Roof Vent - Fiberglass RV
Old 10-09-2007, 12:50 PM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
I took T shaped aluminum and .125 thick Lexan (Lexan will NOT crack)and made a Clear Roof Vent Cover
Looking out from the inside http://i67.photobucket.com/albums/h2...an63/no004.jpg
Top view http://i67.photobucket.com/albums/h2...an63/no007.jpg
Another top view http://i67.photobucket.com/albums/h2...an63/no006.jpg Now my Scamp will fit in my garage with out taking off the roof vent cover, plus I have a clear skylight in my scamp.Its surprizing how much light is in the trailer now with the clear roof vent cover.
Old 10-09-2007, 03:28 PM   #2
Bob H's Avatar
Trailer: 1983 Scamp 13 ft Standard
I took T shaped aluminum and .125 thick Lexan (Lexan will NOT crack)and made a Clear Roof Vent Cover...
Looks Great Kevin! I want to replace my old & cruddy vent cover now.
From the photos, I take it that the lexan is bonded on top of the frame and sealed around the edges and in each screw hole.
2 Questions:
Is there any pitch to the lexan to allow any water runoff? Also is there any weatherstripping on the underside of the frame to vacilitate a seal?
Great Job & Great VIEW!
ConwayBob
Check out my Scamp restoration video on Youtube, & my Ham Radio Blog. Or take the 50 cent tour...
Bob H is offline   Reply With Quote
Old 10-09-2007, 04:28 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
No pitch. Just crack the vent to get a slight angle.WEATHERSTRIPPING - I used 3M automotive double sided foam tape(1/16 thick) I put 2 layers down.
Old 10-09-2007, 06:30 PM   #4
Greg A's Avatar
Trailer: 2015 Escape 19
Turned out really cool Kevin.
Now you'll need one of those vent cover blinds on the inside or you'll be up at first light of day...
Owner:
Fiberglass-RV-4Sale.com
Scamp Owners International
Old 10-09-2007, 08:38 PM   #5
james kent's Avatar
Trailer: Boler 1984
Very good!
Ingenuity pays!
Old 10-11-2007, 08:28 PM   #6
Trailer: 13 ft Scamp
Great Job, I had to make one of these too, but I used wood for the frame and plexiglass. It worked in a pinch, but yours looks much better.
dsheets70 is offline   Reply With Quote
Old 10-11-2007, 09:38 PM   #7
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
Wow! That's cool!
BOBSMITH is offline   Reply With Quote
Old 10-13-2007, 12:40 PM   #8
Trailer: 1976 Boler
HI
I too wanted to be able fit my boler into my standard garage so I installed an aftermarket car sunroof. Works great and if needed I can take the whole glass out if I wanted allowing increased ventilation
Cheers
Al
al gilliland is offline   Reply With Quote
Old 10-13-2007, 04:47 PM   #9
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
al gilliland
Thats another GREAT idea. Thats whats GREAT about this board, is all the information you can get.
Old 10-17-2007, 08:23 AM   #10
efawcett's Avatar
That is soooo cool!
It came out great!
You wouldn't happen to have a parts list would you!?
Was it "T" or "L" shaped aluminum? Did you connect the aluminum sides together somehow to make the frame?
Thanks,
Eric
efawcett is offline   Reply With Quote
Old 10-17-2007, 09:10 AM   #11
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
T shaped aluminum http://i67.photobucket.com/albums/h2...an63/no021.jpg 2 -22" and 2-15" 1 sheet of Lexan(will not crack) 3M double sided foam automotive tape http://www.shoplet.com/office/db/MMM401612.html Screws and nuts. On the corners I used 5 minuate epoxy to seal the gaps.
Old 10-17-2007, 09:21 AM   #12
efawcett's Avatar
Thanks so much Kevin!
Last question! Is a sheet of Lexan something I can pick up around town or do I need to special order it off of the crazy internet!
Thanks Again!
Old 10-17-2007, 11:25 AM   #13
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Got my Lexan at Mills FleetFarm http://www.fleetfarm.com/ about $13.00 for a 18"x26" sheet .090 thick.Also look on Ebay.
Old 10-17-2007, 04:39 PM   #14
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
Odem,Texas
Send a message via AIM to Phil Underwood
lookin good
Phil & Denise Underwood
1997 Bigfoot 21 RB
2002 F-250
Phil Underwood is offline   Reply With Quote
Roof Vent Mike Whitney Problem Solving | Owners Helping Owners 10 02-27-2010 08:18 AM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 04:41 PM
Roof Vent jefh Classified Archives 0 10-27-2007 07:07 AM
Roof Vent gregziglar Modifications, Alterations and Updates 3 08-08-2006 03:37 PM
Roof Vent Kevin K General Chat 0 12-31-1969 07:00 PM
