Routing Water Lines - Fiberglass RV
Old 05-04-2014, 12:07 PM   #1
Carl Brooks's Avatar
Trailer: 73 Tri-Fab
Routing Water Lines
Howdy y'all,
Today I'm working on water lines in my lil love bug and several questions have popped into my fiberglass clogged brain.
Just how were the water lines run from under the sink to the water heater? Somehow I don't think holes thru the floor with bare 3/8 copper tubing running under the trailer is a factory build.
Was 3/8 the size used or should I consider going to 1/2''?
I'm planning on using stainless steel flex lines or would that be a bad choice? I can't think of any reason why they wouldn't be a perfect choice.
Inquiring minds want to know.
Carl
Carl Brooks is offline   Reply With Quote
Old 05-04-2014, 01:02 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
Most, if not all, of modern plumbing AND trailers is done with PEX brand plastic tubing and either PEX connectors (takes a special crimp tool) or Shark brand fittings. You can play with these at the local big box (Loews, Home Depot.) One of the big advantages is that PEX has more expansion tolerance for freezing water in the lines without splittlng. Also good for hot or cold. WAY easier and cheaper to route than metal and has better flow rates because it's so smooth inside. I don't think I 've seen any in trailers with over 3/8 ID (fits standard plumbing connectors.)
Charlie Y
Charlie Y
Old 05-04-2014, 01:26 PM   #3
I am assuming our hot water tank is also inside the tailer? In that case most fiberglass trailers have all their water lines and connections running inside the trailer. Normally around the bottom inside edge of the trailer to get to where ever the water needs to get to.
Old 05-04-2014, 01:35 PM   #4
tractors1's Avatar
Are you sure the external lines aren't the propane feed for the water heater or furnace?
Charlie Y
Old 05-04-2014, 02:08 PM   #5
After 40+ years, hard telling what has been added and/or changed. I don't know what a 1973 Tri-Fab even looks like, but almost all of the earlier FGRV's were sans water heaters from the factory and yours may have been added in or at least changed out by a previous owner.
I have installed three water heaters in the past 2 years in FGRV's and in all cases I used PEX pipe & fittings and ran same inside the trailer. Besides the increased possibility of physical damage, water pipes run external to the trailer are at greater risk of freezing in cold weather.
Flex lines are tempting, but long lines may move around enough during travel to promote premature seal failure at the swivel ends. Most were intended for fixed, non-moving, applications except, of course, for those we have here in California where earthquakes keep things moving on a daily basis. I sometimes use flex lines from a secured PEX transition to metal fitting to a faucet, but they are usually no longer than 12"
Old 05-04-2014, 02:20 PM   #6
Robert Johans's Avatar
Trailer: Nest Caravans
Totally agree with the above endorsement of PEX wherever possible. However, I would not fear the stainless IF they provide some ease to the install AND you keep the lengths short.
As to copper lines, kinda doubt that they are water lines, but I've sen some strange set-ups...
Old 05-04-2014, 02:42 PM   #7
Trailer: 73 Tri-Fab
Yes. Factory LP/Electric water heater inside trailer.
Old 05-04-2014, 02:43 PM   #8
Trailer: 73 Tri-Fab
That's run on a 3/8 copper line also, right next to the waterlines.
Old 05-04-2014, 02:50 PM   #9
Trailer: 73 Tri-Fab
"After 40+ years, hard telling what has been added and/or changed. I don't know what a 1973 Tri-Fab even looks like, but almost all of the earlier FGRV's were sans water heaters from the factory and yours may have been added in or at least changed out by a previous owner."
This is what I'm learning as I get more into this labor of love. It looks just like a Boler with minor differences. Tail lights, windows. It also has a shower and a potty built in.
An A/C was added in the back on the floor so I'm guessing that's why everything has been rerouted underneath.
Old 05-06-2014, 10:07 PM   #10
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
I had a plumber help me plumb a '78 Trillium w/ pex a couple of years ago and when I ask him to help with my newer 79 that I have installed a water heater and pump and outside shower in he suggested brass fittings and stainless flex lines to plumb the whole thing. Have only used the trailer a couple of times since doing the plumbing but it works flawlessly. My plumber friend mentioned that if you have a pex fitting leak on the road you are in trouble but any plumbing or hardware store will have stainless flex hoses to make any repairs necessary- not that he thought they would fail. YMMV
Reid Larsen is offline   Reply With Quote
Old 05-07-2014, 01:38 AM   #11
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
IIRC, home code around here requires 12" of metal line on the water heater output before pex is used, due to deterioration. I used copper flex line.
Old 05-07-2014, 07:31 PM   #12
Trailer: 73 Tri-Fab
Reid,
That makes a lot of sense. I believe I will go that way.
Thank you.
Old 05-19-2014, 06:16 PM   #13
Trailer: 73 Tri-Fab
Went with PEX. Easier to work with.
Scamp 13' water line routing? JohnF Modifications, Alterations and Updates 4 10-20-2011 09:00 PM
Is this safe routing for the brake wires? lars Towing, Hitching, Axles and Running Gear 2 10-07-2011 03:38 PM
Water lines Lainey Problem Solving | Owners Helping Owners 0 07-09-2008 01:34 PM
HOW do you blow out your trailer water lines? Karalyn Plumbing | Systems and Fixtures 8 10-16-2006 07:18 PM
Wire Routing Loren G. Hedahl Problem Solving | Owners Helping Owners 8 02-20-2006 11:47 AM
