09-12-2014, 02:37 PM
Trailer: Amerigo
Indiana
Roof Fan install or not
Ok gang I got an easy one today LOL My 77 Amerigo does not have a roof fan. I wonder if the benefit of one is worth cutting a hole in my roof. My biggest fear is creating a leaking roof. If i do go with a fan its going to be 12volt and be the biggest I can buy. I fugure if install the fan its sure as heck going to move some air LOL With that said I would love some feed back. THANKS IN ADVANCE!!!
09-12-2014, 02:56 PM
A properly installed fan won't leak. It is one of the best mods you could do.
Follow the instructions and enjoy the results!
Fantastic Fan is a quality product and they make one with features and prices to fit most any budget.
09-12-2014, 03:07 PM
Trailer: Escape Trailers
Massachusetts
We agree with Floyd
We wouldn't want to be without the Fantastic Fan in our Scamp. We use it multiple times most days. We also have AC and have used it 4 or 5 times in 3 years.
Follow Floyd's advice on the install and you will be very happy.
David
09-12-2014, 03:28 PM
Trailer: Class A Motorhome
If you install a FanTastic Fan, be sure to order the roof spacers you need for the thin fiberglass roof. They are free from the factory, just call and ask.
I always install Fantastic units. Right now PPL motorhomes in texas has them on sale starting at $99. They have a huge website.
09-12-2014, 03:29 PM
"Properly installed" what ever that means.
You do create another leak point when ever you cut a hole in the roof.
No A/C in my trailer. I carry a Constant Breeze 12 volt box fan. I think out of around 1000 days of camping it's been used maybe 3 times. I had a MaxxAir fan but I didn't want to install it because I didn't want to put another hole in the roof. So I sold it.
09-12-2014, 04:14 PM
It means "properly installed".
I bought a brand new T-Shirt the other day, and it already had four holes in it... I would consider it defective and useless without every one of them.
Even the pocket had a hole it... which I found handy and useful.
09-12-2014, 04:17 PM
Trailer: Amerigo
Indiana
I guess one of my concerns is my roof dips or slopes down in the middle. Not a bunch like a inch maybe 2. Is that a valid concern or is that topically in the FG world??
09-12-2014, 04:23 PM
Unless your roof slopes away from the fan, you are almost guaranteed to have a leak. does water pool there now?
09-12-2014, 04:27 PM
The Amerigo has a flat roof which can sag over time. If it is sever it may need to be raised and reinforced. Of course it has probably reached a fairly stable condition since it has been around a while. Even though the seal should hold wherever the vent is placed, you might be wise to choose a spot close to the end or off-center, away from the lowest spot.
Of course, cutting the new hole for the vent could present the opportunity to lift and straighten the roof.
09-12-2014, 04:29 PM
Everyone swears by roof fans. If I put mine on full, I barely noticed a breeze. I think it's because the Trillium has so many windows that open. As such I seldom use it. When cooking it's useful and if the trailer is very hot. We have a $15 o2cool fan in the window that uses far less power. I use that instead. I recently discovered that the Maxfan that came with my trailer is always on, adding to the parasitic load draining my battery. I don't think I would order a roof fan again or if I did I'd buy one with a real on/off switch. Raz
09-12-2014, 04:39 PM
Trailer: Amerigo
Indiana
Well you all might think I'm crazy but I just went out and checked to roof it does NOT sag like I thought it did. We had about 3" of rain over the past 30 hours and no water. I thank you all for the feed back but wondering if the fan will help cool the camper enough to warrant a hole. I do not plan to do much cooking inside unless raining. So the near sole purpose is for cooling.
09-12-2014, 04:40 PM
The on / off switch can be added after the fact. It doesn't need to be in the fan, a DC breaker on the feed to the fan would work.
09-12-2014, 04:42 PM
When used correctly, they ROCK. The idea is to close all the windows, except for the one next to you. Then when the fan is exhausting, it feels like a breeze is always blowing in the window.
09-12-2014, 04:45 PM
POBox 1267, Denison, Texas
Our Maxx fan primarily is used to get hot air out of the trailer and it does an excellent job in no time. We mostly use it to avoid using the air conditioner.
It is only on if we turn it on. If we want to use it as a fan, it can be used that way also.
09-12-2014, 06:42 PM
We use our Fantastic fan far more than our A/C plus the fan runs on 12 VDC so if your camping without hookups it still works > I installed one on my 1999 Scamp and as Floyd says .if you install it properly it does not leak . We would not be without one . It works great for drawing moisture from the trailer IMHO
09-12-2014, 08:56 PM
Trailer: 2015 Escape 5.0TA
On a recent trip to Alabama in June (Alabama + June = HOT), cracking a window by the bed and running the fantastic fan resulted in a trailer cooled adequately so that the A/C was not necessary. There a so many places where leaks can occur (around belly bands, windows, doors, etc., but when properly maintained, do not. And as Floyd states, sealed properly it will NOT leak. Definitely, a worthwhile addition to add a fan. Not installing a fan for fear of creating a leak IMHO would be like never towing the trailer anywhere for fear that you might get a flat tire or a bug squished on the fiberglass.
What a long strange trip it’s been!
09-12-2014, 09:40 PM
We just got back from 4 days boondocking at Carlsbad State Beach. The weather was hot and muggy. Generators were not allowed after 8:00PM, so the Fantastic Fan was used all night to keep the air moving. The battery was down about 10-12% in the morning which took about 2 hours to re-charge with a 100w solar panel. Free cool air! The fan is a nice addition.
Russ
09-12-2014, 09:56 PM
If you augment that solar panel with the just releases Apple Lunar I-Panel it will charge up overnight as well..... They are 5.5 X 11.5" and are $872.00, I-Pad controller not included.
Question already asked:
"Is that a new I-Pad 6 in your pocket, or are you just happy to see me?"
09-13-2014, 06:24 AM
Didn't mean to hit a nerve. Just giving my opinion. Sorry, Raz
09-13-2014, 07:43 AM
Trailer: Former 13’Scamp, now Snoozy
I had installed a Fantastic Fan in our Scamp, and now have a MaxxAir fan in our Lil Snoozy. The MaxxAir gives me more speed selections, is quieter, and can be left open during rain storms. Roof fans work great when used as David stated (only open the window that you would like the breeze to come in).
Dave & Paula
