Rivet washers? - Fiberglass RV
Old 06-03-2016, 06:02 AM   #1
DaMScampers's Avatar
Rivet washers?
Are Rivet Washers a good or bad idea?
I've never used them but saw them today and liked the idea of them for the application of fiberglass. Yet I ask for your collective wisdom.
DaMScampers is offline   Reply With Quote
Old 06-03-2016, 06:07 AM   #2
You need the plastic washer for the caps to "snap" onto and make a water tight seal. Snap Caps & Plastic Washers
Old 06-03-2016, 06:10 AM   #3
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I like them, especially for relatively crushable materials such as fiberglass. By crushable I mean that the hole in the fiberglass can be made bigger (crushes outward) as the bulge moves toward the head thus not letting the rivet clamp on both sides of the joint. Used on the end side of the joint, not the rivet head side. Can make installing the decorative acorn nuts more fussy to install. But not all trailers use them. You also would probably need a longer rivet to make sure the rivet extends long enough to bulge beyond the washer.
The snap cap base goes right under the rivet head, but I think you're referring to small aluminum washers they intend for the other side of the joint.
Quando omni flunkus, moritati
Old 06-03-2016, 08:20 AM   #4
Borden's Avatar
Name: Borden and Carole
ordered a 100 neoprene rivet washers used to make a water proof seal at trailer wall and head of pop rivet; also got water proof closed end pop rivets for our trailer, look original, are used on fiberglass boats and airstream trailers as well
1978 Ontario made Boler
Old 06-03-2016, 01:57 PM   #5
It sounds like you're talking about using a backing washer for the rivet to grip on. On fiberglass this is definitely a good idea. Rivets can pull through soft materials, especially if the hole wasn't drilled cleanly. I used them when I replaced the fridge vent covers on my trailer. A couple of the old rivets had pulled through the fiberglass.
VB_in_BC is offline   Reply With Quote
Old 06-03-2016, 02:20 PM   #6
A rivet washer on the inside will distribute the forces so as to not shatter the fiberglass and make the holl larger. I think it is a must to use but a pain to do because someone needs to be inside to install and hold the washer. Good Luck.
Old 06-09-2016, 11:47 AM   #7
Borden's Avatar
water proof rivets for camper
Pics of closed end water proof pop rivets, we purchased 5/32 closed end pop rivets with neoprene washers and 3/16 closed end pop rivets; the 5/32 use a washer and 3/16 are a cup head design no washer needed, 100 = $25 approx.
Notice the nail head is not showing on end shot
The 5/32 stainless with stainless mandrel showing the 3/16 is aluminium with steel mandrel. most rivets on the boler are the 3/16 aluminium we got two lengths the shorter ones 19.95 a 100 and the longer ones 24.00 per 100
hope this helps
P.S. also got stainless backup washers for the rivets
Old 06-13-2016, 08:52 PM   #8
Borden's Avatar
Warning
The 3/6 closed end rivets, installed with neoprene washers and broke 3 pop rivet guns. The Titan 15050 did the job well and easy. The are definitely water proof.
Also doing clearance lights.
We have used a neoprene washer at the inside wall to make a water tight connection to hold and connect the power. "all other old holes have been filled in"
P.S. took some of the 5/32 rivet washers and used a leather punch to make the hole 3/16 and placed them under the head of the rivet worked great. Also the boler rivets go into steel brackets on the inside was a two person job.
To rivet or not to rivet? johnwgorman1 Care and Feeding of Molded Fiberglass Trailers 55 05-07-2015 03:48 PM
Compact replacement washers for pop-top SouthwestOregon201 Problem Solving | Owners Helping Owners 1 04-11-2013 10:51 AM
To rivet or not to rivet dykim18 Modifications, Alterations and Updates 0 08-28-2012 01:53 PM
rivet rivet kayleigh0302 Modifications, Alterations and Updates 8 03-29-2012 02:51 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
