Rooftop solar on Bigfoot travel trailer - Page 2 - Fiberglass RV
Old 02-05-2019, 04:09 AM   #15
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
Also thinking of mounting my panels on roof, on my Casita, and watched the video's and can do it, But a few questions.
I had a panel once that went on my Boler with suction cups, never traveling with them on roof, but my problem was, the panel was so close to the fiberglass that it discolored it.
Now I am going to mount one on Casita with brackets, will this also discolor if kept off roof an inch or so?
How do you keep this panel clean? Do you carry a ladder around with you?
Old 02-05-2019, 05:57 AM   #16
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
Originally Posted by Alex Adams View Post
I see a proper link also but do not see what Gilles sees.
A capture of what I see with the link :
Gilles
Bigfoot 15B17G.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 02-05-2019, 06:02 AM   #17
Gilles's Avatar
Quebec
Originally Posted by Rushin View Post
Haha, I speak French now?
Excuse me, I forgot to disable the translator before giving my answer ...
Gilles
Bigfoot 15B17G.
Old 02-05-2019, 06:42 AM   #18
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
That was what I was referring to. I thought maybe you had been infected by the dreaded Marceau virus!
Old 02-06-2019, 10:32 PM   #19
I have a 2018 21RB and it was pre-wired for solar by having wires coiled up at the top of the fridge vent on top. It did a squirrel path and the other end was coiled up underneath. I mounted 2 100W flexible panels on each side of the skylight using VHB tape. After 1 season, no problems. A friend has an Airstream and his panels are taped on too.
Ben
btroxell is offline   Reply With Quote
Old 02-06-2019, 11:30 PM   #20
Trailer: Currently shopping for Burro, scamp or casita
Ben
Ben, that's great! Can you tell what path the cables make when they enter the vent? Also does your 21rb has the battery inside or outside the camper?
Rushin is offline   Reply With Quote
Old 02-07-2019, 10:26 AM   #21
The cables go down the front outside of the stack. I brought them into the trailer by the charge controller where I also installed the solar controller. My batteries are outside, under the front shroud.
Ben
Old 02-07-2019, 04:13 PM   #22
Ben
So the cables go inside the camper into the charge controller inside? Where did you place the charge controller and where do wires from the controller go into the battery?
Old 02-08-2019, 05:55 PM   #23
My trailer came "prewired for solar". That ment the wire was coiled up at the top of the fridge vent, down the vent and into the the cabinet next to the door. The cable was cut with a coil and then continued out the cabinet back into the fridge area and out the bottom of the trailer and forward where it was coiled up. I reconnected the wires in the cabinet and ran the coiled end into the trailer by the charge controller, where I also installed the solar charger.
Ben
Old 02-09-2019, 12:46 PM   #24
Name: ginette & ron
Trailer: 2008 25RB 21 Bigfoot
We have the same trailer. We ran the cable dowb thru the fridge vent and fished them thru to under the boot rack. We have the controler mounted on the aisle side of the boot rack.
GiRo proud new owner 2008 bigfoot 21'with cargo pod and Ram 1500 Ecodiesel. Attached with a Pro Pride Hitch(Hensley design)
giro53 is offline   Reply With Quote
Old 02-09-2019, 05:19 PM   #25
Does it reduce the value of RV if you drill holes to install solar/satellite and if sealed properly? Understanding, ideally less holes less potential leaks. Thanks.
araytime is offline   Reply With Quote
Old 02-09-2019, 05:52 PM   #26
Name: Old Viking 38
Trailer: Bigfoot 29Sl Motor Home
Go to Bigfoot Owners Club International |
Free registration for new owners. Search the forum and forum archives for your trailer and or rooftop solar installations. Lots of information, I believe the best access is down the refrigerator vent. Annual registration fee is $25.00 if you decide to stay with the club.
dschase is offline   Reply With Quote
bigfoot, solar
A/C - Adding a Rooftop Unit Stephan G Ryan Care and Feeding of Molded Fiberglass Trailers 6 07-22-2010 08:10 PM
Rooftop Solar Installation on a 13' Scamp efawcett Problem Solving | Owners Helping Owners 6 07-21-2009 07:15 AM
rooftop a/c nick c Modifications, Alterations and Updates 5 11-09-2008 08:31 AM
Rooftop carrier Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
