Rivets and Acorn Nuts - Fiberglass RV
Old 11-15-2005, 07:02 AM   #1
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
If you're new to trailers, you may wonder what's the deal with the acorn nuts on the inside of Casitas. Are there really bolts? Maybe so on some trailers, but not as delivered from Casita. The acorn nuts is a good way to hide the rivet end.
Here's a sketch I found on the hard drive. Just in case. Just populatin' the Mod Board. You should probably push silicone into the hole as well as the outside of the rivet to keep it water resistant.
Without adult supervision...
Also,
Old 11-15-2005, 07:51 AM   #2
John & Sandy M's Avatar
Trailer: 1999 Scamp 16 ft
Any idea as to rivet/acorn size? I have a couple in our Scamp that have a rivet but no nut and I would like to replace.
John & Sandy M is offline   Reply With Quote
Old 11-15-2005, 08:01 AM   #3
Steve L.'s Avatar
Most of the "structural" rivets on the Casita are, I believe, 3/16". A 1/4x20 nut will just fit over the end of the rivet before it's set. The idea is that the rivet just clears inside the threads and then as you expand the rivet it "squishes" into the threads.
I say "structural" in the sense that the cabinets are hung with them and that's a relatively heavy load.
I'd check with the Scamp owners before you buy since there may be differences.
Also,
Old 11-16-2005, 02:26 AM   #4
Pete Dumbleton's Avatar
There was recently a long discussion re: rivets on Yahoo Scampers, including some folks who have built airplanes -- the consensus was that the best place to get rivets is from the egg manf -- Scamp, for example, will sell an entire rerivet kit including rivets in proper quantities and sizes, acorn nuts, plastic caps and bases -- One needs to specifiy whether it has ratfur or elephant skin inside.
Alternatively, one can just call Scamp, describe the rivet location and they will sell a small quantity.
Old 11-16-2005, 01:53 PM   #5
Brian B-P's Avatar
There's a nice little page on this subject at Boler Life - Acorn Pop Rivet - I think by a FiberglassRV member (but I can't remember your name at the moment - sorry!).
Old 11-16-2005, 03:08 PM   #6
Frank Campbell
Old 11-16-2005, 09:36 PM   #7
Trailer: 72 Boler
mmmmmmm accorn nuts is that how the squirrels get their iron????
Lew King is offline   Reply With Quote
Rivets, Acorn nuts, Rivnuts etc. Dan B Care and Feeding of Molded Fiberglass Trailers 45 11-22-2016 08:21 AM
Speed Nuts Mike Bromley Care and Feeding of Molded Fiberglass Trailers 5 04-30-2010 08:15 PM
Scamp Acorn Nuts Parker Buckley Problem Solving | Owners Helping Owners 8 10-14-2009 08:08 PM
Nuts - Bolts % Other HDW Darwin Maring Problem Solving | Owners Helping Owners 1 05-09-2007 06:03 PM
