope lights shane n Modifications, Alterations and Updates 4 11-28-2010 01:57 PM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 11:05 AM
» Trailer Showcase
Ventura
redwine
Tiffany
Meghan
